July '21 YJOTM - Vote Now! - JeepForum.com
View Poll Results: Who is YOUR July '21 YJOTM elect?
V8FUN 1 3.23%
daddyjeep87 3 9.68%
Calisk8er1080 1 3.23%
GermantownJeep 16 51.61%
timatoe 8 25.81%
Waternut 2 6.45%
Voters: 31. You may not vote on this poll
 1Likes
Closed Thread
post #1 of 30 Old 07-27-2021, 03:54 PM Thread Starter
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
It's a well-rounded mixedbag of goodies this month! Good luck to participants and voters
Voter Rules
1st rule of YJOTM is you do not vote for yourself.
2nd rule of YJOTM is you DO NOT VOTE FOR YOURSELF.
3rd rule of YJOTM is you do NOT solicit votes from outside JF or within JF. Investigations have been held, jeeps have been disqualified. DON'T do it!
4th rule of YJOTM is all nonsupporting members must post when you vote or it will not be counted. Paid members do not have to post when voting.
5th rule of YJOTM is all voters will remain public as to promote self moderation
Up for grabs: Bragging rights for July 2021 YJOTM and $200 gift cert. from Qtec (Thank you @Quadratec - you rock). REMINDER: All YJOTM winners are automatically entered for the chance at being voted for the illustrious title of YJOTY as well as inclusion on the /f12 Calendar courtesy of @daddyjeep87 - thanks dude!
Let's Git'r DONE!
Username: V8FUN
1993 YJ
5.2 Magnum, AX-15, 8.8 rear w/disks, 4"lift on 33's
I bought my Jeep beginning of 2020 with the 2.5. I got it cheap and it ran, but didn't drive. 4wd didn't work, no seats, no bumpers, gas tank had a hole in the side, wrong rear end, mismatch wheels and tires, but it did have a clapped out hardtop and full doors. Got it home and got it driving and kept improving it, and continue to do so. Improvements and upgrades include:
5.2 Magnum from Dakota (freshened up), AA mounts
Alum radiator w/ custom shroud
Custom exhaust w/ cat
H4 upgrade w/relay
AX-15 and NP231 w/ SYE
8.8 w/ disks (D30 up front)
Tom Woods rear DL
Boomerangs F&R, combo of ploy and rubber in leafs
MORE Anti wrap bar and steering brace
TruTracs F&R w/4.10's
Bushwacker flares
Poison Spider hood loovers
JKS Quicker Disconnects
Smittybilt Rear bumper with swing out
Smittybilt sliders
Redhead Dakota PS box
Ruff Stuff 7/8 Heim Steering Kit
Ruff Stuff rear SUA ubolt plates and 5/8 ubolts all the way around
Warrior Products front ubolt plates
Still waiting on Rock Hard front cage
Username: daddyjeep87
1987 YJ
From the ground up...
40x13.5-17 Nitto Trail Grappler MTs
17x8 Vision Soft 8 wheels
Front Axle - Late 70's ford radius arm high pinion Dana44
-extended radius arms and Ballistic Joints on the frame end
-4.56 gears
-Spool
-Chromoly shafts
Rear Axle - Late 70's ford 9"
-disk brake conversion
-Single Triangulated 4 link
-4.56 gears
-Detroit Locker
Custom built LCG suspension, 3" or so higher than stock
-ADS 16" travel Nitrogen shocks all the way around
-Ballistic Fab shock hoops front and rear
-Rear lower links are 2" 1/4" wall DOM with 2.63" Ballistic Joints on both ends
-Rear upper links are 1 1/2"-1/4" wall DOM with more Ballistic Joints on both ends
-Wheel base stretched to 102"
-Ballistic Fab frame and axle brackets
Steering box moved forward 2"
Astro Pitman arm
High steer
Custom drag link and tie rod with GM 1 ton ends
RCI 2162 fuel cell behind the rear seat
Modified family style cage that is tied in to the rear shock hoops
Rear bumper built off of the frame with receiver hitch and fixed tire carrier
Front bumper build out of 1/4" plate with integrated winch mount, Ballistic Fab D-ring mounts,
and 2" rock lights
Front fenders built out of 1 3/4"-.120" wall square tubing and 14 ga. Plate
Modified Trail Tubes stinger welded to front bumper and bolted to front fenders
Quadratec Q9500i winch with Synthetic Rope
3/16" rocker guards bolted to the tub
Daystar 1" body lift
95 Chevy 5.7 TBI engine - stock, but cleaned up to look nice
79 Turbo 350 rebuilt by me with Red Alto frictions
95 NP241C with ORD SYE kit
Custom built adapter from TH350 to NP241
Advance Adapters 1310 rear yoke
Rear drive shaft Re-tubed TJ Shaft with a spare re-tubed WJ shaft
Front drive shaft Re-tubed Ram 1500 front shaft
Custom skid plates
Modified XJ t-case shift lever and custom linkages
Winters Sidewinder Shifter
Custom exhaust with Block Hugger headers and Flowmaster 40 series muffler, wrapped front to
back
Champion aluminum radiator
Transmission and power steering coolers in front of radiator
Optima red top
Custom built battery box
Custom modular snorkel
Stand alone accessory power distribution using factory TJ PDC
Green LED rock lights
Custom Krylon paint complete with old school hot rod flames. This was modeled after the
Muscle Machines toy Jeeps if anyone remembers them
Quadratec Bimini plus
Cobra CB Radio
Custom built center console
It recently scored 1316 on the RTI ramp and 940 on Metalcloak's CTI ramp
Brief history of your jeep and how it came to be.*
I originally bought this jeep in February of 1999. It ran like crap due to the stock carb, but that was soon
replaced with a Holley 2 barrel. I put on a 4" Rough Country lift and some 31" BFG MT's and ran it like
that for a lot of years. It eventually got a Howell TBI upgrade. After the frame rusted out and the tranny
died it slowly got build into what it is today. I had a 5.2 rebuilt by my local VoTech school, but that didn't
work out so well. It now has all Chevy drive train. Somewhere around 2001 is when it picked up the
DaddyJeep name. My oldest son would hear me coming home from work and run to the door and say
"DaddyJeep" so it kind of stuck.
