Help with hid's in a yj - JeepForum.com
post #1 of 6 Old 11-19-2012, 01:18 PM Thread Starter
jabor93
I recently installed projector headlights and hid's into my jeep. I got them working just fine, however the high beams do not work. The kit i got was designed for typical H4 headlight cars, and i guess they have seperate plugs for high beams and low beams. I was wondering if anybody knew where i could splice the wires from the high beam plugs to get the high beams working.
jabor93 is offline
post #2 of 6 Old 11-19-2012, 05:02 PM
SeanB95YJ
SeanB95YJ's Avatar
double-check to make sure you got the dual beam HID kit
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 6 Old 11-19-2012, 05:19 PM
ruggedlife
if you didn't get the dual beam kit they won't ever work. high beam comes from the same plug that goes right into the factory headlight. a dual beam kit will usually have two ballasts per headlight from the kits i have done in the past
ruggedlife is offline
post #4 of 6 Old 12-06-2012, 10:50 PM Thread Starter
jabor93
I did get the dual beams. I have two ballasts. The problem is that the normal connectors for the h4 kit is different from how my headlights connect.
jabor93 is offline
post #5 of 6 Old 12-06-2012, 11:13 PM
rodgers3
did you do the relay mod?
if not you should seriously consider doing it
your stock switch can't handle it.
and will burn out.
rodgers3 is offline
post #6 of 6 Old 12-07-2012, 10:52 AM
fratis
fratis's Avatar
dont look at a connector as a permanent or even a necessary thing. all connectors are just a convenience. you have to have a multimeter and know what each wire does. after this it will be obvious.
-insert meaningless out-of-place political diatribe-
fratis is offline
electronics , hid , lighting
