hardtop? - JeepForum.com
 4Likes
post #1 of 20 Old 06-01-2020, 08:57 AM Thread Starter
carlsflh
hardtop?
just picked up a hardtop for the yj going to refinish it before putting it on can't decide between paint or bedliner .which would hold up better and be easy to touch up? as far as color black ,tan or bright white. yj is bright red with red flairs. now it has a grayish/tan soft top anyone have a pic of a red yj with a white hardtop . i found lots of black and tan tops on red but no white ones .i was thinking white because of the hot sun here in N AZ
carlsflh is offline
post #2 of 20 Old 06-01-2020, 10:43 AM
bruinjeeper
bruinjeeper's Avatar
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #3 of 20 Old 06-01-2020, 12:26 PM Thread Starter
carlsflh
thanks bruin the first pic was just what i was looking for now to decide paint or bedliner . bedliner would be less prep work
carlsflh is offline
post #4 of 20 Old 06-01-2020, 05:15 PM
bruinjeeper
Depends on the bed liner.
Are you thinking off the shelf stuff?
post #5 of 20 Old 06-01-2020, 05:41 PM Thread Starter
carlsflh
one of the 2 part kits on line like this one https://www.ebay.com/itm/U-POL-Rapto...53.m1438.l2649 .
carlsflh is offline
post #6 of 20 Old 06-01-2020, 07:19 PM
Chrisnvegas
Chrisnvegas's Avatar
I wouldn't do bedliner unless you don't care how it looks. Spray paint for plastic works well.
Bedliiner fades really fast in the desert. White will probably be tough to keep clean with the heavy bedliner texture.
I would maybe consider Monstaliner, maybe.
Once bedliner is used, if you don't like it, of it turns out bad, good luck. It's a beeotch to remove.
You're going to put on a hardtop... in the summer?
A/C? Paint what ever color you want. While the top is off, install indoor/outdoor carpet inside for insulation and sound deadening. A bare hardtop a pretty noisy and hot in the sun no matter what color.
Using carpet and adhesive (the adhesive sticks really well to the rough fiberglass)
I only use my hard top in the winter. Didn't even use it last year. My Jeep is toasty with just the doors on.
Those eye-bolts look like crap. (sorry, but they do)
I have a home-made bracket that fits on the top for removal and installation with a winch. It's temporary. Then I have a small wheeled cart that the top stands up on so I can store it in the corner of the garage and wheel it around as needed.
I don't know if you're going to take the top on N off and store it, or if you will keep it on.
If you want to see the cart and removal bracket, just say so.
JoonHoss and TRob1 like this.
"Alferd Packer: “Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is offline
post #7 of 20 Old 06-01-2020, 07:24 PM
jay-h
I rattle canned mine flat black. Easy to redo (i've had it for 14 years) but part of that depends on what you want. It looks acceptable but not high end
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #8 of 20 Old 06-01-2020, 08:15 PM
Chrisnvegas
I've done both. Flat black and the black meant for plastic. It didn't list flat or gloss, just black.
It turned out to be a semi-flat. Not quite as flat, but not glossy either. It's probably my favorite now. Easy touch up and more durable than flat without the "ugliness" of full gloss.
I think we used 5 cans per top and we applied two coats.
post #9 of 20 Old 06-01-2020, 08:17 PM
bruinjeeper
Would that make it "Satin" Black, Chris?
Love it as well.
post #10 of 20 Old 06-01-2020, 09:00 PM Thread Starter
carlsflh
i wan't thinking about the bedliner stuff being a pain to clean. did you use krylon fusion ? eye bolts were already on it they are coming off soon .i wouldn't mind seeing a pic of the bracket and cart although once i put the top on i doubt it will come off very often[may and june maybe , july aug and sept is the rainy season in northern az] i do have ac
Chrisnvegas likes this.
carlsflh is offline
post #11 of 20 Old 06-01-2020, 10:22 PM
Chrisnvegas
Exactly, Krylon Fusion. That's what we used. I couldn't think of the name.
I've fought with Jeep tops for most of my life. Keeping them looking good.
I've tried most things including a roller! The roller almost worked well but the roller material started sticking to the top like a dog shedding!
Most bedliner material is not UV stabilized. Meaning, it fades.
If it were my top and would be on a majority of the time:
I would pick out a color of indoor/outdoor carpet that goes with the interior colors that I liked. I'd turn the top upside-down and glue it on. Now it's insulated and will be much quieter... and will look good. More comfy all the way around. Comfy is where it's at.
Then I cleaned the outside with Dawn and a scrub brush. Last, I used laquer thinner for a final cleaning.
The Krylon worked better than anything else so far.
I don't discount Monstaliner yet. I've read it's UV stable so it won't fade and comes in many colors.
Let's see if someone has used it. Maybe it's really good for tops?
I'll post pics here of the bracket and stand I made. Removing the top takes a few minutes by myself.
post #12 of 20 Old 06-02-2020, 03:38 AM
timatoe
timatoe's Avatar
If you do bedliner, use Monstaliner. I would not use Raptor, I've got a buddy that swears by it, yet his is flaking off in less than two years. My Monsta hasn't faded, chipped or peeled in pushing 8 yrs.
timatoe is offline
post #13 of 20 Old 06-02-2020, 04:18 AM
bruinjeeper
Agreed.
Not to mention more UV permanent and smoother texture (easier to clean) with a satinesque finish.
post #14 of 20 Old 06-02-2020, 06:04 AM
Chrisnvegas
Did you use it on your top?
Anyway to make it not glossy?
I'm thinking of getting it for my pickup bed, right now I have a plastic liner that is slippery. Good stuff?
post #15 of 20 Old 06-02-2020, 08:04 AM Thread Starter
carlsflh
what type of glue do you use for the carpet 3m spray Adhesive, contact cement or carpet Adhesive
carlsflh is offline
