Head Gasket Replacement - JeepForum.com
post #1 of 30 Old 01-03-2010, 07:47 PM Thread Starter
PrinothPro
So some of you guys seen my earlier post about milky oil. I have a blown head gasket for sure. :
Can you guys please tell me where I can find a good parts for the new gasket and head bolts. The engine is only 20,000 miles old since it got rebuilt in 2002. I dont know if the bolts are reused or new. I want to get new ones anyway.
I have Borla headers, do I need to get new gasket for it too since I have to take that off too.
Do anybody want to come over and help me replace the gasket? I have a case of beer!
PrinothPro is offline
post #2 of 30 Old 01-03-2010, 08:14 PM
4.7stroker
4.7stroker's Avatar
Use a felpro gasket set, that should come with everything you need.
I have no problem reusing head bolts and have done for 30 years as long as they are not TTY you are good. If you must get new head bolts use ARP. Make sure the head is not cracked or warped before you bolt it back on, a machine shop shouldn't charge much to pressure check the head.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 30 Old 01-03-2010, 08:14 PM
jsawduste
2006 YJ Wrangler
Hesco for all
jsawduste is offline
post #4 of 30 Old 01-03-2010, 08:25 PM
Gobi_Gred
Gobi_Gred's Avatar
1987 YJ Wrangler
I can tell you that Fel-Pro has never done me wrong in the gasket department. 25.00 at Napa
Getting new head bolt is a good idea. I can't find them at Napa online but you might be able to get them in-store
Yes you DO need a new intake/exhaust gasket. 21.50 at Napa
Gobi_Gred is offline
post #5 of 30 Old 01-03-2010, 08:29 PM
Gobi_Gred
Gobi_Gred's Avatar
1987 YJ Wrangler
This the seqence(sea-kwence) that the bolt are supposed to be tightened in the intake/exhaust. The numers I wrote on there are the torque specs. Iirc they are in ft/lbs EDIT: These nubers are for a 4.0 the order is probly similar not sure about the torque
post #6 of 30 Old 01-03-2010, 08:36 PM
jimdeere
Not to highjack, but should the head bolts be re-torqued after a run in period? I just re-did the head on grandaughter's 2.5 Wrangler, and I got conflicting advice.
jimdeere is offline
post #7 of 30 Old 01-03-2010, 10:42 PM
4.7stroker
4.7stroker's Avatar
I guess that would depend on the advice from the gasket maker.
The Felpro perma torque gaskets do not get retorqued.
Dwayne
[url]
[url]
post #8 of 30 Old 01-04-2010, 10:39 AM Thread Starter
PrinothPro
Thank you guys, The advices you gave me are very useful.
What about the valve cover, use RTV to seal it?
post #9 of 30 Old 01-04-2010, 11:32 AM
chargerhunter
You may want to spend the extra few bucks $30 or so and have the head resurfaced. Ask me how I know...
chargerhunter is offline
post #10 of 30 Old 01-07-2010, 01:08 PM Thread Starter
PrinothPro
Quick question, does blown head gasket make the jeep stall very often?
post #11 of 30 Old 01-07-2010, 01:11 PM
chargerhunter
Make it run hot and often water in oil. I have had them where they ran rough and pull a spark plug and water pours out..not a good sign......
post #12 of 30 Old 01-07-2010, 01:19 PM Thread Starter
PrinothPro
Hmm, the jeep do not run hot at all. The temp is perfect on the spot. When it is warmed up, it want to stall so badly and it stalls at any rpm. I still think I got blown head gasket but I am not too sure anymore
post #13 of 30 Old 01-07-2010, 01:37 PM
Que89YJ
Stalling is usually not a blown headgasket. Do a compression test and check to see if the oil is milky in color. A stall can be caused from a bunch of much simpler things.
Que89YJ is offline
post #14 of 30 Old 01-07-2010, 03:30 PM
MJMPC
MJMPC's Avatar
You have water in the oil blowen headgasket is about the only way water got there .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #15 of 30 Old 01-08-2010, 07:07 AM
chargerhunter
Check the plugs, take a pic and post after you pull one. You can tell alot by an engine by the color of the plugs. .
4.0L Head Gasket Replacement NamesMUD YJ Wrangler Technical Forum 8 07-26-2020 06:22 PM
head gasket and or head replacement hecubus TJ Wrangler Technical Forum 0 05-27-2008 12:22 AM
head gasket replacement ErnieG TJ Wrangler Technical Forum 2 01-27-2008 07:45 AM
Head Gasket Replacement? Jarvo2 TJ Wrangler Technical Forum 4 01-08-2007 11:18 PM
Head gasket replacement ckracing TJ Wrangler Technical Forum 3 12-11-2006 10:26 PM
