Issues installing an e-locker on my front axle? - JeepForum.com
 6Likes
post #1 of 21 Old 04-07-2020, 10:49 PM Thread Starter
TrevorThe88YJ
I have an 88 YJ - mostly stock. Limited slip in the back. A stock Dana 30 in the front. Front axle has the original hub locking mechanism. I'd like to install an e-locker in the front. I don't run the vehicle extremely hard, but have somewhat routinely taken it places where it's been really challenging because of that stock front axle. It's my daily driver. When I had the limited slip installed in the back, I asked to have a limited slip installed in the front. The techs said not to do it because they didn't feel it was necessary and because they didn't think the stock hubs would handle it. Have run in that configuration now for a few years and have had enough challenges with that stock differential that I need to do something. Seems like an e-locker is a good solution. The question I have is will the stock hubs handle the use of an e-locker or will I need to replace them with manual locking hubs? I'd prefer not to have to do that. Would appreciate any advice you can offer. Thanks so much in advance!
TrevorThe88YJ is offline
post #2 of 21 Old 04-08-2020, 06:59 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I'd fire that "mechanic". There's some serious lack of understanding there. LOTS of folks lock the front axle with excellent success which places far greater stresses on it vs installing a limited slip.
Since you run the "early" version YJ front axle, you'll have the Spicer series 5-260x ujoints, or if they were ever replaced, possibly some other brand that's the same fitment size.
This is generally known as your weak link/fuse on the front axle. Not the unit bearing style hubs.
Arguably, the front axle ears are stronger on the axles with the smaller ujoints like yours because the axle ears have slightly more material as compared to later years that use the larger 5-297x ujoints (or 760 series).
Lots of folks swap to the TJ style axle shafts & unit bearings (which the passenger side is a one piece design) since you'll have the larger ujoints. A different seal is required for the passenger side since the axle diameter is different.
Swapping to manual style hubs can get pricey & there's all sorts of pro/cons. I did it several years ago - but I had a distributors account so my costs were drastically lower than what's available to the general public. That axle is long gone though since I upgraded to a completely different axle.
timatoe likes this.
Joe Dillard is offline
post #3 of 21 Old 04-08-2020, 07:51 AM Thread Starter
TrevorThe88YJ
Thanks! So it sounds like I could install the e-locker and be just fine then...at least from a hub perspective? Iím not a heavy rock crawler and much of the problems Iíve experienced are due to loose gravel like rocks and uneven roads such that one side of my front axle will come off the ground.
post #4 of 21 Old 04-08-2020, 08:21 AM
Waternut
Waternut's Avatar
The cheaper option is to just install a lunchbox locker like the Spartan or Aussie locker. They're around $250 and you can look up youtube videos on how to install it yourself. If you drive in 4wd in the snow much, you won't want it but if you only engage 4wd on loose gravel or dirt, you'll be fine. You won't even notice those lockers in place when driving on the road in 2wd.
timatoe, Awesome and YJDave like this.
Waternut is offline
post #5 of 21 Old 04-08-2020, 03:08 PM
fishadventure
fishadventure's Avatar
Another vote for the Aussie.
BTW I am in Vermont (snow) and I have an Aussie in the Dana 30. It’s a good tool and it was amazing how awesome it was on the first trail run after I installed it. Very invisible on the trail.
(I am of the belief you /shouldn’t/ generally run 4WD on the road in snow because I believe that’s why we see so many 4x4 trucks, suv, and whatever’s off the road in snow: it helps you over-drive the conditions. I may use 4-by on hills or from a standing start but I almost never have driven regular with it. Other people think differently but the Aussie hasn’t effected me as a result. I figure 4-by is for maneuvering, snow-plowing, racing, but not driving.
If a rear wheel skids in four-by-four you likely induce traction loss on a front wheel, leaving only two tires with complete traction. If you’re in 2WD, all four wheels have independent braking and traction. My opinion.
YJDave likes this.
[size=ď3Ē]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 21 Old 04-08-2020, 03:39 PM
jeeepguy
jeeepguy's Avatar
I would recommend getting a TrueTrac in the front axle. Much lower cost, zero maintenance issues and more DD friendly than an e-locker and especially an auto-locker. Works like an open diff most of the time and locks up smoothly and solidly when you need it.
