How to remove sway bar end links? - JeepForum.com
 4Likes
  • 1 Post By Awesome
  • 1 Post By JarheadAl
  • 1 Post By Awesome
post #1 of 15 Old 04-02-2020, 05:13 PM Thread Starter
JarheadAl
What is the best way to remove them?
JarheadAl is offline
post #2 of 15 Old 04-02-2020, 05:20 PM
RockWoRM
RockWoRM's Avatar
PB blaster and a pickle fork. (bushing doesn't look new so no worries there) or put a nut on the stud and tap it out. Even a pitman arm puller might work if you can get enough meat to grab on the sway.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #3 of 15 Old 04-02-2020, 05:24 PM
Awesome
Awesome's Avatar
With a sawzall.
Or you can unbolt the bushings on the frame and pull the whole thing off in one piece.
You can use a torch or a plasma cutter too, just be careful about where the sparks are going.
The 4th 5-seater YJ in the world.
Awesome is offline
post #4 of 15 Old 04-02-2020, 06:32 PM Thread Starter
JarheadAl
Rockworm, I like the pickle fork idea. I have whacked it with a 3lb hammer, with the nut on. It didn't care.
Awesome, would you cut between the away bar and the bushing? Then you would still need to drive out what is in the sway bar? Am I understanding you correctly?
post #5 of 15 Old 04-02-2020, 11:44 PM
Awesome
Awesome's Avatar
No, I'm saying junk the whole thing.
bruinjeeper likes this.
Awesome is offline
post #6 of 15 Old 04-03-2020, 12:02 AM
04TJ-jeeper
04TJ-jeeper's Avatar
the more you look around the forum the more you'll notice most of us have junked the whole sway bar. awesome's post is spot on, if you're absolutely committed to saving your sway bar lots of PB blaster, let it sit. or heat and cool repeatedly to expand and contract the metal to break it free
1987 YJ 4.2 / 1990 YJ 4.2 / 1995 YJ 4.0 / 2014 JKU / 2019 JLU
04TJ-jeeper is offline
post #7 of 15 Old 04-03-2020, 06:51 AM
jbolty
jbolty's Avatar
the way to separate any tapered joint is to apply pressure and smack it on the side. hard. not a tap, a good whack with a big hammer. doing this to those joints in the vehicle will be impossible, there is no way to get a decent swing at it.
as for tossing the whole thing, that's a different discussion.
hit it here.
jbolty is offline
post #8 of 15 Old 04-03-2020, 11:46 PM
RockWoRM
RockWoRM's Avatar
Not knowing what lift if any he has, I purposefully did not say junk the whole thing. I am still of the opinion any lift over 3" needs the sways and disco's. I still would try some PB blaster and let soak overnight.
I also do not recall the sway link stud bolt being tapered? But then it's been a while.
RockWoRM is offline
post #9 of 15 Old 04-04-2020, 07:32 AM Thread Starter
JarheadAl
Thanks for all the replies. Work on the Jeep has been slow. My wife's grandmother died last weekend and there have been a few things that needed my wife's attention, which meant mine also. Work has also been slow and I'm not much of a mechanic, so I am learning as I go.
Installing a Rubicon Express 2.5" lift. My initial thoughts are to have it but I'm going to remove the when sway bar, remove the end links, drive it around the neighborhood, maybe around town some to see how it drives. Interstate driving is where I feel it may be necessary.
Awesome likes this.
post #10 of 15 Old 04-04-2020, 04:13 PM
Awesome
Awesome's Avatar
I have a 3.5" lift and I drive it at 75mph. Very stable. I'm not a stupid driver though.
No idea if the lift is actually 3.5" anymore.
Awesome is offline
post #11 of 15 Old 04-04-2020, 04:18 PM
RockWoRM
RockWoRM's Avatar
That means your springs aren't flexy enough to need a sway.
RockWoRM is offline
post #12 of 15 Old 04-04-2020, 04:20 PM Thread Starter
JarheadAl
Pickle fork for the win. About 12 whacks on each end did the trick.
post #13 of 15 Old 04-04-2020, 04:48 PM
Awesome
Awesome's Avatar
Pft.
Awesome is offline
post #14 of 15 Old 04-07-2020, 10:02 AM
RockWoRM
RockWoRM's Avatar
Pft.
Cool pic.
I'm betting the crossover steering helps a lot, too.
RockWoRM is offline
post #15 of 15 Old 04-07-2020, 11:56 AM
Awesome
Awesome's Avatar
Nah, but it does help my turning radius. Also helps control wheel hop in 4WD, and it increases HP.
Awesome is offline
