Instrument lights don't work! help! - Page 2 - JeepForum.com
post #16 of 19 Old 03-01-2015, 08:59 PM
ttop191
Originally Posted by kletchworth1 View Post
ok so im having a similar problem except this jeep just got running again after about a year only two lights light up on the instrument panel and the others don't
If you've got some lights but not others it's the individual bulbs that are blown. You'll have to pull the gauge cluster and swap the bulbs out.
ttop191 is offline
post #17 of 19 Old 03-02-2015, 05:55 AM
Mike Romain
I only know the CJ wiring well, but the dimmer has its own fuse, the oil and volts are on a different circuit.
Mike
Mike Romain is offline
post #18 of 19 Old 03-02-2015, 11:23 AM
bergovoy
the flexible circuit board contacts maybe corroded or bent... the little tabs on the light bulb holders that make contact may need to be cleaned, as well as the inside contacts that touch the contacts of the bulb itself
bergovoy is offline
post #19 of 19 Old 03-02-2015, 01:12 PM
bharris68
Gravel Truck Pilot
okay - a few folks who piled on this thread can check here for help on gauge cluster: https://www.jeepforum.com/forum/f12/r...er-how-991307/
For others - do a search for "Fuse Box Layout" or dig around for a link to the FSM for your YJ
bharris68 is offline
electrical , light , instrument , panel , disply , YJ , wrangler
Instrument cluster lights don't work jeep_olllllo_ TJ Wrangler Technical Forum 4 12-30-2009 07:48 AM
Instrument panel lights kimvansa TJ Wrangler Technical Forum 9 10-10-2006 07:45 AM
Instrument Lights SCRubi TJ Wrangler Technical Forum 2 12-03-2005 06:51 PM
Short to the Instrument lights The Dutch Man TJ Wrangler Technical Forum 1 10-31-2005 06:28 PM
No Lights on the instrument panel rrclimber YJ Wrangler Technical Forum 1 06-03-2004 10:17 AM
