Leaking and wetness around Charcoal Canister Area (pics) - JeepForum.com
 2Likes
  • 1 Post By Boojo35
  • 1 Post By Siva283
post #1 of 14 Old 09-10-2019, 03:39 PM Thread Starter
natewill18
As of recent I've been having extreme gas pressure release when I take off my gas cap to pump gas ,and now there's leaking after a drive right underneath my charcoal canister. And there's liquid everywhere as you can see in the pic. Any thoughts if both issues are related? Any solutions for a fix ?
P. S. 3rd photo is from underneath the charcoal canister. You can see the black fluid droplets on the starter solenoid next to the red transmission bellhousing
IMG_20190910_112723_01_1568151542067.jpg   IMG_20190910_112537_01_1568151579797.jpg   20190910_103120_1568158885243.jpg
1989 Jeep Wrangler YJ
4 cyl 2.5L TBI // 5 spd man
33x12.5x15 tires
4" RC Lift w 1" RE booms
natewill18 is offline
post #2 of 14 Old 09-10-2019, 03:45 PM
Siva283
Siva283's Avatar
Your Gas cap vents vacuum or let's air in. Your rollover valves vent pressure to the canister it sounds like you either severely overfilled your tank or more likely something is plugged your vent system between the engine and canister. A third option and mine did this is my fuel pump was overheating badly creating more pressure than the vents can handle it had all the gas in my tank almost to hot to touch
Ask me how I know...
Siva283 is offline
post #3 of 14 Old 09-10-2019, 05:18 PM Thread Starter
natewill18
I'll check choice 2 and 3 because I always ride half tank lol
33x12.5x15 tires
post #4 of 14 Old 09-10-2019, 07:03 PM
bruinjeeper
bruinjeeper's Avatar
if that was gas... you would certainly smell it. Does it smell like fuel . . .
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #5 of 14 Old 09-10-2019, 08:09 PM Thread Starter
natewill18
Yes my Jeep has always smelled like fuel
33x12.5x15 tires
post #6 of 14 Old 09-11-2019, 05:30 AM
Siva283
Siva283's Avatar
I think you have your answer then. Now you need to run the lines to see where the failure is. That can turn into a dangerous situation quickly.
Siva283 is offline
post #7 of 14 Old 09-12-2019, 05:20 PM
bruinjeeper
Yum!
~YJOTM MAY '16~
~YJOTM JULY '19~
post #8 of 14 Old 09-13-2019, 06:12 PM
Boojo35
1987 YJ Wrangler
Yikes! I don't even like the smell of oil cause that can catch fire too....... although much harder than fuel....
Chrisnvegas likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #9 of 14 Old 09-15-2019, 07:59 PM
Azhunter1
Mine was running like crap after I got it and I ended up dropping the tank cleaning it out and blowing about a 100psi down the line. The crap that came out was awesome. I ended up putting a third filter on right where the fuel line comes off the frame and over to the fuel pump. I used a clear filter so I could monitor the crap. Oh my jeep is a 88 4.2 with a carb.
Azhunter1 is offline
post #10 of 14 Old 09-16-2019, 01:16 AM
Chrisnvegas
Chrisnvegas's Avatar
Sure doesn't look like gas to me. Looks oily. What is it, gas or oil? Kinda makes a difference!
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #11 of 14 Old 09-16-2019, 06:07 AM
Siva283
Siva283's Avatar
I dont know what I was thinking origionally when I looked at those pics. You should check your oil pressure sender and your dipstick when I got oil there thats where it came from.
You also need to find that fuel smell. My fiancee was was killed when her jeep caught on fire. Dont risk it it isnt worth.
Siva283 is offline
post #12 of 14 Old 09-16-2019, 10:20 AM
bruinjeeper
That's why I wanted to confirm with the OP if it was gas... vastly different smell.
The texture and its appearance doesnt look like fuel. Its grimey. Dipstick tube may be blowing out oil or even from the valve cover on that side..if it was the sending unit, it'd be all over the place... hood, fender well, hell even the radiator. And i am fairly certain his engine would be seized by now...a sending unit failure can be catastrophic in no time
Doubtful... but a hairline crack on the dipstick tube somewhere on the pipe should be inspected for
~YJOTM MAY '16~
~YJOTM JULY '19~
post #13 of 14 Old 09-16-2019, 11:58 AM
Siva283
Siva283's Avatar
Or if your an idoit like me and screw it in tight but not tight enough the sending unit will leak slowly. Definitly looks like oil. I dont know why I was thinking those pics were in the back. Fuel is still nothing to mess around with. It defdinitly hits a spot. I would be worried about the fuel smell first then the oil
Siva283 is offline
post #14 of 14 Old 09-16-2019, 12:01 PM
Siva283
Siva283's Avatar
When something isn't right with the fuel this can happen and did. Snuffed a life far to soon and took 2 kids mother away.
Siva283 is offline
