Help with Lifts - JeepForum.com
 7Likes
post #1 of 20 Old 07-08-2019, 09:22 PM Thread Starter
Skinard
Help with Lifts
I have a 1994 Jeep Wrangler YJ that I want to lift. I've read and read with no decision yet. I'm debating between a 2.5" or a 4" lift. However I can't find the information needed for 4" lifts as far as what modifications are needed to accommodate a 4" lift. Only information I have found is a longer driveshaft. Maybe one of you enthusiast can help me out with information? This will mostly be a trail rig, that being said the trail I wan't to go down is full of semi deep muddy puddles and the mud where I'm located really sticks to your tires.
Skinard is offline
post #2 of 20 Old 07-09-2019, 08:54 AM
Heepo
Heepo's Avatar
The general consensus is that a 4" lift will require a slip-yoke eliminator (SYE) conversion kit on the transfer case, and most likely a new rear driveshaft too.
'91 YJ w/ 4.0, AX-15, NP231J, OME 36Rs, 5/8" booms, BFG A/T 33s
Heepo is offline
post #3 of 20 Old 07-09-2019, 09:01 AM
Siva283
Siva283's Avatar
SYE always requires a new driveshaft since you will need one with a double cardone joint and your stock one is just a single. THe yokes are different as well
Ask me how I know...
Siva283 is offline
post #4 of 20 Old 07-09-2019, 11:03 AM
jhrebs
1987 YJ Wrangler
Other possible changes would be your steering(maybe just a drop pitman arm), linger brake lines. Both may come with lift kits. Not sure though.
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #5 of 20 Old 07-09-2019, 04:24 PM
Awesome
Awesome's Avatar
With a 4" lift you'll need to remove the track and sway bars, relocate your front brake lines and get a longer rear brake line. I got longer fronts AND relocated them, and it was kind of overkill.
As the others have said, you'll need a SYE and driveshaft, and a drop pitman arm. You'll probably want better shackles, as the stock ones are weak and you'll be putting more stress on them.
If you go spring over you can keep the stock springs and get 5" of lift. It'll flex nicely. You'll still need to do everything else, and add a anti-wrap bar.
EDIT: You'll need longer shocks.
The 4th 5-seater YJ in the world.
Awesome is offline
post #6 of 20 Old 07-19-2019, 04:03 AM
itsajeepthang86
itsajeepthang86's Avatar
I've put a 4" lift on two different YJs. The first thing I'd decide on is if you want to piece something together yourself, or go with a kit. There are plenty of kits available with some very budget friendly while others will give you higher end components. I've used the 4" kit from Rough Country and can't complain. It comes with everything essential for a lift including a drop pitman arm, transfer case drop, bracket relocations where needed, springs, and shocks.
You don't need a to replace the drive shaft with a 4" lift if you run the transfer case drop. However remember that with 4" of life, you will be putting the drive angles around what most would consider the max working angles. This means your DS is going to be a possible weak point, but is not something that is on the required list to simple get a lift on your jeep.
I would highly recommend extended brake lines, though you can get by with stock lines. It would mean adding a relocation bracket for the steel lines, and would still put a good bit of stress on the existing lines. For a few bucks you can find a set of stainless steel extended lines and they are worth every penny.
In short I'd recommend looking at something like the RC lift https://amzn.to/2XRTORD which you could use as a baseline for the minimum components needed. Here is a set of extended brake lines as well: https://amzn.to/2Ycp2SI
Remember these are minimums where cost is a factor. You can always get upgraded components as needed, but it will all come down to what you need vs what you want. Also as a side note, just know that with a 4" lift you are adding lots of stress to the different systems. Like any major change, it will end up showing you what is wearing out. Expect things like U-joints, bushings, misc mounts, etc. will wear out sooner rather than later so any lift you install might lead you chasing other repairs.
itsajeepthang86 is offline
post #7 of 20 Old 07-19-2019, 06:56 AM
Siva283
Siva283's Avatar
Run from Rough COuntry They are junk that ride like **** and you will be replacing springs yearly as they sag. Some people get lucky and they dont sag. Most dont. Look at BDS or Zone. Even Rubicon Express however I cant recomend them anymore. My RE springs flex great but on the highway they are rough riders
Awesome and bruinjeeper like this.
Siva283 is offline
post #8 of 20 Old 07-19-2019, 08:24 AM
bruinjeeper
bruinjeeper's Avatar
I still think piecemealing your components is the best bang for buck.
And you get exactly what you need (and should want).
4 BDS 3.5" springs, 4 correctly valves and sized Bikstein 5100 shocks, .25" lift Currie Greasable boom shackles with hardware and bushings, SS Currie longer braided brake lines and a u bolt flip from the junkyard didn't cost me an arm and a leg and they are some pretty higher end products. I think I paid $200 more than a crappy kit which includes a lot of components a kit from rough country would include that are not required just to sucker you in.
I am pleased with my suspension.
Edit: I should also note that I am in Canada. All of these components listed will cost you much less when your in the US.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #9 of 20 Old 07-19-2019, 09:39 AM
Awesome
Awesome's Avatar
Seconded.
You can look all over this forum (and the TJ forum) and people will tell you to stay away from Rough Country.
EDIT: It's no longer common, but my Jeep had a Superlift kit on it when I bought it. The only thing left from the kit are the bump stop extensions and the springs themselves. The springs are at least 12 years old now. I wouldn't be surprised to learn they are actually 24 years old. They still flex and are even on all four sides. If they've sagged, they've done so evenly.
bruinjeeper likes this.
Awesome is offline
post #10 of 20 Old 07-19-2019, 05:03 PM
bruinjeeper
Does anyone know if superlift still produces the Black Diamond springs?
Haven't looked into springs or whats out there in at least 5 years.
~YJOTM MAY '16~
~YJOTM JULY '19~
post #11 of 20 Old 07-19-2019, 08:22 PM
Boojo35
1987 YJ Wrangler
I would not put RC stuff on a riding lawn mower or a bicycle let alone a Jeep. Garbage. Bought my 94 roller with a brand new RC kit on it. Spring eyes on the shackle end sat on the frame rail at the rear of the vehicle. Poorly made. Wrong spring arches. RC has poor customer service. Pure crap. Let me add. These springs were brand new. Never hit the road. Just BS right out of the box. Worst stuff ever.
Have a very close friend that did a lot of RC installs for a "RC dealer" . He says the same thing. JUNK! Wait a while longer if money is the issue. Buy something better.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #12 of 20 Old 07-19-2019, 08:40 PM
itsajeepthang86
Too each their own
post #13 of 20 Old 07-19-2019, 08:50 PM
Boojo35
1987 YJ Wrangler
Yep. Glad for those who don't appreciate real world experiences. Try to help but carry on.
Boojo35 is offline
post #14 of 20 Old 07-19-2019, 09:01 PM
itsajeepthang86
You have your experience and I have my own personal experience with two separate kits. Neither have had the issues you described, but that doesn't discount others experiences.
post #15 of 20 Old 07-19-2019, 09:11 PM
Awesome
Awesome's Avatar
We're not knocking you, bud, we're going by general consensus. I'm glad your RC lifts have been good for you.
I'll probably end up with Old Man Emu or BDS when I get new springs.
Awesome is offline
