July 2019 YJOTM - Vote Now! - JeepForum.com
View Poll Results: Who is July 2019's Sunshine Rig?
Awesome 6 20.00%
daddyjeep87 9 30.00%
bpounds 1 3.33%
bruinjeeper 9 30.00%
Siva283 5 16.67%
Voters: 30. You may not vote on this poll
 9Likes
Closed Thread
post #1 of 45 Old 07-23-2019, 08:36 PM Thread Starter
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Alrighty folks! Summer is in full tilt! Brake cleaner shelf is running low, the wrench and sockets are getting more and more slippery and the kids & grandkids are taking up the elbow grease time (not necessarily a bad thing). Let's see if I can't try and top up that glass for one of you!
Voter Rules
1st rule of YJOTM is you do not vote for yourself.
2nd rule of YJOTM is you DO NOT VOTE FOR YOURSELF.
3rd rule of YJOTM is you do NOT solicit votes from outside JF or within JF. Investigations have been held, jeeps have been disqualified. DON'T do it!
4th rule of YJOTM is all nonsupporting members must post when you vote or it will not be counted. Paid members do not have to post when voting.
5th rule of YJOTM is all voters will remain public as to promote self moderation
Up for grabs: Bragging rights for JULY 2019 YJOTM and $200 gift cert. from Qtec (Thank you @Quadratec - you rock). REMINDER: All YJOTM winners are automatically entered for the chance at being voted for the illustrious title of YJOTY as well as inclusion on the /f12 Calendar. Let's Git'r DONE!
Username: Awesome
1995 YJ
Specifications and Modifications:
4.0 I6
AX15, NP231 w/'True Neutral', Tummy Tuck – True Flat Belly
TeraFlex Super Short Slip Yoke Eliminator
Tatton's Beefy Driveshafts front and rear
8.8, 4.10:1, Limited Slip, Disk Brakes, U-Bolt Flip, Solid cover
D30, WJ Knucles/Brakes, 1-ton Crossover Steering, CAD Delete, Aussie, 4.10:1, Solid cover
31x10.5x15" Duratracs (too small)
Custom front bumper, Rugged Ridge 8500lb Winch
Rear Tire Carrier Bumper, LED Reverse Light Bars
York On Board Air, Freightliner Air Horns
Bilstein 5100 Series longer-travel shocks, Custom shock extensions in the rear
Superlift 3.5" Springs, sagged to about 1.5"- maybe a bit more, Custom Shackles
1" Body Lift
Track Bar / Sway Bar Delete Mod
Ford Ranger Front Bench Seat – Jeep seats 5
Custom Shifter Knobs
Cobra GMRS Radio
Custom Security Storage Trunk
It's been a lot of fun modifying this YJ over the years. It was my daily driver for most of the time that I've owned it, but a couple of years ago it was retired from that role and now it's my toy. Now I get to spend more time on projects, so they can be a bit more involved. My most recent major project was the flat belly skid, which took a total of two months to complete. Whenever we get time, the whole family climbs in and we go rock crawling with the local Jeep club. The YJ manages to keep up with Jeeps sitting on 35"s and impresses everyone we wheel with.
Pictures:
Username: daddyjeep87
1987 YJ
From the ground up...
• 35x12.50-15 Cooper STT's
• cheap steelies
• Front Axle - Late 70's ford radius arm high pinion Dana44
-extended radius arms and Ballistic Joints on the frame end
-4.56 gears
-Detroit True Trac
• Rear Axle - Late 70's ford 9"
-disk brake conversion
-Single Triangulated 4 link
-4.56 gears
-Detroit Locker
• Custom built suspension, 3" or so higher than stock
-ADS 16" travel Nitrogen shocks all the way around
-Ballistic Fab shock hoops front and rear
-Rear lower links are 2"-1/4" wall DOM with 2.63" Ballistic Joints on both ends
-Rear upper links are 1 1/2"-1/4" wall DOM with more Ballistic Joints on both ends
-Wheel base stretched to 102"
-Ballistic Fab frame and axle brackets
• Steering box moved forward 2"
• Astro Pitman arm
• High steer (unknown brand)
• Custom drag link and tie rod with GM 1 ton ends
• RCI 2162 fuel cell behind the rear seat
• Modified family style cage that is tied in to the rear shock hoops
• Rear bumper built off of the frame with receiver hitch and fixed tire carrier
• Front bumper build out of 1/4" plate with integrated winch mount, Ballistic Fab D-ring mounts, and 2" rock lights
• Front fenders built out of 1 3/4"-.120" wall square tubing and 14 ga. Plate
• Trail Tubes stinger welded to front bumper and bolted to front fenders
• Quadratec Q9500i winch
• 3/16" rocker guards bolted to the tub
• Daystar 1" body lift
• '95 Chevy 5.7 TBI engine - stock, but cleaned up to look nice
• '79 Turbo 350
• '95 NP241C with ORD SYE kit
• Custom built adapter from TH350 to NP241
• Advance Adapters 1310 rear yoke
• Rear drive shaft – re-tubed TJ Shaft with a spare re-tubed WJ shaft
• Front drive shaft – Hybrid Chevy 1500 front shaft and XJ rear shaft
• Custom skid plate 1" below the frame
• Modified XJ t-case shift lever and custom linkages
• Modified WJ transmission shifter with S-10 cable
• Custom exhaust with Flowmaster 40 series muffler (for now. It is a little much after a couple hours on the trail)
• Champion aluminum radiator
• Optima red top
• Custom built battery box
• Custom Krylon paint complete with old school hot rod flames. This was modeled after the Muscle Machines toy Jeeps if anyone remembers them
• Quadratec Bimini plus
• Cobra CB Radio
• Custom built center console
• It recently scored 1313 on the RTI ramp and 940 on Metalcloak's CTI ramp
Next items to address
• It has been running a little warm so a fan shroud will be fabricated soon
• While addressing cooling I am adding transmission, engine oil, and power steering coolers.
