Heater core. - JeepForum.com
post #1 of 6 Old 12-02-2007, 06:59 PM Thread Starter
jaminb
Heater core.
Can i flush my heater core with out taking it out? if so can yo tell me where to find the hoses to do it?
jaminb is offline
post #2 of 6 Old 12-02-2007, 07:02 PM
jeeepguy
jeeepguy's Avatar
The two hoses that are just inboard of the battery that are going into the firewall are the heater hose feed and return.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #3 of 6 Old 12-02-2007, 07:06 PM Thread Starter
jaminb
so i dont have to take it out to flush it? just drain about a gallon of coolant? i have a/c in my jeep so its a huge pain to get at the heater stuff.
jaminb is offline
post #4 of 6 Old 12-02-2007, 07:10 PM
jeeepguy
jeeepguy's Avatar
Yea, you can flow pressurized water thru it. Do it both ways several times to loosen up any crud. Be warned that flushing that unit CAN cause it to become plugged rather than cleaning it... just an FYI.
BTW, having the AC there is no big deal... I've done it several times.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #5 of 6 Old 12-02-2007, 07:56 PM Thread Starter
jaminb
well ill try that first. it it gets clogged then ill just replace it.
jaminb is offline
post #6 of 6 Old 12-04-2007, 02:22 PM
jeepross
just make sure that you reverse flush it, as in, the opposite way it flows, all the crud will come out, i had no heat last fall due to this issue, thought i was going to have to replace the heater core, took it to a shop and had them do a reverse flush, the contents that came out was quite dramatic, however, i now have lots of heat!
jeepross is offline
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
heater core lilmike386 YJ Wrangler Technical Forum 2 08-24-2009 07:03 AM
Heater Core (I think) DrumBat YJ Wrangler Technical Forum 8 08-05-2009 02:18 AM
Heater Core Help stu1021 YJ Wrangler Technical Forum 4 08-03-2008 02:11 AM
heater core O2BTOM TJ Wrangler Technical Forum 4 11-10-2006 09:41 AM
