Just installed a barnes skidplate - Page 2 - JeepForum.com
 17Likes
post #16 of 55 Old 01-09-2019, 07:50 AM
Louie4
Louie4's Avatar
1935 CJ2A
Is this it?
https://genright.com/products/univer...ember-kit.html
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #17 of 55 Old 01-11-2019, 05:00 AM
jeep63
jeep63's Avatar
Originally Posted by NHfireLJ View Post
Check UFC under cover fab. They make 0" to 3" drop skids. nice products
I'll throw my weight in on UFC... Nice solid skid.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
post #18 of 55 Old 01-11-2019, 04:23 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by Louie4 View Post
Yup
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #19 of 55 Old 07-09-2019, 10:10 PM
bruinjeeper
bruinjeeper's Avatar
Originally Posted by jbolty View Post
I have the ultra thin UFC and it drops maybe an inch below the frame. Had to fab the transmission mount and massage the floor a little but it's been great.
how much "massaging" we talking here?
they recommend at least a 2" BL. I have a 1" going on soon and already have a 1" MML installed with the stock 30rh automatic.
did you clock your tcase?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #20 of 55 Old 07-10-2019, 07:09 AM
Siva283
Siva283's Avatar
I was wondering the same thing. I have a 1 MM lift I just put in.(Gotta love just using common spring bushings for the motor mount) and I am about to do a 1 body lift. I have been trying to figure how flat I can do with my skid since I need a new one soon I had to use fender washers on it to keep it up. Sounds like a 1 inch drop would about fit the bill to keep from having to massage the floor.
Ask me how I know...
Siva283 is offline
post #21 of 55 Old 07-10-2019, 07:31 AM
gutthans
gutthans's Avatar
Been a while for this thread, but this seems like a good time to post up my TDK skid pics. A little less clearance than some of the others, but damn hard to beat for workability. It's a 2 piece unit with the flat plate separately attaching to the 'pan' portion. Around town I drop the plate off as it's 1/4 steel and weighs about 60 lbs.
I also drill and tap the frame for studs, and use conical nuts to hold it on. That'll work better for stock plates because it eliminates the rust-in-the-hole issue. TDK holes are flat so I flip the nuts.
gutthans is offline
post #22 of 55 Old 07-10-2019, 07:38 AM
Siva283
Siva283's Avatar
HOw did you tap the frame and get a good bite. The frame is only about 1/8th inch. Doesnt seem like you would get more than 2 threads?
Siva283 is offline
post #23 of 55 Old 07-10-2019, 08:45 AM
gutthans
gutthans's Avatar
I ran a 1/2 x 20 SAE thread. It goes through the frame and rethreads the nut behind it as well (factory frame). The TDK frame has a tall nut welded flush that gets retapped to the 1/2 x 20. Gives just shy of 1/2" of threaded area. I use double sided studs with 1/2 x 20 (frame) and 1/2 x 13 (nuts). Blue Loc-tite in and use Eastwood Amber over the inside.
gutthans is offline
post #24 of 55 Old 07-10-2019, 08:55 AM
bruinjeeper
As much as I appreciate another option... I want as much clearance as possible and the UCF skid seems to fit the bill.
@jbolty I am wondering if transmission option matters when it comes to clearances. Or is it a case of the TC? I would prefer not to have to do as much as clocking the TC. This project can only work for me if it's as quick, painless and cheap as possible. I have no issue with massaging with a BFH. But would like a definite answer on if it would be enough to make the 1" Ultra thin UCF skid work. Or even a full on Barnes flat skid.
@Awesome can you chime in here with your experiences?
~YJOTM MAY '16~
~YJOTM JULY '19~
post #25 of 55 Old 07-10-2019, 08:55 AM
jbolty
jbolty's Avatar
Not much. Some one fussy might cut the floor and build a little house but I just smacked it with a 5# hammer a few times. The drive shaft yoke was hitting the floor; that's it.
NHfireLJ likes this.
jbolty is offline
post #26 of 55 Old 07-10-2019, 09:01 AM
jbolty
jbolty's Avatar
I have an auto trans so the mount is a little different but that made it easy to modify. Cut an inch out of the bracket, smacked the floor a few times and presto.
thinking about it now I had to modify the exhaust bracket too, just to raise the pipe. All in all not a big job. We put the same skid on a TJ with a rubicon transfer case and did have to cut the floor for that one.
jbolty is offline
post #27 of 55 Old 07-10-2019, 09:05 AM
Siva283
Siva283's Avatar
Do you know if the Auto sits higher than the manual?
Siva283 is offline
post #28 of 55 Old 07-10-2019, 09:13 AM
jbolty
jbolty's Avatar
it might. I used the original rubber mount and cut an inch out of the bracket. Can't find a picture. you could also cut a little off the front lip of the skid and gain an inch.
found a pic of the oricinal auto bracket. this is 1/8 thick and bent into a sort of flat top pyramid.
Siva283 likes this.
jbolty is offline
post #29 of 55 Old 07-10-2019, 09:15 AM
bruinjeeper
Thank you.
I also have an automatic. These were my concerns as most belly ups I have seen involved the manuals.
So the tcase yoke is the issue. No problem.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #30 of 55 Old 07-10-2019, 09:17 AM
bruinjeeper
Interesting. An inch out of the bottom of the bracket I am assuming.
I will look at photos of the UCF skid once more to see if I can understand how cutting an inch from its lip would help. Can't visualize it right now
~YJOTM MAY '16~
~YJOTM JULY '19~
