Jeep + Squirrel + dogs = repair of wires - JeepForum.com
post #1 of 41 Old 04-28-2019, 02:38 PM Thread Starter
JohnW63
My dogs went after a squirrel hiding in the engine bay of our Wrangler and by the time we found out they had pulled out sections of the wiring harness and a few other things hanging down. One being the vacuum lines to the valve that operates the transfer case, another is the part of the luum that goes toward the back of the car and plugs into the gearbox and beyond. Need to replace one fuel line. The wire to the iol pressure sender is broken. The wire to the starter solenoid. The OS sensor plug was pulled apart, but I think it is still OK.
Where can I get the main wire loom that runs to the back of the car and new vacuum lines to the transfer case ?
JohnW63 is offline
post #2 of 41 Old 04-29-2019, 02:03 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Have you tried Quadratec?
https://www.quadratec.com/
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 41 Old 04-29-2019, 02:48 PM Thread Starter
JohnW63
Thanks for the tip. I didn't expect them to have more than accessories. While they had some wiring, the section I need wasn't one of them. I checked at my local dealer. They have nothing. I think the dealers don't keep parts available after 10 years. Seems pretty short sighted of Jeep.
I may have to look in salvage yards, ebay, or try to patch and resolder the section back together.
The other one, might be tough. I was mistaken about where it goes. It's a pair of thin , stiff plastic, vacuum lines that go to a vacuum actuator on the front axle. I bet it locks and unlocks the axle when you put it in 4WD.
I have to fix the left front side marker, as they ripped that out too. And a fuel line, and.....
JohnW63 is offline
post #4 of 41 Old 04-29-2019, 02:53 PM Thread Starter
JohnW63
Found the vacuum thing in the service manual. " Command-Trac " vacuum control system. The damaged part looks to be the lines that go to the indicator switch in the dash. I need to crawl around some more to make sure they don't go to the transfer case.
JohnW63 is offline
post #5 of 41 Old 04-30-2019, 05:52 PM
Boojo35
1987 YJ Wrangler
If your vacuum lines are color coded, simply find some rubber vacuum or washer hose that fits snugly over the plastic lines and cut out the bad sections and slip on some hose.
If you cannot find a wire harness. Solder and shrink wrap is a good repair if done correctly. You should be able to match up wire colors for sure but generally it does not come down to that cause the little buggers rarely chew all the way through the copper.
Some useless trivia. Rodents seem to like to eat wiring in certain vehicles or in certain places but not others. I am told that vegetable oil or the equivalent was used to manufacture the wiring insulation and it makes some wiring tasty to rodents and others not so much.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 41 Old 04-30-2019, 08:19 PM Thread Starter
JohnW63
Boojo,
The vacuum lines are both simple black tubes. I do have a question, and can post a picture if needed. There is a vacuum line that starts on the intake manifold, had a T that has one end going into the firewall and the other is held on the firewall until it gets to a spot right above the battery. There is a circular end hanging there that looks like it has a tip that went to something. Maybe the end of the vacuum section I have to fix ? Can anyone with a YJ take a look under the hood and see what should attach to that ?
I am pretty sure the dogs chased the critter up into the engine bay and mangled the wires and stuff, and not squirrels chewing it. They had torn up my fuel lines only a few months ago and I had to have one fixed again, today.
JohnW63 is offline
post #7 of 41 Old 05-01-2019, 06:13 AM
NHfireLJ
NHfireLJ's Avatar
Boojo,
That sounds like the check valve and vent. Its not connected to anything if I recall..
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #8 of 41 Old 05-01-2019, 10:23 AM
daddyjeep87
daddyjeep87's Avatar
1987 YJ Wrangler
Collins Brothers is a large Jeep recycler. They most likely have everything you need. There is also UPFJ Jeep salvage, but they are a little harder to get in tough with. Collins Bros has a web site you can order through.
Make sure you tell them you are working on a Jeep. If you call it a car they may not know what you are talking about. A Jeep is not a car... A Jeep is not a truck... A Jeep is a Jeep.
87 YJ, 5.7/TH350/NP241, Custom 4 link/ Radius Arms, ADS Nitrogen Shocks, 35" Cooper STT
Look for the YJ of The Month thread in the YJ Technical Forum. Vote for your favorite Jeeps.
YJOTM August 19
daddyjeep87 is offline
post #9 of 41 Old 05-01-2019, 12:20 PM
Que89YJ
I will have to put together an updated list of the ones specific to Jeeps. Use google to start with. Search jeep scrapyards, Jeep used parts and car-parts,com searches all the major junkyards all across the US
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 41 Old 05-01-2019, 12:48 PM
Mr.B
Mr.B's Avatar
Do you have the Jeep Field Service Manual(FSM)? It will have all your wiring diagrams and vacuum diagrams.
It would be good to know what year YJ you have. Please fill out your Jeep profile. It helps us help you. I have most of the YJ FSMs that you could download. I just need to know what year is your YJ. Send me a PM with what year you have and I'll PM you a link to download it.
Also I just saw somewhere those 4wd vacuum harnesses. I don't remember where though.
Ham license:
Everyone is Welcome
Mr.B is offline
post #11 of 41 Old 05-01-2019, 03:17 PM
Que89YJ
Hey Mr. B. I haven't had a chance to find the manuals. I have so much archived. I think around 10tb.
I used Morris for the 93 FSM. I'm not sure about the 92. I have a bunch of engineering manuals for the 87/90 from Renix.
Sent from my SM-G955U using Tapatalk
Fault codes:
No Start:
Que89YJ is offline
post #12 of 41 Old 05-01-2019, 05:19 PM Thread Starter
JohnW63
I grabbed a few shots off the internet.
Top left corner above the battery. Looks like it comes over from the right, and hangs a 90 down.
It's a 1991 Wrangler. I thought I had my profile created, way back when I joined.
JohnW63 is offline
post #13 of 41 Old 05-01-2019, 05:23 PM
Que89YJ
I think you're talking about the axle vent.
Fault codes:
No Start:
Que89YJ is offline
post #14 of 41 Old 05-01-2019, 07:49 PM Thread Starter
JohnW63
The line comes from the intake manifold and goes to that spot.
JohnW63 is offline
post #15 of 41 Old 05-01-2019, 07:52 PM Thread Starter
JohnW63
Mr. B
Where is the best place to get that ? The service manuals have lots of diagrams. I would prefer that had it laid out as it would be in the Jeep, rather than a logical diagram.
JohnW63 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
18 Grand Cherokee extreme amount of problems and concerns under 7300 miles professordenk WK2 Grand Cherokee Forum 25 09-16-2019 11:11 PM
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
First jeep, new to Car repair/ Modification Tim Ryan Card New Members/Introductions 0 01-24-2019 08:34 AM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
