Just installed a barnes skidplate - Page 4 - JeepForum.com
 17Likes
post #46 of 55 Old 07-10-2019, 10:57 PM
jbolty
jbolty's Avatar
not sure if these pix from the mars rover will help, hard to get a good angle.
bruinjeeper likes this.
jbolty is offline
post #47 of 55 Old 07-10-2019, 11:35 PM
bruinjeeper
bruinjeeper's Avatar
Helps a lot thanks.
Did you crack your tub? Lol
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #48 of 55 Old 07-11-2019, 04:40 PM
jebmoore
Junior Member
@joblty - Is that massaging in addition to a BL. Didn't see you mention if you had one or not.
jebmoore is offline
post #49 of 55 Old 07-11-2019, 05:39 PM
jbolty
jbolty's Avatar
1" BL and MML
where are you in San Diego? You could come look at it.
jbolty is offline
post #50 of 55 Old 07-12-2019, 12:18 AM
jebmoore
Junior Member
1" BL and MML
I am in Chula Vista and that would be awesome.
Sent from my iPhone using Tapatalk
jebmoore is offline
post #51 of 55 Old 07-14-2019, 04:37 PM
fishadventure
fishadventure's Avatar
Originally Posted by bruinjeeper View Post
if you lower the lip at the pan it can sit a little closer. I have a deep pan too.
It sounds like with me being a manual I might be ok with just a 1 inch Body lift.
A number of build threads I have read involve the manuals... the 1" MML and 1" BL got them through. But completely flat, I often saw re-clocking the tcase being involved.
I think adjusting the floor is fairly simple if you can weld. I raised my motor/transmission like 3” higher for a flat skid. I had to cut the floor support to clear the tcase plus cut out where the SYE output is and build a piece to weld back in to keep the ujoint from whacking
I’d suggest that you not hesitate to cut the floor and extend the hump or whatever’s necessary. This was a pretty quick mod and you’ll have nowhere near the clearance issues I made for myself!
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #52 of 55 Old 07-14-2019, 04:52 PM
Awesome
Awesome's Avatar
Sorry Bruin, I didn't see you asking for my experience until now.
MML and BL is 100% necessary. I made my own MML with a couple of aluminum blocks. I really should have just bought the Brown Dog mounts, because my stock mounts are worn out anyway. For a flat skid with minimal clearancing issues I recommend using a super short SYE. Using a standard SYE is what gets a lot of people into trouble with clearing the output yoke. Spend the extra $50 and get the super short SYE. I got a Terraflex unit because JB was out of stock when I was ordering my parts. I haven't had any issues with it.
I have a totally flat plate as my skid/trans mount.
I did not modify the exhaust bracket.
I did not modify the transmission tunnel.
I did not "modify" the floor with a hammer.
I did not modify the transmission mount. I looked and looked, and I really can't see how you can really gain any clearance from changing the mount. It's only a little over 1" thick to begin with.
I did not modify the transfer case clocking. I cannot see how you can gain clearance from doing so. If you clock it down, you'll have to have a taller transmission mount (which pushes everything else up). If you clock it up, it'll hit the floor.
I DID modify the floor support under the driver's seat by cutting a notch into it to clear part of the transfer case. I probably could have cut the transfer case instead. I don't think the part of the case that was hitting is structural.
If I did it again I'd build a separate crossmember that mounts the transmission to the frame, and keep the skid as a separate unit. I'll end up doing this anyway some day when I get bored. My skid is only 3/16" and it's very heavy and difficult to line up with everything.
The 4th 5-seater YJ in the world.
Awesome is offline
post #53 of 55 Old 07-14-2019, 07:06 PM
bruinjeeper
not really keen on changing up my SYE for a super short version... should have got that in the beginning - what's done is done.
thanks for the details. all really helpful
~YJOTM MAY '16~
~YJOTM JULY '19~
post #54 of 55 Old 07-14-2019, 08:19 PM
Awesome
Awesome's Avatar
Sell yours and get a new one. The extra length on the DS is worth it, and so is the clearance.
Awesome is offline
post #55 of 55 Old 07-20-2019, 06:17 AM
fishadventure
Originally Posted by Awesome View Post
So
I DID modify the floor support under the driver's seat by cutting a notch into it to clear part of the transfer case. I probably could have cut the transfer case instead...structural....
The floor support is structural. I boxed mine after cutting the channel to obtain clearance with 16 or 14 but that’s probably not a big deal structural area in reality.
Granted my situation isn’t like yours, but I had to cut casting ears off the transfer case in addition to clearancing the channel.
Also you are correct - a short SYE probably won’t need the floor cut away and patched for clearance