• Finish up my power distribution center (repurposed WJ PDC)
• Re-route exhaust again and add quieter muffler (Thrush turbo)
• Lower fuel cell through floor to bottom of frame rails to get back some storage.
• Parachute for drag racing. Check in on my build thread in mid August. It will make sense then.
• Upgrade to synthetic winch line if I ever win YJOTM.
Brief history of your jeep and how it came to be.
I originally bought this jeep in February of 1999. It ran like crap due to the stock carb, but that was soon replaced with a Holley 2 barrel. I put on a 4" Rough Country lift and some 31" BFG MT's and ran it like that for a lot of years. It eventually got a Howell TBI upgrade. After the frame rusted out and the tranny died it slowly got build into what it is today. I had a 5.2 rebuilt by my local VoTech school, but that didn't work out so well. It now has all Chevy drive train. Somewhere around 2001 is when it picked up the DaddyJeep name. My oldest son would hear me coming home from work and run to the door and say "DaddyJeep" so it kind of stuck. The Jeep has been a part of my family for a lot of years and is finally performing as I envisioned it. It is an absolute beast and has exceeded my expectations.
Username: bpounds
1988 YJ Canadian Built. We Call her Mauser.
Original 4.2L
Howell TBI fuel injection
CRT HEI ignition
Retro-fit NEW AX-15 with external slave
Advanced Adapters SYE
True neutral TC mode shifter
Adams rear DC driveshaft
Brown Dog motor mounts
Zone 2" lift
Berzerks 1/2" boom shackles
No tracks, no sways, no problem
Dirtworx rear bumper and tire carrier
Warn M8274 Winch with remote SS relay
Mod'd battery tray with Optima Yellow
Military terminals
Custom HD battery cables
LED front fogs
LED rear backup lamp
Green LED dash cluster lights
22" light bar on custom mounts
14" Windshield Wipers mod
Late model TJ side mirrors
Custom mirror relocation
Rugged Ridge console and seats
In & out GOpro mounts
Custom Maglite Rack
Decals to cover scar tissue
Daily Driver
New all-metal brass/copper radiator OEM style
Username: bruinjeeper
1995 YJ
Rebuilt 2.5L/30RH/NP231J
- 3.5" BDS springs
- 3/8" Currie greasable boomshackalaka's front, 1” lift booms rear
- 33x12.5r15 Cooper Discoverer S/T
- 15x8 Cragar soft 8's
- Bilstein 5100s
- D30 w/ TJ shafts (CAD delete) and shock mounts moved up on tube w/ perches mounted atop setup for SOA, Built Ford 8.8 – 4.56 gearing
- 4.0 Throttle Body
- 1” JKS MML
-American RatRods aluminum hood vents.
- Currie SS braided extended brake hosing all around
- RR SYE and XJ cut down rear driveshaft
- Beefy DOM steering linkage, cross over heim steering setup (TMR bracket)
-M.O.R.E rear shock extensions
- 136AMP GC alternator and wiring upgrade
- Flex-a-lite electric fan conversion
- LED CREE Headlights wiring/relay upgrade
- Transmission cooler and deep tranny oil pan for the auto tranny
- LED undercarriage lighting, 3x3 LED light pods (x4), 2x7 LED light bars (x2) 1x6 LED mini light bar mounted on rear spare tire relocated license plate.
- Poison Spyder BFH winch bumper
- S]-[ittybilt 10K X20 wireless waterproof winch
- Modified china made rear swing out tire carrier (shovel mount, rotopax mounts, flagpole mount, hatchet mount)
- Red LED interior lighting/gauges
- Blue Black Widow racing buckets w/ Sparco 4 pt. Harnesses
- Rampage frameless soft top with Bestop half door sliders.
