Heater Core Flush Question - JeepForum.com
post #1 of 9 Old 02-06-2008, 09:58 PM Thread Starter
Jeebs
2015 JK Wrangler
I searched and have the Hayne's open...
Trying to flush my heater core and wanna make sure I'm not doing this wrong. I have the hoses disconnected and am trying to run water through with zero going through - all coming right out same line.
Question is does the it need to have the key in the 'on' position or have anything set on the heater control panel before hand or should it always pass through.
Thanks in advance
Jeebs is offline
post #2 of 9 Old 02-06-2008, 10:01 PM Thread Starter
Jeebs
2015 JK Wrangler
Nevermind! I got it....just needed a little umf to get it through!
Jeebs is offline
post #3 of 9 Old 02-15-2008, 10:49 PM
redhatman
redhatman's Avatar
So you didnt need anything on? Just disconnected both lines that are parallel, and ran the hose through them? What came out?
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #4 of 9 Old 02-15-2008, 10:52 PM Thread Starter
Jeebs
2015 JK Wrangler
Yep. Disconnected the lines and ran the hose through until it was running clean. There was a lot of brownish fluid and some chunky stuff. I am thinking it was all for nothing though. Now that I have everything reconnected I am getting coolant on the passenger floor board so I think I have a blown core.
Jeebs is offline
post #5 of 9 Old 02-15-2008, 11:00 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yep, sounds as if you have a bad core Jason. Maybe just bypass it for the time being. Tell the lady to put on another sweater/jacket & you'll be okay.
Joe Dillard is offline
post #6 of 9 Old 02-15-2008, 11:00 PM
redhatman
redhatman's Avatar
That sucks man...I hear the core on those is a PITA. How much coolant did you need to re-add? Do you have a very hot heater now?
-Pat
post #7 of 9 Old 02-15-2008, 11:02 PM
Joe Dillard
BTW: Have fun during the new lift kit install party when it arrives. I saw you got a super deal on it!
post #8 of 9 Old 02-15-2008, 11:11 PM Thread Starter
Jeebs
2015 JK Wrangler
Actually, I heard its really easy on the YJ. Something like 4 or 5 bolts and it comes right out. I heard a TJ is a royal PITA. Gotta pull apart the entire dash, steering column, etc...
Jeebs is offline
post #9 of 9 Old 02-16-2008, 06:34 AM
timatoe
timatoe's Avatar
Yeh, it's not that bad. I replaced mine about a month ago in under an hour. Of course it's the second time I had that out, about a year ago I replaced the fan motor. From the engine bay, unplug the fan motor and disconnect the drain hose and take off four nuts. Insides disconnect the three cables going to the housing and pull it out. Open the housing and swap it out. Not too bad. Be carefull putting the housing back in to make sure you don't pinch the wiring for the computer, strange things start happening after that.
timatoe is offline
heater core flush help mgaither0 TJ Wrangler Technical Forum 3 01-12-2010 07:18 PM
Correct way to flush your heater core! Bubba3200 TJ Wrangler Technical Forum 1 01-08-2010 11:28 AM
heater core flush, write up?? jakecarder TJ Wrangler Technical Forum 2 01-09-2009 07:50 PM
heater core reverse flush badmystur YJ Wrangler Technical Forum 8 12-21-2008 12:45 PM
Flush The Heater Core???? gtospeeding TJ Wrangler Technical Forum 3 05-28-2008 11:51 AM
