Inner C gussets for YJ ?? - JeepForum.com
 7Likes
post #1 of 19 Old 04-29-2021, 11:01 AM Thread Starter
YJ40
YJ40's Avatar
Hi,
i work on my front d30 and try to find some inner C gussets. For JK, TJ and XJ's are lots of kits, but not for a YJ . Will JK gussets work on my YJ? It seems that the lowerJK bracket will not work with my stock shock mounts...
Any idea ?
https://www.quadratec.com/products/16356_100X_A_PG.htm
https://www.quadratec.com/products/52465_6619.htm
Thanks,
Marcel
89´YJ 4.6l , my toy since 1999...
YJ40 is offline
post #2 of 19 Old 04-29-2021, 11:16 AM
222Doc
222Doc's Avatar
i used those on my Jk d44s. installed my self when i sleeved the axles as well. I would think it wont fit well. might be able to mod it too though? Only you will know once you get those and test the fit. Jks the upper goes righto the spring pad, that for sure may be short if you want to come down to the axle.
there are other designs for these as well. thought Tera made some that are solid chunks a bit narrower then the bent plate type. Not sure if that helps what you want to do. The other choice is fab them your self out of .25 plate or like Tera 3/4 inch chunk cut to shape.
222Doc is offline
post #3 of 19 Old 04-29-2021, 11:20 AM
cas6969
cas6969's Avatar
https://taboocustoms.com/store/YJ-Dana-30-C-Gusset-Kit
Silicone, the thinking man's duct tape.
cas6969 is offline
post #4 of 19 Old 04-29-2021, 06:45 PM
Waternut
Waternut's Avatar
This kind of failure really only came to light when JK's hit the scene. It wasn't really an issue on CJ's, YJ's, TJ's, ZJ's, WJ's, or XJ's and all of those came with some version of the D30 axle. However, it's a pretty well documented problem on the JK's. I haven't seen any conclusive evidence as to why it affects JK's more but I suspect it has to do with the increased weight. When a bone stock YJ weighs 2900lbs and a bone stock JKU is 4200lbs, it does start to make sense though...especially when you consider the typical mods and their increase in weight of the two models.
If it costs $12 and you're bored and have the axle apart, maybe it'd be worth it but I wouldn't tear the axle down and pay $70 to strengthen something that will likely be one of the last things to fail on your rig prior to upgrading axles.
Waternut is offline
post #5 of 19 Old 04-29-2021, 09:56 PM
SevenSlotAddict
The basic problem is manufacturers are leaving the bastige child YJ in the dirt. Considering they are 30+ years old I sorta understand. Many of the YJs on the road have been modified by some of their PO's so demand isnt the biggest. Why devote a lot of time manufacturing somethi8ng that may sit on a shelf?
I sometimes dont understand because the Wranglers and CJ's are constantly being restored and driven so accessories are still in demand. One example I see is extra wide fender flares. Yeah I cant find a 7" kit that direct fits the YJ for less than $400. TJs? Still available. With the boom in the JK generation entering the SUV market as strong as they have, the focus is on them.
SevenSlotAddict is offline
post #6 of 19 Old 04-30-2021, 07:51 AM
Waternut
Waternut's Avatar
Although I agree the pre-JK Jeeps don't have the same level of aftermarket support that the JK and JL have. However, I don't think it's necessarily a bad thing. Most mods for YJ's are functional and less show while the JK is heavily biased towards show and while there are certainly more lift/offroad specific mods available to the JK, there isn't really a shortage of companies who offer that for the YJ. Heck, you even have companies who have developed a pre-designed 3 link/4 link with for coilovers for a YJ and believe it or not, it's cheaper for the YJ.
That said, I think the vast majority of people who put inner C gussets on a JK buy the parts online and pay someone to weld them on because it's necessary pretty early on in the build sequence. IMO, by the time a YJ needs inner C gussets, you've either learned how to weld or you know someone who can weld it for you because you didn't get to the point of needing this by bolting on a big lift and bigger tires. Anyone who mods a YJ enough to need this kind of thing on a YJ probably has enough 1/4" plate scrap laying around to make a set of these and weld them on but realistically, they've welded in a new axle already and don't need them anyway.
jsawduste likes this.
Waternut is offline
post #7 of 19 Old 04-30-2021, 07:54 AM Thread Starter
YJ40
YJ40's Avatar
Thanks,
the taboocustoms kit looks intresting,so i contacted them, but it seems they don't ship outside US and Canada, and i'm outside...
But i could use this design to fabricate my own gussets.
@Waternut the axle is apart to bare steel so this is the best time for a uprade.And a little bit overkill is better than allways to fear something could bent on a trail. It will get a truss also and when it is done a new black shiny powdercoat.
YJ40 is offline
post #8 of 19 Old 04-30-2021, 08:05 AM
Waternut
Waternut's Avatar
Originally Posted by YJ40 View Post
Thanks,
I understand the feeling of security. However, I ran 35's with a locker an a V8 in a big boulder field bigger than my tires. Didn't even run a truss although I considered that. I broke the ring and pinion which is what forced an axle upgrade.
Waternut is offline
post #9 of 19 Old 04-30-2021, 08:06 AM
shaggyjim
On a YJ Dana 30 I would think the tube would bend way before the inner C.
timatoe likes this.
shaggyjim is offline
post #10 of 19 Old 04-30-2021, 08:20 AM Thread Starter
YJ40
YJ40's Avatar
Years ago i broke my tube out of the diff on my old D35 rear, so i would stay on the safe side...
YJ40 is offline
post #11 of 19 Old 04-30-2021, 08:56 AM
Waternut
Waternut's Avatar
To each their own and gussets should be easy enough but the D35 is a totally different animal. The D35 is an infamous axle in terms of every aspect being a known failure point. The D30 in the YJ isn't the same and is known to be quite reliable with 35's in most cases with stock power.
I'm not trying to discourage doing this as it should be cheap and easy to do yourself but don't stress about it or let it hold anything else up because it's really not that important.
Waternut is offline
post #12 of 19 Old 05-01-2021, 05:17 AM
fishadventure
fishadventure's Avatar
@joedillard !has had great posts on this in the past FYI
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #13 of 19 Old 05-03-2021, 05:44 AM
NHfireLJ
NHfireLJ's Avatar
https://www.ironrockoffroad.com/prod...c-gussets.html
https://www.artecindustries.com/tjinnerc
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is online now
post #14 of 19 Old 05-04-2021, 10:25 AM
fishadventure
Ever seee the rough cownty video on their D30 truss kit? says that their’s has splines for ultimate strength and describes the pieces as “armor.”
post #15 of 19 Old 05-04-2021, 10:43 AM
RockWoRM
RockWoRM's Avatar
Yup, cracked the axle right under the perch's on the long side. Luckily, someone in the group had a 110 welder to get it fixed.
Waternut made a good point... the weight factor. I've never had mine weighed, but I know it's mucho heavy, so I did the Artec truss and C gussets. But even tho the JKUs are heavier, seems there's got to be some other reason they are so prone to fail?
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
