Greasable shackle bolts - JeepForum.com
 9Likes
  • 3 Post By jbolty
  • 1 Post By Waternut
  • 3 Post By Boojo35
  • 1 Post By fishadventure
  • 1 Post By jsawduste
post #1 of 15 Old 02-13-2020, 06:03 AM Thread Starter
jhrebs
1987 YJ Wrangler
I have 2” BDS springs. I have 1” lift boomerangs shackles made by a guy on JF. Don’t remember his name. Can I buy just the greasable bushings and bolts? Any specific size that I need?
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 15 Old 02-13-2020, 06:10 AM
paulhead
if it works fix it
paulhead's Avatar
Sure, google provides lots of options, be sure get the right size, I imagine they're 1/2", maybe 9/16"
Trying to weld has honed my grinding skills
paulhead is offline
post #3 of 15 Old 02-13-2020, 06:39 AM
jbolty
jbolty's Avatar
I went this route a few years ago and at the time I found it cheaper to get a whole set with shackles, bushings, sleeves and bolts. But, they are long gone. They clog, don't seem to help flex much and the fittings kept getting smashed. I just take them apart and grease once a year now.
bolts on frame side are 9/16. shackle side, 1/2
TSEJEEPERS, paulhead and NHfireLJ like this.
jbolty is offline
post #4 of 15 Old 02-13-2020, 06:56 AM
bruinjeeper
bruinjeeper's Avatar
As @jbolty pointed out... they will clog if not setup properly. Its finicky and tedious but you have to ensure you stick the greasable bolt through the sleeve in the orientation where the grease passage in the bolt lines up with the grease passage in the sleeve.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #5 of 15 Old 02-13-2020, 07:55 AM
paulhead
if it works fix it
paulhead's Avatar
I think I read somewhere they're weaker because of being hollow. I'd just get some good grade 8 bolts and light coat of white lithium grease on the bushings and you'll be fine.
paulhead is offline
post #6 of 15 Old 02-13-2020, 08:03 AM Thread Starter
jhrebs
1987 YJ Wrangler
Thanks guys
jhrebs is offline
post #7 of 15 Old 02-13-2020, 03:13 PM
Waternut
Waternut's Avatar
I noticed that my greaseable bolts were grade 5 and have a hole drilled in them for the grease. I don't think you really have to worry about them breaking unless you start jumping your jeep regularly or just totally neglect your suspension for many years. Grade 5 has a shear strength of 74000 psi minimum. If you do the math, the area of a half inch bolt is 0.2 which makes the shear strength of that bolt equal to 14,800 lbs and your 3-4k lb jeep is sharing that weight over 8 bolts (2 per leaf spring counting the bolts in the shackle as 1 since the load on the top bolt is basically the same as the load on the bottom).
That said... I have greaseable bolts on my jeep and they are so messy. I probably break a grease fitting every other wheeling trip as well and have yet to replace any of them so they've effectively become a heavily greased standard bolt. Just go to your local hardware store and buy some grade 5 or grade 8 bolts and called it a day. Grease everything up before you install it and you'll be golden.
jbolty likes this.
Waternut is offline
post #8 of 15 Old 02-13-2020, 05:46 PM
Boojo35
1987 YJ Wrangler
So. You live in California..... LOL.... Here in Michigan or other salt belt places, White Lithium grease is garbage. JS. Some good anti-seize compound may be a better answer.
paulhead, Siva283 and bruinjeeper like this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #9 of 15 Old 02-13-2020, 07:19 PM
paulhead
if it works fix it
paulhead's Avatar
Yeah I see the cancer you guys grow on your jeeps and it makes me cringe.
paulhead is offline
post #10 of 15 Old 02-13-2020, 08:04 PM
Awesome
Awesome's Avatar
Bersk is the guy that made your shackles.
The 4th 5-seater YJ in the world.
Awesome is offline
post #11 of 15 Old 02-14-2020, 07:16 AM
fishadventure
fishadventure's Avatar
I was thinking to myself, “ Isn’t white lithium grease for seat tracks and steering shaft cams?“
Golden grease or red long grain stuff survives in the salt belt. Blue is good too but it doesn’t seem to play as well with other greases like Gold and Red. No matter what the label compatibility days.
Plus, it’s good for wheel bearings, ujoints, everything.
White lithium can probably wash out of your shackles when your neighbor’s kid runs their dishwasher.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #12 of 15 Old 02-14-2020, 08:13 AM
mikewiz38
For what it's worth, I've read that greasable shackles aren't best because a lot of the chassis lube grease will make the rubber bushings expand and bulge. It's different if you use poly bushings. When I installed mine with rubber bushings, I ended up using the sil-glyde instead.
It worked well, but I do have creaks when I go over bumps slowly, IE: pulling over the curb in the driveway. I think it's the shackles and bolts, but I don't know for sure.
Maybe I should just fill them with chassis grease, maybe not. I just read that the petroleum based greases and rubber aren't a good mix.
1994 Wrangler YJ - 4.0L - 5 Speed
mikewiz38 is offline
post #13 of 15 Old 02-14-2020, 10:35 AM
fishadventure
Define “rubber” 🙂
I’ve wrecked a few fixed-end bushings that are impossible to ‘grease.’
I’ve been greasing YJ shackle bushings since 2014. That way stuff can be removed/serviced. Both ‘rubber’ and urethane. I did tear some up when I bent a shackle mount.
I suppose in 20 years grease might soften them. I’m thinking don’t worry about it. They’re cheap enough to change out.
paulhead likes this.
post #14 of 15 Old 02-14-2020, 02:03 PM Thread Starter
jhrebs
1987 YJ Wrangler
Yup. Thanks. I actually feel terrible for forgetting.
jhrebs is offline
post #15 of 15 Old 02-14-2020, 02:39 PM
jsawduste
2006 YJ Wrangler
You`re grounded.
Awesome likes this.
jsawduste is offline