I've had both and even though I have front/rear e-lockers now, the TrueTracs before were nearly as good for WAY less money.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #7 of 21 Old 04-08-2020, 04:03 PM
222Doc
222Doc's Avatar
what can be more street friendly then any type of selective locker, be it ARB or the E- locker? I mean its open on the street and only locks when you turn it on. selective off road is friendly as well since in 4x4 its open so you get better turning and when you need just push the button. The only draw back is the cost really. LSD is ok but its not like a real locker as well.
222Doc is offline
post #8 of 21 Old 04-08-2020, 07:51 PM
80cj
80cj's Avatar
1980 CJ5
I helped a friend regear his YJ several years ago and while we were at it, installed Tru Tracs front and back. What really helped besides the Tru Tracs was removing the sway bar and track bar. That helped the four wheels stay planted on the ground and really let the Tru Tracs put the power to the ground.
80cj is offline
post #9 of 21 Old 04-08-2020, 09:27 PM
Waternut
Waternut's Avatar
Not arguing for or against true trac's or selectable lockers. I've owned OX, ARB, Spartan lunchbox, and the 8.8 limited slip. They all have their place and they will all take one heck of a beating. However, I think it's worth pointing out that a lunchbox locker can be installed by your average guy with very basic tools. Anything that is a full carrier locker will now require resetting your backlash on your gears. It isn't hard...once you know how...but now your average guy will need to do more research to understand it, more tools to accomplish the job, and honestly more confidence in his mechanical skills. If you do a lunchbox locker, you can watch a youtube video and get the job done after work one day. If you want to change your carrier and don't know anything, you're going to spend longer than that just trying to figure out what you need to do and what tools you need to buy.
jbolty likes this.
Waternut is offline
post #10 of 21 Old 04-08-2020, 10:08 PM Thread Starter
TrevorThe88YJ
Thanks for all your advice! I looked up some of those options, but Iíll look at them again. Sounds like I should have no issues with my stock hubs though and thatís great news! Again, thanks to everyone for your help!
post #11 of 21 Old 04-09-2020, 01:33 AM
Chrisnvegas
Chrisnvegas's Avatar
I think he's under the impression that YJ's have auto-locking hubs when they don't.
A lunchbox locker should work well with a CAD right? Won't the unlocked CAD keep the Jeep from driving funky on the street?
"Alferd Packer: ďStand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is online now
post #12 of 21 Old 04-09-2020, 08:17 AM
Waternut
Waternut's Avatar
Unless you have severe front driveshaft misalignment, you won't notice it on the road even without the CAD. Now when I had a front driveshaft that was bent, I noticed it when running a 1 piece passenger axle shaft even without the locker. Ultimately, when not driving the pinion (aka in 2wd), the locker is free to spin. The only hiccup I had with a lunchbox locker and no CAD was when my tire pressures were off by more than 2 psi in the front. When that happened, the locker didn't like to turn after driving a while. Since I shouldn't have that anyway, I consider that my fault. Never heard any clicking over the sound of the engine so that wasn't an issue either.
I have two complaints with the lunchbox locker... First: When on the trail in 4wd, your turning radius will suffer a bit unless you push the clutch in because your front axle will be locked any time you're driving the wheels. Not the end of the world but occasionally, I'd have to back up to make the turn. Second: If you break something in the rear axle and have to drive home in 4wd (aka front wheel drive only), you will be in for a scary ride with an auto locker in the front.
Waternut is offline
post #13 of 21 Old 04-09-2020, 08:59 AM
NHfireLJ
NHfireLJ's Avatar
Its not terrible, and won't be the case if he has a working CAD.
Another vote for Aussie. Ran many in my builds... inexpensive and very functional...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #14 of 21 Old 04-09-2020, 09:06 AM
Waternut
Waternut's Avatar
How does a CAD make it better? It's fully engaged just like a solid axle shaft if you're having to limp home in FWD.
The point I was trying to make earlier was that having CAD or no CAD doesn't really matter in terms of on road driving if the rest of your system is up to par.
In case it's not clear, CAD is central axle disconnect in case the original guy doesn't understand that term.
Waternut is offline
post #15 of 21 Old 04-09-2020, 09:09 AM
NHfireLJ
NHfireLJ's Avatar
Yes I know what a CAD is... but guess I should have reworded... If he has a CAD, he can easily disable to drive home in FWD and on one wheel
SOLD
style intake
NHfireLJ is offline
