How does my compression test rate ? - JeepForum.com
post #1 of 10 Old 10-30-2013, 11:12 AM Thread Starter
krazybob
I have a '88 YJ with the 4.2 engine which has about 165K miles. I did a compression test the other day, and all of the cylinders were right at 130#. I did the check with all the plugs out and engine was cold. I'm wondering if the compression is in the bad, good, or other range? I don't know what a reading should be with an engine with this many miles should be.
Krazybob,, Mtn. Home, Idaho
My goal, is to die young,,
at a very old age
1988 YJ 4.2 5sp
krazybob is offline
post #2 of 10 Old 10-30-2013, 11:14 AM
bpounds
bpounds's Avatar
I think 130# is very good. And if they were all close to that, that is even better.
Bill
Jeepers drive high!
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #3 of 10 Old 10-30-2013, 11:53 AM
Diode Dynamics
Jeep Lighting Experts
Diode Dynamics's Avatar
2011 JK Wrangler
As long as it is consistent in all cylinders and your getting those numbers you should be ok!
This video is very helpful:
Welcome!
Nick C.
Your Source For Jeep Lighting
We provide the highest quality products around! check us out! >
Diode Dynamics is offline
post #4 of 10 Old 10-30-2013, 11:58 AM
remmons
remmons's Avatar
2015 KL Cherokee
I would be happy if all of the cylinders in my motor were all like that. The biggest thing to be concerned with is consistency. The numbers can all vary by up to 10%, anything more and the motor will need to be rebuild, re-ringed, re-gasketed, etc, what ever it took to bring them all back into range.
Robert.
remmons is offline
post #5 of 10 Old 10-30-2013, 12:42 PM
Siva283
Siva283's Avatar
Those numbers are great. Especially cold. The should raise a little when warm. From the factory they IIRC only 150 psi.
Ask me how I know...
Siva283 is offline
post #6 of 10 Old 10-30-2013, 08:38 PM
c5wagner
That's really good, mine are at 165 +or- 5psi but I'm rebuilt with .030 bored over stock
1989 Base YJ TBI 350, 4l60, Np231 SYE/6 pin planetary/Wide chain, D30 ARB, 8.8 ARB 4.56
c5wagner is offline
post #7 of 10 Old 10-30-2013, 09:15 PM
Old4X
1990 CJ7
Good numbers.
Check timing chain slack, replace gears and chain if over 6 degrees.
If you are feeling industrious, drop the pan and plastiguage the rod bearings. You want 2 1/2 to 3 thousandths clearance there (IIRC). The factory maint manual details inspecting the bearings and field clearance specs.
Properly treated, your engine is not at the half way point in it's life yet.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 10 Old 10-31-2013, 08:47 AM
jaycal3
jaycal3's Avatar
Nick,
Thanks so much for that video! That guy is awesome and made it really easy to understand both how and why.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #9 of 10 Old 10-31-2013, 09:23 AM
Diode Dynamics
2011 JK Wrangler
I'm always trying to learn more myself, having more learning resources never hurts!
Plus I like that guys laid back attitude lol
Nick C.
post #10 of 10 Old 10-31-2013, 03:49 PM Thread Starter
krazybob
Thanks a ton for the replies ! It always helps to go to the forum for info on the questions I have Now I won't have to wonder how my little 6 banger is doing
at a very old age
1988 YJ 4.2 5sp
krazybob is offline
