Help with brake disc ASAP - Page 2 - JeepForum.com
post #16 of 21 Old 08-18-2013, 10:28 PM
bigbossd1030
bigbossd1030's Avatar
Originally Posted by jtv135
When in the air the rim and brake rotor rock. Nothing else moves. The studs don't move the hub assembly doesn't move and the brake caliper doesn't move.
Does it move at the balljoints then?
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #17 of 21 Old 08-18-2013, 10:29 PM
bigbossd1030
Oh wait, I see what you are saying. Try a different tire on that axle. Maybe the rim is messed up?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #18 of 21 Old 08-18-2013, 10:30 PM
bigbossd1030
And also try the other rotor.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #19 of 21 Old 08-18-2013, 10:33 PM Thread Starter
jtv135
1987 YJ Wrangler
You know the rim being damaged isn't something I actually thought about. It is very possible as it rode several miles with damaged and missed wheel studs. I will check that tomorrow and see
jtv135 is offline
post #20 of 21 Old 08-28-2013, 02:26 PM Thread Starter
jtv135
1987 YJ Wrangler
Just wanted to let y'all know that I did find the little issue that was causing the wheel to rock. My inner brake pad was bent therefore not allowing the brake rotor to sit fully against the wheel hub. Went ahead and put fresh pads on both sides. Backing to running like a champ now
jtv135 is offline
post #21 of 21 Old 08-28-2013, 05:31 PM
bigbossd1030
Good to hear!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
