GenRight tank install - JeepForum.com
 15Likes
post #1 of 24 Old 10-19-2020, 10:03 PM Thread Starter
paulhead
paulhead's Avatar
Bought a GenRight gas tank (GST-4002) back in December and it was sitting in my garage until today. Man I think I procrastinate a little. Finally tackled it and wasn't too bad. Priority was to have a fore extinguisher close by and drain the tank best I could. Disconnected the battery ground. I cut and disconnected the filler and vent hoses because they were hard and shiny and decided to replace them. Bought one of these pumps and it worked ok, I don't think they're made for gas.
3-4 bolts front and back, I needed to bring down the tank a little less than a foot to get to the fuel lines, vent and electrical plug and unhook everything.
Trying to weld has honed my grinding skills
paulhead is offline
post #2 of 24 Old 10-19-2020, 10:16 PM Thread Starter
paulhead
paulhead's Avatar
Tank out, pulled the fuel pump. It looked fairly new, I think it had been replace before because of RTV around the pump, decided not to replace it. The fuel pump float was hitting the fuel trap inside the new tank, I decided to perform a little cosmetic surgery on it, also it was bottoming out a bit so I trimmed the return line and moved up the pump about a quarter inch. fit good.
New gasket
NHfireLJ likes this.
paulhead is offline
post #3 of 24 Old 10-19-2020, 10:38 PM Thread Starter
paulhead
paulhead's Avatar
So the instruction call for you to dry fit the tank so you can mark where to drill the holes in the frame. You'll be using the stock 4 bolts in the back but the front requires you mount thought the frame with 2 steel sleeves provided. It stated you can weld the sleeves in but I opted not to. They were snug and it was a tight fit, I just painted them.
Frikin dog thought it was play time every time I laid down on the ground.
Like a dolt I didn't take any measurements before pulling the tank but you can see the 8.8 was banging the skid pretty good.
The tank went in easy, bolted it in and looked good. I got some nice distance between the axle and skid now. I think I'll be able to come back a good 4"
I'll take some more pics when the sun comes out and I finish up the filler hoses. You're suppose to cut the hoses and add extensions I'm thinking of going to this mom and pops auto parts down the road and see if they have any hoses that'll work. I feel more comfortable with a one piece hose.
paulhead is offline
post #4 of 24 Old 10-20-2020, 02:11 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
You will want to get those sleeves welded for sure. That hole will elongate
paulhead and ThomasYJ like this.
YJUnlimited stretch, Links, SBC, Tons, Lockers, and stuff
March 2017 YJOTM/ 2017 YJOTY
87TPIYJ is offline
post #5 of 24 Old 10-20-2020, 04:41 AM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Wow. Fantastic.
I was wondering what you've been up to.
paulhead likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #6 of 24 Old 10-20-2020, 07:48 AM
Siva283
Siva283's Avatar
How many gallons is that tank?
Siva283 is offline
post #7 of 24 Old 10-20-2020, 09:14 AM Thread Starter
paulhead
paulhead's Avatar
Hmm, you had it happen?
paulhead is offline
post #8 of 24 Old 10-20-2020, 08:23 PM Thread Starter
paulhead
paulhead's Avatar
You got me thinking and you're right, pulled the tank back out and welded up the sleevs
The big filler hose fit just fine, went to the auto parts shop and found one for the vent line.
87TPIYJ likes this.
paulhead is offline
post #9 of 24 Old 10-20-2020, 08:24 PM Thread Starter
paulhead
paulhead's Avatar
17
paulhead is offline
post #10 of 24 Old 10-21-2020, 02:36 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
It’s funny because of this thread I finally figured out why they sent me such long sleeves. The Krawler tank goes from frame rail to frame rail so you don’t use half the sleeve. I was like “why would they send such long sleeves?” Now I know.
87TPIYJ is offline
post #11 of 24 Old 10-21-2020, 01:29 PM Thread Starter
paulhead
paulhead's Avatar
Popped the tank back in, hooked up the fill/vent hoses (for the vent I used a heater hose part# 19782 and cut off an inch, worked perfect.
Got great clearance
Half *** cut the tail pipe, it's blowing on the corner of the tank but I''l get back to it once I stretch it.
Dropped about 6 gallons in it and it registered a hair over a quarter tank, started right up, I'll see how good or bad I bent the float when I top it off.
87TPIYJ, NHfireLJ and 11-11-11 like this.
paulhead is offline
post #12 of 24 Old 10-26-2020, 05:43 PM
bdavid500
Great write-up. I just did this install, I didn't have access to a welder so I opted to bolt a piece of angle onto the forward tank mount. Then bolted that to the frame. Not a better method just different and didn't require welding. I had my exhaust done at a shop in Denver,. After 2 attempts I think they now have it routed so it won't rub the tires when I am flexing the rear suspension.
bdavid500 is offline
post #13 of 24 Old 10-26-2020, 06:44 PM
bruinjeeper
Man that is one nice item.... look like it is going to work out nicely for you Paul.
post #14 of 24 Old 10-27-2020, 05:58 PM
jserna
1987 YJ Wrangler
jserna is offline
post #15 of 24 Old 10-29-2020, 02:05 PM
ThomasYJ
Knuckle dragger
ThomasYJ's Avatar
Good call on this. Hadn't crossed my mind, initially. I'll knock that out when I re-drill the new frame rails and put the tank back in.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