Username: Calisk8er1080
1992 YJ
-4.0
-ax-15
-Atlas 4 t-case
-fabricating a custom dash from scratch
-working on on board air
-working on a tons swap
-working on just about everything just short of a frame off/engine swap to be completely honest...
-Oh and a rattlecan paint job for good measure
My first jeep. Bought it in 2013 with a small lift and 33s already on it. Wheeled it a few times, daily'd it pretty much everywhere, then pulled it off the road to rebuild it from the ground up... 6 years later very little progress has been made. I blame my wife. I bought her a JK that she dailys AND wheels pretty hard... guess which vehicle keeps getting all my attention?
Anyway, Even though I haven't driven it in years, I still love the thing like it was my own child. I found some pictures of it from before I garaged it, so maybe I'll get more than just one (pity) vote this time around
The day I brought it home. I fell in love with it pretty much instantly on the drive home from the lot.
The one and only time I washed it. It proceeded to break down for several months the same day, so I don't wash jeeps anymore...
My first time wheeling it. Rausch Creek in PA, Topless for Tatas trail.
One of my fave pics I've ever taken, not just of the jeep, but of anything.
Username: GermantownJeep
1995 Jeep Wrangler Rio Grande
-Rubicon Express 4.5 lift, 33x12.50 Goodyear MTRs, Ford 8.8 rear end, SRC bumpers/rock sliders, Bestop seats, Tuffy console/glove box, Cobra 18 wx CB, Herculined tub, pocket flares/trimmed fenders, Flowmaster exhaust, Kilby gas tank skid, KC lights, Engo 10k lb winch. Probably more Im forgetting about.
-Im the original owner. Purchased in December 1995 with a little help from my parents (I was 17). Probably one of the last YJs ever built. It was my daily driver all through college and my early twenties. I was in a wreck in 2004 and decided to get a car with AC, but I kept the Jeep and gradually fixed it up. Lift and tires went on in 05. Did the 8.8 swap in 06. Everything else was done over the last 15 years. I dont have as much time for it now that I have kids, but they love going for rides every now and then. I dont plan on getting rid of it anytime soon.
Username: timatoe
1990 YJ
4.2 I6 w/Howell Fuel Injection; AX-15 with external slave conversion; Atlas 4.3; HP44 Front w/ARB 14B Rear with Yukon Grizzly - 5.13 gears; currently on 37x12.5x17 Cooper STT Pros and KMC beadlocks; Spring over with 3 front stretch on XJ springs - 8 rear stretch on Explorer Sport Trac springs (until the 4 link); Metal Cloak front fenders; homebrew sliders on BTF blank rocker armor; rear Metal Cloak-ish comp fenders on blank BTF armor; Poison Spyder tire carrier; sprayed Road Rash orange with Monstaliner (black in well black) and a whole slew of other mods.
Bought this basically stock with a set of 33s, giant 2 shackle lift and a 2 body lift. My friend Mr.B got me to the Rubicon and fed the addiction LOL. Its been through a few iterations of builds with just taking the shackles and body lift off and trimming for TJ flares and 33s, to SOA on YJ springs, D30 and 8.8, to fit 35s to the current stretch and comp cut. Like everyone else, its still not done. Collecting parts for a rear four link, then hopefully on to the front, then new cage, LS swap, and on and on
Then:
Now:
Username: Waternut
1988 YJ
Story: I bought this jeep about 4 years ago and it barely ran with the 2.5L engine. All of the emissions were removed and it was leaking fuel, overheating, and all the electrics were flickering on the ride home. My buddy and I were joking that we were filming an episode of Roadkill. I cleaned everything up and got it working only to decide the engine wasnt powerful enough and it needed gears. That gave me 5th gear back but also highlighted the need for more power. One thing led to another and I managed to swap an LS engine in for next to nothing but the level of effort and research required to keep things cheap took a huge toll on my free time.
