Headlights... hi beams work, lows do not. - JeepForum.com
 3Likes
post #1 of 25 Old 08-12-2019, 05:19 PM Thread Starter
BChamberlin
BChamberlin's Avatar
Just put in a new switch, no change. I can’t really believe both headlight low beams are bad but then again, I just got this thing a couple days ago.
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #2 of 25 Old 08-12-2019, 06:43 PM Thread Starter
BChamberlin
Read it could be the dimmer switch. I see where it is under the dash. Damn, what a tough spot. Any suggestions for reaching this?
I hate chasing ghosts. Never mind repairing stuff but damn I’ve been on a bad streak lately with stuff going wrong that’s not easily identified.
1994 Wrangler YJ
2008 Wrangler X
post #3 of 25 Old 08-12-2019, 08:41 PM
bruinjeeper
bruinjeeper's Avatar
Do you have a multimeter?
Is power going to the headlights when low beams are on?
Siva283 likes this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
post #4 of 25 Old 08-13-2019, 05:44 AM Thread Starter
BChamberlin
I do have one but I’m not the most experienced with using it.
1994 Wrangler YJ
2008 Wrangler X
post #5 of 25 Old 08-13-2019, 06:04 AM
Siva283
Siva283's Avatar
Set it to 12v DC turn your head lights on. Put the black lead on battery negative and put the red lead on the socket that the tabs for the bulb go. You should have 12v on one. One is ground one is low beam power and one is high beam power. If you have your lights on and set to low mean you should see 12v on one of the 3 spots.
Ask me how I know...
Siva283 is offline
post #6 of 25 Old 08-13-2019, 06:05 AM
Siva283
Siva283's Avatar
I was about to ask the same till I saw this. My multimeter has become one of my best friends
1project2many likes this.
Siva283 is offline
post #7 of 25 Old 08-13-2019, 11:26 AM Thread Starter
BChamberlin
So just turn the low beams on, pop the good and stick a voltmeter on the headlight terminals?
1994 Wrangler YJ
2008 Wrangler X
post #8 of 25 Old 08-13-2019, 01:06 PM
bruinjeeper
Siva explained it above. Ground out the black wire on your multimeter. Try it in all three wire ports at the headlight if you don't know which colour feeds low beam into the headlight
~YJOTM MAY '16~
~YJOTM JULY '19~
post #9 of 25 Old 08-13-2019, 01:13 PM
Siva283
Siva283's Avatar
Turn on the low beams. Set the meter to 12v DC stick the black probe on battery ground use the positive to probe the 3 contacts in the socket. 1 of them should have 12v with the low beams turned on. The dc symbol is usually a solid straight line over a dotted straight line
Siva283 is offline
post #10 of 25 Old 08-13-2019, 01:25 PM Thread Starter
BChamberlin
Thanks. I'll do this when I get home.... er I mean tomorrow. Tonight is the Aerosmith concert with my kid.
bruinjeeper likes this.
1994 Wrangler YJ
2008 Wrangler X
post #11 of 25 Old 08-13-2019, 07:21 PM
jbolty
jbolty's Avatar
has anyone suggested a voltmeter?
jbolty is offline
post #12 of 25 Old 08-13-2019, 07:49 PM
bruinjeeper
...amazing idea.
That's why you're mod, bruh. Lol
~YJOTM MAY '16~
~YJOTM JULY '19~
post #13 of 25 Old 08-13-2019, 08:19 PM
fishadventure
fishadventure's Avatar
There’s the thing. If no power at the headlight prongs when the headlights are on low beam then it’s possible the switch is bad, but also possible something is unplugged/poor contact, or it’s the adjustment/length of the rod from stall to switch under the column.
I had a switch go bad once. I jumpered things under dashboard so I had low beams on the high beam output to get by. (I was swapping body/tub out soonish at the time and that “fixed it” for me
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #14 of 25 Old 08-15-2019, 05:27 PM Thread Starter
BChamberlin
Well, if I did this right, and keep in mind I have as much experience with a voltmeter said I do walking on the moon, I got a reading of around 12 point something with the hi beams (switch on, lights on). I get a big fat zero with the lo beams (switch on, no lights). I’ve already replaced then light switch itself. Could it be the dimmer switch? That thing looks like a pain in the bean bag to replace.
Sent from my iPhone using Tapatalk
1994 Wrangler YJ
2008 Wrangler X
post #15 of 25 Old 08-15-2019, 05:59 PM
Siva283
Siva283's Avatar
when you tested low beams you checked the other 2 prongs right? It won't have power on the same one the high beams are on. Your next step is to see if you have power coming out of the switch. If you have power there you then check at the dimmer on the column under the dash. Your actual on off switch is very common to go bad. If you need a new one It's called a rheostat
Siva283 is offline
