HELP! Jeep YJ RC Lifts - JeepForum.com
post #1 of 46 Old 04-16-2012, 12:19 PM Thread Starter
CMetry
I'm 18 and bought my first jeep. Now I'm looking into lift kits. My buddy with a cherokee bought a RC lift for his jeep and it looks and works great.
I have been reading a bit about Rough Country lifts. They have a 2.5 and 4 inch lift for my YJ.
Half the posts I read are negative and the other half are positive about their leaf springs. Some work great and some sag right away. A few years back their springs used to be really bad is what I've found out. They redid them and changed them a couple years ago after all the complaints and I was wondering if they have gotten any better.
I'm really low on money. I have a 2" body lift and a 1" shackle lift with 33s. I can fit 35s but they would rub a little bit. New fender flares are coming next so I'll trip a little and be able to fit 35s easy. but I want to get some sort of lift where I wouldnt have to trim at all and eventually work my way up to 37s.
Help me out with some of your opinions! It would be greatly appreciated.
CMetry is offline
post #2 of 46 Old 04-16-2012, 12:41 PM
flea2107
If budget is your main limit then trimming would be the best way to go. Lifting a YJ is not as simple as just putting a lift under your Jeep. You will need to, at some point, buy a SYE, CV driveshaft and if your lift kit does not come with all the other accessories, then you could be buying new links, brake lines, steering components and maybe some other things. Some of the fender kits leave enough room for 35's on a stock jeep, with trimming being part of the install. Either way lifting a YJ 2-4" is not cheap by any means and if you try to save by not doing the entire job at one time, you could be replacing parts faster than you can save for new ones. Start with trimming and get your jeep set with tires and all then lift it once you have the complete budget.
flea2107 is offline
post #3 of 46 Old 04-16-2012, 12:51 PM
giggityjeeper
the half that are positive, have no choice but to say good things, thye have it spent money on it, and now have to say its good......
it is the cheapest lift you can buy for a jeep..... that shold pretty much be self explanitory....
it is the bottom of the pile, YES there are MUCH better lifts and springs, if this is all you can afford, it will make a nice starter of budget build
you better do some research to get to 37, your gonna need more then lift springs, more like front and rear diffs, SYEs, etc....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 46 Old 04-16-2012, 12:58 PM
Siva283
Siva283's Avatar
^^^^X2 The man knows what he is talking about.
Siva283 is offline
post #5 of 46 Old 04-16-2012, 01:08 PM Thread Starter
CMetry
Yeah that is way down the road. I know you can't just throw 37s on there. Just taking it step by step.
CMetry is offline
post #6 of 46 Old 04-16-2012, 01:58 PM
YJeeper89
I got my 4" off of ebay, came with the new n2o shocks, and came with a drop pitman arm, and T-case drop, for 500 plus s&h. I've had it on for about 6-7 months, and she still sits somewhat level, other than the rear being a bit higher/stiffer for the added hardtop weight, which btw i have a soft top, no complaints so far, im running 33's with stock axles, planning on a SYE kit hopefully soon
1989 Wrangler Islander: SOLD
1999 Cherokee Sport: SOLD
1996 Cherokee Country project
YJeeper89 is offline
post #7 of 46 Old 04-16-2012, 02:43 PM
Jared24knapp
1987 YJ Wrangler
Just installed a 4" on my 87 2.5 depending on motor your going to
Need gears I did... Was planning on budget build but had to spend way
More right away then I planned on if I had to do it all again I would have trimmed and
Cut fenders for bigger tires and saved more to do it all right the first time
Have no complaints about the lift so far three wheeling trips down many more to go
Jared24knapp is offline
post #8 of 46 Old 04-16-2012, 02:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You're going to spend twice as much money by slowly stepping up to 37's than by making a solid plan to get them under your jeep. If the budget is the issue and you're thinking the springs are going to be the cost factor in the road to 35's you might want to reconsider your options. Giggity hit the nail on the head when he gave you a condensed list of upgrades to run with bigger tires. What's wrong with running 33's? What's your gearing at anyway?
Luck Favours The Prepared
Anticanman is offline
post #9 of 46 Old 04-16-2012, 02:50 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And to answer your initial question, folks are still swapping out their RC springs for quality and regretting throwing money in the wrong direction in the first place. You can get a OME kit for just about as much and don't have to fork over that lump sum all at once if you piece it together spring by spring.
post #10 of 46 Old 04-16-2012, 02:57 PM
Rynfw100
Rynfw100's Avatar
X2 on this. It's what I did. Except I did a Bastard Pack lift with 3/4 Ton springs, and they felt about as stiff as my neighbors 4" RC lift on his 90 YJ.
Give hotjeepparts.com a look. They're called 2.5" Medium-Duty OME Rear Lift springs. I got all 4 of mine for like $460 shipped. But then you have to buy bushings, which I got from a local AZ place.
My 5.2L V8 swap and Jeep build:
https://www.jeepforum.com/forum/f12/1993-2-5l-jeep-wrangler-build-5-2l-swap-1210512
Rynfw100 is offline
post #11 of 46 Old 04-16-2012, 03:09 PM Thread Starter
CMetry
I'm not sure on my gearing. What is the best way to find the ratio?
I like my 33s but the rears dont have very much tread. The welded rear axle is eating them driving around town. I'm going to need new tires eventually and my buddy has 35s off his TJ he said he would sell me.
CMetry is offline
post #12 of 46 Old 04-16-2012, 03:18 PM
deathtrap
Ive been running a rc 4" and 33s for around 3 yrs. It works for the type of Trails I run. (mostly mountan fire roads and moderate jeep trails) the kit was more complete then the more expensive kits when I bought it. I dont
have a s.y.e. but I spent a lot of time dialing in the drive line angles. Yes it is the cheapest spring lift for a yj, But you are installing on one of the cheapest model jeeps you can buy. Im trying to keep mine semi low buck while retaining good reliabiltiy. Hope this helps, just my experience.
deathtrap is offline
post #13 of 46 Old 04-16-2012, 03:18 PM
Rynfw100
Rynfw100's Avatar
Check the Axle Tag on your axles. Your ratio is either 3.07, 3.53, or 3.73.
Rynfw100 is offline
post #14 of 46 Old 04-16-2012, 03:34 PM Thread Starter
CMetry
Where is the Axle Tag? It's not on the diff cover is it?
CMetry is offline
post #15 of 46 Old 04-16-2012, 03:40 PM
Xpress
Xpress's Avatar
It should be fastened to one of the differential cover bolts.
'96 ZJ 5.2L, IRO 3.5" lift, KOR radiator support, MVF steering brace, IronMan 1 Ton
Xpress is offline
Jeep lifts when I jack trany up frankstopher TJ Wrangler Technical Forum 5 05-22-2011 12:09 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-27-2009 11:21 PM
Cheap Lifts on a Jeep? HELP! JCWrestler TJ Wrangler Technical Forum 6 06-06-2008 10:31 AM
New Jeep Owner - Advice on lifts needed dg512055 TJ Wrangler Technical Forum 12 05-31-2007 12:46 PM
Lifts for a NEW jeep owner O)||||||(O TJ Wrangler Technical Forum 15 03-04-2005 07:35 PM