As my wheeling confidence and offroad friend base increased, I started down the path of making an extremely capable rig while trying to maintain as much on road drivability as I couldor at least as much as you can for a vehicle which I decided would never have doors or a top again, sticky tires, and full hydro steering. I dont like to consider myself a fair weather Jeeper but I like driving this Jeep because its special every time I drive it. So if the weather is nice, its always a treat to drive and I leave the bad weather days for a less interesting daily driver.
Drivetrain:
5.3 LS engine with 4l60E transmission
Adams driveshafts front and rear
Rear - Ford 8.8, OX air locker, and 4.88 gears with Yukons Ultimate 88 kit
Front Custom Dana 44 with RCV axles, ARB locker, and 4.88 gears (re-tubed for driver drop not done by me)
Lokar shifters for the transmission and transfer case
Suspension:
Front - Triangulated 4 link with 14 Fox coilovers stretched 7
Rear Triangulated 4 link with 14 Fox coilovers stretched 2
Total wheelbase is 102
Wheels and tires:
39x13.5x17 BFG red label stickies
DIY beadlock wheels using Total Metal Innovation kit
Apex rapid tire valves
Brakes:
8.8 with Chevy front disc brakes and Ruff Stuff disc brake bracket (technically a Ford 9 disc brake upgrade)
Chevy D44 brakes with Ford D44 bearings/rotors for a 5x5.5 bolt pattern
Ford Explorer Booster and MC (1.063 bore its a little soft but brakes very well)
Steering:
D44 has the machined knuckles with high steer arms. Pieced together a full hydro setup using PSC 8 Ram, Trail Gear 120cc orbital and adapted it to the LS power steering pump with a simple fluid cooler. All hoses, fittings, etc came from surplus center on the cheap.
Armor and body:
Trail Gear DIY welded front cage and 92+ rear roll bar
DIY aluminum rock sliders
DIY aluminum fold down storage tailgate
DIY aluminum flat skid plate
DIY aluminum fuel tank and skid
Barnes low profile tailplate bumper
Stubby high line front fenders
Speedmaster 12000lb winch with synthetic cable
Genright hood vents
Interior:
Custom fiberglass flat dash with JEGS gauges and 6x9 speakers
Stock HVAC system removed and Maradyne heater box installed
5 gal air tank added under the dash where the HVAC used to be for the air lockers
Cypher aftermarket reclining suspension seats with harnesses and harness bar
Raptor bedliner throughout tub
Honorable mentions:
Onboard alternator stick welder for emergency trail repairs
Battery relocated to the bottom of the tub for a lower CG
[url=https://ibb.co/wgttmPB]
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #2 of 30 Old 07-27-2021, 04:58 PM
jcourt667
jcourt667's Avatar
Voted.
94 Sahara YJ 4.0L HO. 260k miles!
jcourt667 is offline
post #3 of 30 Old 07-27-2021, 05:06 PM
calisk8er1080
calisk8er1080's Avatar
Gah, tough choice as always, but I managed to pick one to vote for.
Been MIA from here for a while... I'm trying to be active in this community again.
calisk8er1080 is offline
post #4 of 30 Old 07-27-2021, 06:06 PM
timatoe
timatoe's Avatar
Voted!!
timatoe is offline
post #5 of 30 Old 07-27-2021, 08:46 PM Thread Starter
bruinjeeper
post #6 of 30 Old 07-27-2021, 09:14 PM
bobracing
Were actually suppose to pick only one?
Voted
92 YJ
https://www.jeepforum.com/forum/f22/open-mouth-insert-jeep-2878945/
bobracing is offline
post #7 of 30 Old 07-27-2021, 10:05 PM
CJWoodman
CJWoodman's Avatar
1983 CJ8
Voted
Big Ugly cJ8 build in progress
Jeep Air
CJWoodman is offline
post #8 of 30 Old 07-28-2021, 06:25 AM
Dake
Dake's Avatar
Voted
Waiting on my Rough Country lift to sag!
April 2020 pandemic YJOTM
Dake is offline
post #9 of 30 Old 07-28-2021, 06:31 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Nice group of Jeeps as always.
87 YJ, 5.7/TH350/NP241/HP Dana44/9", Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
daddyjeep87 is offline
post #10 of 30 Old 07-28-2021, 07:25 AM
DRLExpress
DRLExpress's Avatar
Voted
DRLExpress is offline
post #11 of 30 Old 07-28-2021, 08:04 AM
TSEJEEPERS
TSEJEEPERS's Avatar
voted
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 30 Old 07-28-2021, 08:56 AM
cas6969
cas6969's Avatar
vo-ted
Silicone, the thinking man's duct tape.
cas6969 is offline
post #13 of 30 Old 07-28-2021, 01:34 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
need moar bumps before I can vote.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #14 of 30 Old 07-28-2021, 01:54 PM
Towny72
Yep.
Socialism gave us the Yugo, I'll pass!
Towny72 is offline
post #15 of 30 Old 07-28-2021, 02:59 PM Thread Starter
bruinjeeper
one of the all-time greats
Closed Thread
