Help !!! 6 lug rear axles - JeepForum.com
post #1 of 8 Old 04-25-2002, 10:07 PM Thread Starter
rollinashortysahara
Guest
what are some good 6 lug rear axles?
that are on cars i herd the toyotas have beefy axles but like something with a semi narrow dana 60 thats 6 lug?? or what should i go for??
i want junkyard swaps i don't have the money for costom stuff
rollinashortysahara is offline
post #2 of 8 Old 04-26-2002, 05:24 AM
Atropine
Atropine's Avatar
I think some of the dana 44's are 6 lug, when I was looking to swap my rear end a lot of people told me that I would have to get new wheels with it, which is part of the reason I'm going with the 8.8
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 8 Old 04-26-2002, 05:26 AM
Atropine
Atropine's Avatar
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #4 of 8 Old 04-26-2002, 05:35 AM
Bob J
Bob J's Avatar
1984
An early '80s Wagoneer had a D44 in the back with a 6 on 5.5" bolt pattern.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #5 of 8 Old 04-26-2002, 06:13 AM
RodeoRob
RodeoRob's Avatar
Full size jeeps, Isuzu, Toyota, and Chevy all use the 6 lug pattern.
toyota rear axles are good and beefy, but i think closer in strength to a D44 than a D60. They do make full float conversion kits for them, they're drop out style 3rd members, and of course, factory available electric lockers.
Another thing to consider if you're looking for something a little more than a D44... Isuzu used a corp 12-bolt axle (no its not GM, this is Isuzu corp) thats compairable in strength to a D60/Ford 9". Its got a 9.6" ring gear, removable 3rd member, 6 lug, I believe it would be about 60" wide, comes stock with 4.56 gears, and ARB makes an airlocker for it.
If you don't mind 6-lug, another good choice is the Isuzu D44. Found on the rears of any Rodeo/Passport after 93. 58" wide, disc brakes, 4.10 or 4.30 gearing, many have factory LSD.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #6 of 8 Old 04-26-2002, 06:31 AM
V8wrangler_idaho
rear toyota axels are more or less a dana 40. I looked that one up a long time ago.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #7 of 8 Old 04-26-2002, 06:41 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
1987 - 1991 Grand Wagoneers had 60" wide D/44's front & rear. Early 80's had an AMC 20 with factory one-piece axles and thick axle tubes and is also a great axle to swap in.
Steve
OldJeepguy is offline
post #8 of 8 Old 04-29-2002, 10:15 AM Thread Starter
rollinashortysahara
Guest
see i have the front dana 44 out of a wagoneer i'm just looking for a good match (the rear wasa a dana 20 on that wagoneer ) all the dana44 rears i found in that yard were offset thanks a ton for the info i have known about the isuzu dana 44 and the toyotas i didn't know the strength of them i would have went with the 8.8 if i didn't finf this dana 44 for $170 i figured hey can't beat that any where so i picked it up i want to find a 4runner axle (toyota 8") with 4.30 or 4.56 gearing with the electric lockers damn that would be nice ( no gear changine or locker installation bill)
i know how to do alot of work but re-gearing isn't one of them ( unless is third member style like the yota axles and the 9" fords )
YJ rear gears/axles in TJ? haubstr TJ Wrangler Technical Forum 2 05-15-2008 08:30 PM
rear axles DirtyJeep95 YJ Wrangler Technical Forum 5 04-01-2008 08:42 PM
rear axles yj JUSTWRIGHT57 YJ Wrangler Technical Forum 4 11-13-2007 06:48 PM
Tj Rear Axles?? jeeps4life TJ Wrangler Technical Forum 10 01-23-2005 10:30 PM
Rear driveshaft change when changing rear axles? skifast1 TJ Wrangler Technical Forum 7 12-23-2004 08:36 AM