- 4" flush mount tail lights and dime LED reverse lights
- Airaid CAI, full Pacesetter longtube headers into a magnaflo cat and dumped out of a Walker SoundFX exhaust before the rear axle.
- Rock hard cage tie-ins and overhead mounted switch panel
- Monstalined interior and exterior
- S]-[ittybilt 0" front tube fenders, S]-[ittybilt rear 3" tube fender flares and rocksliders with tube step
- Dime size LED signal (x8) incorporated into the stock system. Front of tube fender, tube fender side wall, rear quarter panel, tire carrier.
- Home brewed drop down tailgate table
In the near future:
1” BL, Tummy tuck
Lil' More:
My only daily driver and still kickin'. Thanks for helping me get sicker, and sicker... it's been a fun and bank account crippling adventure that has taught me a lot of good. Thanks guys and gals for the fantastic relief from the daily grind, and for all the future endeavours y'all will undoubtedly assist with.
Username: Siva283
1993 YJ
It has the 4.0/ax15/np231wSYE, I put an 8.8 in it. Regeared it to 4.10 and has a selectable locker in the 8.8 and a lunchbox locker in the front. Custom front and rear driveshafts. There rear frame on both sides was rotted and repaired with CNC cut plates. It has the 136 amp alt from a 98 durango. Sitting on 33's. Bumpers front and rear winch and tire carrier in the works. OBD2 upgrade is also in the works as well.
I bought this Jeep to build with my Fiancee. She was killed in a car fire shortly after. So I built it with her daughters whom I adopted. Marley 9 actually helped with the regear and Jadyn 12 helped install the 8.8 she did some of the welding. They both have helped me replace every gasket in the motor. So it became a father/Daughter project with those girls.
9278 YJ likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #2 of 45 Old 07-23-2019, 08:39 PM
Bong_Holyeo
Bong_Holyeo's Avatar
is it just me or does siva not have photos?
April 2018 YJOTM
June 2019 YJOTM
Bong_Holyeo is offline
post #3 of 45 Old 07-23-2019, 08:42 PM Thread Starter
bruinjeeper
it's just you
post #4 of 45 Old 07-23-2019, 08:48 PM
Bong_Holyeo
Originally Posted by bruinjeeper View Post
it's just you
you are right i refreshed and see them now lol ignore me
NHfireLJ likes this.
April 2018 YJOTM
June 2019 YJOTM
post #5 of 45 Old 07-23-2019, 09:03 PM Thread Starter
bruinjeeper
Yep... it was all you man.
...I had absolutely nothing to do with fouling any photos up *whistles and strolls*
post #6 of 45 Old 07-24-2019, 07:09 AM Thread Starter
bruinjeeper
Bump
Randonexplosion likes this.
post #7 of 45 Old 07-24-2019, 01:57 PM
AZdEvilYJ
AZdEvilYJ's Avatar
Man I might have to flip a coin in a playoff bracket system! I know I’ve voted for each of these jeeps in the past. From a very clean mild stocker, to a wild v8 long travel Jeep with flames excellent line up fellas
bruinjeeper likes this.
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #8 of 45 Old 07-24-2019, 03:15 PM
Flint762
Voted
Flint762 is offline
post #9 of 45 Old 07-24-2019, 08:16 PM
Waternut
Waternut's Avatar
Voted. There is definitely a conflict in my head between sweet jeeps built with money and know-how and jeeps that were built with heart and soul.
Waternut is offline
post #10 of 45 Old 07-24-2019, 11:00 PM
StrippedTorx
StrippedTorx's Avatar
Voted. Lots of nice rigs. Wish there were fellow yjers like you guys closer to myself!
StrippedTorx is offline
post #11 of 45 Old 07-25-2019, 07:58 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
We got us a tight race going on.
87 YJ, 5.7/TH350/NP241/HP Dana44/9", Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
daddyjeep87 is offline
post #12 of 45 Old 07-25-2019, 08:09 AM
V8orBUST
V8orBUST's Avatar
Sunshine rig... lol. Good lineup this month.
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #13 of 45 Old 07-25-2019, 08:17 AM
bobracing
voted
92 YJ
https://www.jeepforum.com/forum/f22/open-mouth-insert-jeep-2878945/
bobracing is offline
post #14 of 45 Old 07-25-2019, 09:08 AM
TSEJEEPERS
TSEJEEPERS's Avatar
voted
Thanks bruinjeeper for doing this!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #15 of 45 Old 07-25-2019, 10:46 AM Thread Starter
bruinjeeper
Bump
Closed Thread
