Jeep 4.0 - not much power reaching 4000 RPMs - JeepForum.com
 3Likes
post #1 of 21 Old 12-20-2018, 09:52 AM Thread Starter
pablorg
1981 CJ7
HI,
I have a 1995 YJ Sahara 4.0. The problem I have is that the Jeep won't go over 4000 RPMs and it starts to loose power after 3800 RPMs. Instead, I have seen videos of 4.0 engines reaching 4600 RPMs easily
Any ideas what could be wrong.
The engine is recently rebuilt. Bored 60 over. HESCO adjustable pressure regulator. New fuel pump.
Thanks!
- Pablo
95 YJ Sahara AX-15
81 CJ-7 Laredo 360V8-Edelbrock MPI
pablorg is offline
post #2 of 21 Old 12-20-2018, 10:02 AM
Mortgage-payer
Mortgage-payer's Avatar
1976 CJ7
Plugged fuel filter?
I call it a distributor, not a dizzy.
Mortgage-payer is offline
post #3 of 21 Old 12-20-2018, 10:14 AM
jtec
jtec's Avatar
2014 JK Wrangler
I do not understand why over 4k in a jeep 4.0/l but my 2 esp if an automatic.
Anyway first is fuel - check the pressure - Re pump New is nt always good.
Exhaust restrictions - a backpressure gauge will tell easily.
MY favorite use a scanner - the data will help - all done quickly from front seat .
Always codes offer a clue. and we can see live data,
look at ECT, MAP, TPS, and fuel trims and o2 sensor readings .
jtec is offline
post #4 of 21 Old 12-20-2018, 10:26 AM Thread Starter
pablorg
1981 CJ7
The fuel filter and fuel pump are new - changed them 2 weeks ago
- Pablo
95 YJ Sahara AX-15
pablorg is offline
post #5 of 21 Old 12-20-2018, 12:31 PM
jtec
jtec's Avatar
2014 JK Wrangler
X2 new ≠ good
If you have a schraider valve on fuel rail - an EASY test.
Have you look at codes?
jtec is offline
post #6 of 21 Old 12-20-2018, 12:49 PM
gutthans
gutthans's Avatar
Just to check: Are you having this issue in all gears, or just 5th gear? Maybe 4th and 5th? Plugged exhaust (rust or catalytic failure) or too tall tires can lead to this result. Also misadjusted timing settings.
Don't know much about which sensors might contribute (I always rip all of that off and run 'old school')...
Do as suggested, and check fuel output. Your 'new' stuff could be faulty or a line could be plugged. Shake/thump your muffler and cat and listen for junk inside that shouldn't be there...
gutthans is offline
post #7 of 21 Old 12-20-2018, 01:26 PM
V8orBUST
V8orBUST's Avatar
I'm curious about the torque curve above 3500 rpm, the 4.0 makes most of its power in the 2000s I thought. With such an over bore, I would assume your compression ratio is higher possibly requiring more fuel at a higher octane. Timing may also play a part in the increased compression.
Just my thoughts, I can and may well be wrong.
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #8 of 21 Old 12-20-2018, 08:21 PM
Awesome
Awesome's Avatar
You are correct, the engine makes most of its power before it hits 3k. Mine actually drops power noticeably after 3200 RPM.
To the Original Poster:
What gear are you in? If you're trying to do 120 in 5th gear, you're obviously going to have a hard time revving past 4k.
The 4th 5-seater YJ in the world.
Awesome is offline
post #9 of 21 Old 12-21-2018, 11:59 AM Thread Starter
pablorg
1981 CJ7
I am in 3rd gear going uphill. I have 31" tires and 4.56 gears. I am also @ 9800 feet of altitude...
- Pablo
95 YJ Sahara AX-15
pablorg is offline
post #10 of 21 Old 12-21-2018, 12:34 PM Thread Starter
pablorg
1981 CJ7
Compare mine to this, for example:
or
- Pablo
95 YJ Sahara AX-15
pablorg is offline
post #11 of 21 Old 12-21-2018, 01:10 PM
Awesome
Awesome's Avatar
Okay, then you have a fuel or air issue. Check for vacuum leaks using the carb cleaner method. Check your air intake for restrictions. At that altitude you're going to be sucking a lot of air down.
Awesome is offline
post #12 of 21 Old 12-21-2018, 07:41 PM
Boojo35
1987 YJ Wrangler
Good lord. 9800 feet? There is no air left up there. Your engine loses cylinder pressure in a big way because there is no air to compress. An engine is an air pump with combustion added in. It needs air to make power.
Next question. How steep is the hill in degrees?
You may not have a problem IMO.
Awesome likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #13 of 21 Old 12-29-2018, 09:11 PM
rgb66
rgb66's Avatar
or as a wise person once told me. "You don't have a problem, you have a jeep."
Tophog1 likes this.
rgb66 is offline
post #14 of 21 Old 01-03-2019, 11:48 AM Thread Starter
pablorg
1981 CJ7
I am in 3rd gear going uphill..
- Pablo
95 YJ Sahara AX-15
pablorg is offline
post #15 of 21 Old 01-04-2019, 05:29 PM
astjp2
Clogged catalytic converter, my YJ had the same problem and found the exhaust clogged.
astjp2 is offline
