interior door lights wont turn on in my 94 yj - JeepForum.com
post #1 of 3 Old 01-21-2019, 05:04 PM Thread Starter
Fishstic
Fishstic's Avatar
The other day I reconnected the Dome lights for the first time since I got the Jeep, (the ones that turn on when you open the doors) replaced both of the bulbs too and they both worked fine, Next day I wake only to see both lights won't turn on anymore? Is it a fuse problem? If so what fuse is it? or a wiring issue? I think you can turn on both lights with the Dimmer right? if that's the case I turned on the Dimmer and the Dash lights turn on fine but the Dome lights still don't light up not even a flicker.
Fishstic is offline
post #2 of 3 Old 01-21-2019, 06:55 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'd pull the bulbs and see if they are still ok, test them. The same circuit feeds the dash and the dome lights, no separate fuse.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 3 Old 01-21-2019, 10:26 PM Thread Starter
Fishstic
Fishstic's Avatar
Yeah, that's what I did earlier tonight, didn't see it at first but when my mom gave it a look she said that the lights burnt out, even though they were bought yesterday. Maybe I got the wrong size? Any idea as to what size they could be?
Fishstic is offline
dimmer switch , dome lights , electrical , wrangler , YJ
