jeep yj lift question - JeepForum.com
post #1 of 12 Old 07-22-2019, 06:46 PM Thread Starter
94oldblueyj
I have a 94 yj with a 4.0 5 speed and a 8.8 with 4.10s when I bought the jeep it came with 33s but it has a shackle lift and a 2 inch body lift. In the near future I will be replacing the shackle lift with a suspension lift. I am trying to keep the lift small particularly a 2.5 rough country lift, but would I be able to clear the 33x12.5s on that lift and the 2inch body lift with out rubbing? Any help would be greatly appreciated.
94oldblueyj is offline
post #2 of 12 Old 07-22-2019, 07:27 PM
bruinjeeper
bruinjeeper's Avatar
You already have a thread on this
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #3 of 12 Old 07-23-2019, 04:33 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
May rub a little but doable.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #4 of 12 Old 07-23-2019, 06:53 AM
stephencbrinson
How high is the current shackle lift? Do the 33s rub now? Stock shackles are 4in bolt to bolt. How long are your current shackles?
Sent from my SM-G930U using Tapatalk
1992 YJ, 2.5L, AX5, D30, D35, 2.5 RE lift
Daniel 3:18
Ephesians 2:1-12
stephencbrinson is offline
post #5 of 12 Old 07-23-2019, 09:00 AM
Siva283
Siva283's Avatar
You dont want an RC lift or you will be back here asking why your jeep rides like **** after the new lift.
Ask me how I know...
Siva283 is offline
post #6 of 12 Old 07-23-2019, 09:06 AM Thread Starter
94oldblueyj
I will find a picture of the shackles there is a drop bracket for the spring where the shackle was and a 4 inch shackle dropping from the original fixed mounting pointing the same thing in the rear.
It does rub on thee springs at full lock.
post #7 of 12 Old 07-23-2019, 10:13 AM
stephencbrinson
If it rubs on the springs loft won't help. You need to adjust the back spacing on your wheels I think.
Those more knowledgeable should chime in.
Daniel 3:18
Ephesians 2:1-12
post #8 of 12 Old 07-23-2019, 01:14 PM
Siva283
Siva283's Avatar
You are correct. You need a wheel with less backspacing. I believe 3.25 inches of backspace accomodates a 12.5 inch wide 33 or 35.
Or you can adjust your steering stops and just give up a little turning radius
Siva283 is offline
post #9 of 12 Old 07-24-2019, 12:37 AM
xpage
I have a 2" lift, 1" body lift and 1" shackle lift. I run 32s and it seems like i have plenty of room.
xpage is offline
post #10 of 12 Old 07-24-2019, 05:30 AM
Siva283
Siva283's Avatar
@xpage I ran your exact set up but with BDS. I had 33's with barely any rub and I mean just barely.
How do you like your Zone springs. I have been curious about them since my 4 inch RE springs flex great but the highway ride leaves alot to be desired.
Siva283 is offline
post #11 of 12 Old 07-27-2019, 12:31 AM
xpage
I'm quite happy with them. Definitely better than the PO springs. Once I put the tire pressure to 30psi it felt much better over bumps as originally i think it was too rough. I might go down to 28psi in the future to see if the drop to that makes it even smoother for the rougher roads i take around San Diego. A bit more than 2" lift was exactly what I got out of the springs, though closer to 2" than 2.5"
Can't say much about the off-roading feel of them since I haven't done that yet but hope to soon. Just been occupied with work and other things the last 3 months.
xpage is offline
post #12 of 12 Old 07-29-2019, 05:53 AM
Siva283
Siva283's Avatar
I have noticed that a better on road ride usually also equates to great flex off road. I dont even look at off road flex anymore I go for a comfortable on road ride. Even rough country will flex off road. You just gotte set the suspension up right.
Siva283 is offline
