how to tell gear ratio by the ring gear - JeepForum.com
post #1 of 7 Old 08-14-2006, 08:39 PM Thread Starter
YJscott2
Guest
how can you tell the gear ratio by the ring gear. can u multiply the nubers or what
im goin to pick up a front end and the guy dosnt know what gears it has.
YJscott2 is offline
post #2 of 7 Old 08-14-2006, 08:44 PM
TSEJEEPERS
TSEJEEPERS's Avatar
divide the number of teeth in the pinion gear by the number of teeth in the ring gear.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 7 Old 01-10-2010, 01:47 PM
Howiedooit
I believe it's the other way around, ring/pinion= ratio
Howiedooit is offline
post #4 of 7 Old 01-10-2010, 01:49 PM
Fhajad
Fhajad's Avatar
Why don't you just spin the wheel and count the drive shaft turns?
It's kind of easy.
Fhajad is offline
post #5 of 7 Old 01-10-2010, 01:55 PM
Why J?
Why J?'s Avatar
There are numbers etched into th ring gear it self. I believe they are after the part number, it wil lbe a number - number. Divide the first number by the second and that is your ratio.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #6 of 7 Old 01-10-2010, 02:18 PM
postaldave
postaldave's Avatar
Jack up the rear end. Count driveshaft revolutions while rotating the tire. Turn the tire 2 complete rotations if your other tire remains stationary and does not rotate. Turn the tire 1 complete rotation if the other tire turns in the same direction. The number of times the driveshaft rotates equals the gear ratio. If the driveshaft rotates about 3x, the gear ratio is 3.07. If it rotates 3 3/4 turns, the gear ratio is 3.73. You can mark the driveshaft to help you count.
tape a string onto the driveshaft if you want to make it fool proof
postaldave is offline
post #7 of 7 Old 01-10-2010, 07:30 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
I had an axle with a tag saying 3.07 on the front when I got the jeep and I popped it open and it was 3.07!
I did a spin on the rear and calculated 3.73 but the darn tag said 3.07. Popped the cover and it was an aftermarket pinion gear with 3.73.
Since then, when I buy axles at yards, I ignore all tags and pop covers and read the rings.
The guys are saying read the ring gear. It will not always just say 3.07 3.73 or 4.1 on it. It will say something like "41 10", or 41 ring gear teeth and 10 pinion gear teeth, or 41/10 = 4.10. Or.."41 11"...41/11 = 3.73...etc
hotelconucc93 is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
(D30) new ring gear bolts won't fit into new ring gear sportcoupe TJ Wrangler Technical Forum 14 08-21-2010 02:10 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 09:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
