high oil pressure on my YJ ! - Page 3 - JeepForum.com
post #31 of 34 Old 01-22-2010, 09:16 AM
Urb4nTr0ll
Originally Posted by PASKS View Post
to the brim means to the top of the full mark on the dipstick and you might be onto sometin here....i got a fram on there. but i was getting the exact same reading with a penzoil filter too.
i use Fram as well. Might try a Royal purple oil filter.
*I want a half hardtop for my Jeep.
*I'm starting to love my '90 Jeep.
*My Jeep does not get me laid, but who cares.
Urb4nTr0ll is offline
post #32 of 34 Old 10-15-2020, 08:05 AM
Bboarder711
yes I am digging this thread up from the grave.
3 years ago I had a breakdown as the oil pressure switch had a catastrophic failure and was spewing oil onto a hot exhaust (at highway speeds). At this time I had a local shop put in a new pressure switch, pan (rusty) and pick up. Since this my pressure as been around 60 (prior was 40). I drove it with no care and dismissed this to a properly working pressure switch. Recently It jumped to 80 with the occasional drop to 70. It is not pegged at max but vary close.
I have 125k, no leaks, original PCV with broken breather hose and some build up (nothing in airbox). I do also get code 51 but don't think my o2 sensor is related.
Thanks
- Rich
Bboarder711 is offline
post #33 of 34 Old 10-16-2020, 07:50 AM
fishadventure
fishadventure's Avatar
The gauge connectors in the cluster can lead to wonky readings.
Did you try a different oil pressure sender? Or verify with an analog capillary gauge?
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #34 of 34 Old 10-16-2020, 11:18 AM
Bboarder711
I have not done either.
- Rich
Oil Pressure.... too high? MikeyJ YJ Wrangler Technical Forum 13 05-09-2009 10:41 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 08:46 PM
high oil pressure Sunvista TJ Wrangler Technical Forum 5 07-22-2008 05:03 PM
High Oil Pressure Tom Kuhn YJ Wrangler Technical Forum 12 04-28-2007 08:14 AM
oil pressure high heapofjeep YJ Wrangler Technical Forum 9 03-14-2006 07:41 AM
