(Hard) Labor Day - Body Mount Replacement! - JeepForum.com
post #1 of 7 Old 08-30-2019, 08:46 AM Thread Starter
KnuckleheadLabs
After a number of repairs to The General this summer, I've now been staring at a new set of body mounts sitting on my workbench for about 3 weeks. I think it's time. The mounts are OEM replacement height.
The old mounts are crusty. I'm going to make some cutouts on the tub and try to loosen things up with PB and a torch. The spot where the driver's side rearmost mount goes into the tub is completely gone, so I'll have to replace some steel there, and the mount up by the radiator looks shaky too. A couple of the captive nuts are loose inside the tub, so I may have to just punt and cut the bolts and pull it all out thru the tub.
Here's the rearmost mount; there should be some steel where the arrow points:
Here's the one by the radiator; that whole area around the mount looks a bit soft:
This is representative of the other existing mounts.... this is the one behind the seat.
My plan goes something like this: cut my way to the nuts under the seats and the rear, PB all the mounts for a day, and see what bolts will come loose with a torch and some muscle; I don't want to have to cut all of them and end up with the tub out of alignment. Once i can jack one side up the needed 2" or so to get the new mounts in I'll just have to see how it goes. The rearmost mount that where it used to fasten to the tub i figure i can insert some stock steel and weld it up after i drop the tub back down. The front mount I'll just have to see what needs fixing/welding after I get the old one out. One major concern I have is if I can't repair those two completely rotten mounts to my satisfaction, I'll have to install 9 mounts and take it to a shop to weld up the front bracket and the rear of the tub. Willing to hear opinions as to whether I'll be ok with those 9 mounts for a short trip to the shop if it all goes code red.
Mostly I'm looking for any advice & encouragement...The General is running real nice, except for the hard ride I think is the result of the worn mounts...sometime i feel like there's gonna be blood in my urine after a long ride. Shocks are not that old, and the springs are in good shape, although new shocks are in line after i fix these mounts.
On the other hand I could just enjoy the jeep for the long weekend and put this off another week. I'll see what kind of inspiration this post generates and maybe this afternoon I'll bust out the cutting wheel and a quart of PB Blaster. Cheers to all, best wishes for the long weekend!
KnuckleheadLabs is offline
post #2 of 7 Old 08-30-2019, 09:25 AM Thread Starter
KnuckleheadLabs
photo embed didn't work- attaching here if anyone interested
post #3 of 7 Old 08-30-2019, 10:03 AM
bruinjeeper
bruinjeeper's Avatar
Good luck. You gots some corrosion going on there.
My jeep is clean and I still have managed to break 4
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #4 of 7 Old 05-19-2020, 08:31 PM
Trjeeper
Trjeeper's Avatar
Did you fix the rust issues in the rear body mount and how did you do it? I have the same issue with a 95 YJ I just bought.
Trjeeper is offline
post #5 of 7 Old 05-19-2020, 09:28 PM
bruinjeeper
i didnt see anything in his photo. lol. nthing to fix when all the metal is gone.
fast forward to 4:52 of this video and check out this fix. LOL
post #6 of 7 Old 10-12-2020, 11:17 AM
GRM1230
GRM1230's Avatar
Any updates on how this went? I need to replace my front center body mount and one on the passenger side. Will know more about the drivers side, but want to get the passenger side sorted out first.
Sent from my iPhone using Tapatalk
GRM1230 is offline
post #7 of 7 Old 10-13-2020, 10:51 AM
Bboarder711
thanks for posting the video I am dreading this.
- Rich
Bboarder711 is offline
body mounts , YJ
