Help with brake disc ASAP - JeepForum.com
post #1 of 21 Old 08-18-2013, 02:13 AM Thread Starter
jtv135
1987 YJ Wrangler
About a month ago my front passenger wheel snapped all 5 lug nuts and blew a hole in the brake rotor. I replaced the hub assembly and the brake rotor. I know the rotor will be loose until the lug nuts are tightened on the rim which holds it all together. My issue is when I tighten my lug nuts all the way down and jack the jeep back up my wheel rocks. I can't find anything loose nor missing. Any help greatly appreciated.
jtv135 is offline
post #2 of 21 Old 08-18-2013, 02:18 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
How does your wheel rock? If you held the wheel at 3 and 9? Or 12 and 6?
Michaelgoesrawr is offline
post #3 of 21 Old 08-18-2013, 02:25 AM Thread Starter
jtv135
1987 YJ Wrangler
Rocks at 12&6
jtv135 is offline
post #4 of 21 Old 08-18-2013, 04:23 AM
SeanB95YJ
SeanB95YJ's Avatar
sounds like in the process of blowing out the rotor, you MAY have boogered up the unit bearing and/or ball joints
got any pics of what's going on around there?
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #5 of 21 Old 08-18-2013, 08:16 AM
Michaelgoesrawr
I'd say its the wheel bearing.
post #6 of 21 Old 08-18-2013, 08:55 AM
superj
superj's Avatar
Me too
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 21 Old 08-18-2013, 09:00 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Wheel bearing = hub assembly. OP says he replaced it.
You should tighten the lug nuts with the tire in the air, then torque to final spec when its on the ground, not sure if you're doing that. When the wheel rocks, look closely. Do the lug nuts and studs move with the wheel? Or not? If they don't, then your issue is likely that the studs are too long and your lug nuts are not tightening on the wheel but instead bottoming out on the studs. This of course assumes you don't have open lug nuts.
Pictures would help us diagnose a lot easier. Take pics of everything.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #8 of 21 Old 08-18-2013, 07:10 PM Thread Starter
jtv135
1987 YJ Wrangler
When I first noticed the issue I thought it was that when I put the lugs into the hub assembly that I just didn't get them seated completely. Then realized I had bottomed out the lug nuts. I went through 2 sets of lug nuts. So I know they are not bottomed out. I have disassembled everything again to make certain the studs were seated completely in the hub assembly. Got it all back together the other day and same issue. I will try and get some pics to show y'all tomorrow.
jtv135 is offline
post #9 of 21 Old 08-18-2013, 08:07 PM
TSEJEEPERS
TSEJEEPERS's Avatar
A picture of your wheels would help too.
Personally I use open ended lug nuts.
I am a little confused where you say "you put the lugs into the hub".
Did you get a new unit bearing or are you trying to rebuild the one you had before?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #10 of 21 Old 08-18-2013, 09:50 PM Thread Starter
jtv135
1987 YJ Wrangler
I put studs on the hub not lugs. Got a little ahead of myself in writing
jtv135 is offline
post #11 of 21 Old 08-18-2013, 09:51 PM Thread Starter
jtv135
1987 YJ Wrangler
I replaced the original hub with a new assembly
jtv135 is offline
post #12 of 21 Old 08-18-2013, 10:04 PM
bigbossd1030
bigbossd1030's Avatar
Is the hub seated on all the way? The three bolts torqued on? I would guess the ball joints might be buggered up. If everything else is new and installed properly.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #13 of 21 Old 08-18-2013, 10:18 PM Thread Starter
jtv135
1987 YJ Wrangler
Yeah everything is bolted on properly and torqued down.
jtv135 is offline
post #14 of 21 Old 08-18-2013, 10:20 PM
bigbossd1030
Does it rock when it's in the air? I would jack it up and rock it to see where the movement is actually coming from, like mentioned above. That's the only way to tell.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #15 of 21 Old 08-18-2013, 10:27 PM Thread Starter
jtv135
1987 YJ Wrangler
When in the air the rim and brake rotor rock. Nothing else moves. The studs don't move the hub assembly doesn't move and the brake caliper doesn't move.
jtv135 is offline
