Identifying Dash Wiring - JeepForum.com
 1Likes
  • 1 Post By LumaWJ
post #1 of 13 Old 07-21-2019, 09:03 PM Thread Starter
WildBillinTN
WildBillinTN's Avatar
1978 CJ5
I’ve torn the dash off of my Wrangler to take care of a few issues. While I’ve got it apart, I’m trying to clean up the wiring. There are three harnesses that I found just hanging out on the left side that I can’t figure out what they were intended for. Based on some diagrams, I think one could have been a door jamb switch? No idea on the other. Can anyone help me out?
753E1413-5533-4D7F-9C15-08538040F67B_1563760974775.jpg   94A46424-649A-492D-93FB-577455917904_1563761005631.jpg
1970 CJ-6 Buick 225 (RIP)
!978 CJ-5 304
1990 Jeep Comanche 4.0
1992 Jeep Wrangler 4.0
WildBillinTN is offline
post #2 of 13 Old 07-22-2019, 06:58 AM
mikewiz38
While not 100% sure, one looks like it's the little button that tells you when the door is closed so the lights turn off. The other one looks like it may be for the sound bar. There's also a footwell light down there but it doesn't look like that one. I'm pretty sure those are the only wires that are over there anyways.
1994 Wrangler YJ - 4.0L - 5 Speed
mikewiz38 is offline
post #3 of 13 Old 07-22-2019, 08:44 AM
adiubald
The one on the right (4 wire) is the factory front passenger speaker connection. The OEM speaker has the mating connector. You should be able to confirm by tracing back to the radio harness.
When I bought my '95, I ordered it without a radio - it had no options. Last summer I picked up a '91 "fully loaded" and I am finding all kinds of connections under the dash that I have never seen before too.
adiubald is offline
post #4 of 13 Old 07-23-2019, 10:48 PM
littletoes
This might help?
littletoes is offline
post #5 of 13 Old 07-24-2019, 06:49 AM Thread Starter
WildBillinTN
1978 CJ5
It looks like the diagram I need but it won't let me click on the image to enlarge.
Originally Posted by littletoes View Post
This might help?
!978 CJ-5 304
post #6 of 13 Old 07-24-2019, 08:11 AM
Que89YJ
Computer, right click, save as, and open saved file.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 13 Old 07-24-2019, 05:24 PM Thread Starter
WildBillinTN
1978 CJ5
I tried that. For whatever reason all the text is pixelated beyond reading. I'll check google. Thanks for all the help everyone.
!978 CJ-5 304
post #8 of 13 Old 07-24-2019, 08:48 PM Thread Starter
WildBillinTN
1978 CJ5
I found this link that has been pretty helpful:
https://www.jedi.com/obiwan/jeep/instclust/
!978 CJ-5 304
post #9 of 13 Old 07-24-2019, 10:54 PM
Que89YJ
I can get you the factory manual tomorrow. PM me
Sent from my SM-G955U using Tapatalk
Fault codes:
No Start:
Que89YJ is offline
post #10 of 13 Old 07-24-2019, 11:09 PM
littletoes
In order to post them to be able to read larger, I would have to take "snips" of it, then post those.
It would be fairly cut up, but I can do it if needed??
post #11 of 13 Old 07-25-2019, 09:20 AM
V8orBUST
V8orBUST's Avatar
There is a 2 prong with a pink wire for the courtesy lights and also a single wire connector for the door jam switch if I remember correctly. Just installed courtesy lights myself on the short bus and the left side has a 3 pin connector, the right has a 2 pin. I could be very wrong.
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #12 of 13 Old 07-25-2019, 02:04 PM
LumaWJ
This is corect
WildBillinTN likes this.
JGC 4,7l
Wrangler YJ
LumaWJ is offline
post #13 of 13 Old 07-25-2019, 09:39 PM Thread Starter
WildBillinTN
1978 CJ5
Thanks for the offer but I think I got what I needed from your picture and googling what I couldn't make out. Great info!
!978 CJ-5 304
