Hoops up front, outboarded rear - Page 4 - JeepForum.com
 40Likes
post #46 of 88 Old 06-26-2020, 08:11 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I just held them with my other hand.
bruinjeeper likes this.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is online now
post #47 of 88 Old 06-26-2020, 08:56 AM
bobracing
Just out of curiosity, are you going to move the bottom axle shock mount up too?
Helps clean up "grabber" things hanging below the axle.
92 YJ
https://www.jeepforum.com/forum/f22/open-mouth-insert-jeep-2878945/
bobracing is offline
post #48 of 88 Old 06-26-2020, 11:07 AM Thread Starter
bruinjeeper
bruinjeeper's Avatar
Already done
bobracing likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #49 of 88 Old 06-26-2020, 11:10 AM Thread Starter
bruinjeeper
Originally Posted by cpia84 View Post
im no expert by any means but I would assume c-clamps should hold them in place especially with the round flat spots on the bottom of the hoops. A ratchet strap would be another item i would try using.
Just curious do the hoops come with braces or do you need to make your own?
Probably going this route. I ain't as skilled or at least not as trusting as holding it in place manually while tacking with the free hand.
I was just wondering if they would hold... the hoops are imbalanced unevenly and hold some weight.
post #50 of 88 Old 06-26-2020, 08:29 PM Thread Starter
bruinjeeper
they come with the braces. I see no way of getting them welded with any confidence without pulling the fender inners. with all the crap i got mounted to them, i am gonna install without them and see how that goes initially.
SHould be fine for the 5 months until the jeep is retired from daily duties, then i can get them done properly with all the down time in the world.
post #51 of 88 Old 07-26-2020, 07:52 PM
V8orBUST
V8orBUST's Avatar
Ford shock towers
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #52 of 88 Old 07-27-2020, 06:53 AM Thread Starter
bruinjeeper
Life's been busy.
Still awaiting a good, free saturday to rent the welder and burn my new mounts in.
But as noted above, I went with the trail gear hoops. Where I am located... they were only a minuscule amount more. Plus they do add an element of mall crawler fashion... which is very important to me.
Azhunter1 and cpia84 like this.
post #53 of 88 Old 07-27-2020, 08:30 AM
jbolty
jbolty's Avatar
$54/pair
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jbolty is offline
post #54 of 88 Old 07-27-2020, 08:33 AM Thread Starter
bruinjeeper
Originally Posted by jbolty View Post
'Murican dollars.
In canadian monopoly money. . . . . .
The trail gear hoops costed me 80$ + tax in Monopoly moneys.
post #55 of 88 Old 07-31-2020, 05:57 PM
Louie4
Louie4's Avatar
1935 CJ2A
I like my Trail Gear hoops. I didn’t put the stiffening tubes in but probably should have.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #56 of 88 Old 09-28-2020, 08:03 PM Thread Starter
bruinjeeper
alright.
yup, bringing it back for future users.
i got the old shock towers cut off and most of the frame wall ground down... i was toying with the trail gear hoops in terms of fitment/placement. It gets might tight up there.
Essentially, to be safe, it seems the bottom most edge of the frame is where the lower most weld has to go in order to fit them in... anybody else find this? Did any of you massage the inner fender with a BFH or what?
(i do have a 1" body lift as well).
post #57 of 88 Old 09-28-2020, 08:43 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I think I was about dead center. But that’s with a 1” body lift and metal cloak fenders. I pushed them up till they touched.
post #58 of 88 Old 09-28-2020, 08:59 PM Thread Starter
bruinjeeper
metal cloaks would provide that extra space for sure.
BFH it is i guess. (it's cheaper)
87TPIYJ likes this.
post #59 of 88 Old 09-29-2020, 06:41 AM
NHfireLJ
NHfireLJ's Avatar
I went on top of the frame (different hoops) and trimmed the inner fender a bit to get some height but only because I'm using air shocks... When I ran the ford towers I just butted them up to the underside of the fender...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #60 of 88 Old 09-29-2020, 06:43 AM Thread Starter
bruinjeeper
Thanks for tuning in.
Yea. I'm gonna bust out the BFH tonight and try to get .75"-1" more clearance.
