Gear ratio confusion - JeepForum.com
 8Likes
post #1 of 23 Old 11-12-2019, 05:17 PM Thread Starter
siilverback68
siilverback68's Avatar
1987 YJ Wrangler
I am confused. I took apart my front end and the ring and pinion are pitted badly and needs to be replaced. Going off the tooth count I have a 3.54 gear ratio. 46 teeth on ring and 13 on pinion. Is this the same as 3.55 gears? I am looking at replacement ring and pinion and the teeth count is different. According to the specs of some of the replacement sets I am looking at the teeth count is 39/11 which is still 3.54. Will the different teeth count make a difference on fitment? I have a 87 YJ with a 4.2 and putting a AX15 into it.
siilverback68 is offline
post #2 of 23 Old 11-12-2019, 07:21 PM
NHfireLJ
NHfireLJ's Avatar
3.54 is numerically the same as 3.55
as long as the ratio is the same, they are all interchangable
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #3 of 23 Old 11-12-2019, 07:35 PM
80cj
80cj's Avatar
1980 CJ5
Whatever 3.54 or 3.55 set you decide on, be sure the ring and pinion have matching numbers to show that they are a matched gear set.
80cj is offline
post #4 of 23 Old 11-12-2019, 07:37 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by 80cj View Post
46/11 is a 4.18 gear ratio. Actually, unheard of or at least not a common ratio.
Re-read it. He never said 46 by 11
SOLD
style intake
NHfireLJ is offline
post #5 of 23 Old 11-12-2019, 09:09 PM
CSP
As long as the ratios are within 1% of each other, you're fine. Those two are only 0.007 gear ratio points apart, or 0.2%.
Many 1970s Ford trucks left the factory with 3.50 in the rear axle and 3.54 in the front.
Randonexplosion likes this.
CSP is offline
post #6 of 23 Old 11-12-2019, 10:32 PM
80cj
80cj's Avatar
1980 CJ5
I know. I screwed up and corrected my post.
NHfireLJ likes this.
80cj is offline
post #7 of 23 Old 11-13-2019, 05:52 AM
Siva283
Siva283's Avatar
Also you know its not as easy as just bolting the new stuff on right?
New gears new set up. While not hard its not easy either and requires special tools
Ask me how I know...
Siva283 is offline
post #8 of 23 Old 11-13-2019, 09:33 AM
Waternut
Waternut's Avatar
I'd like to see pictures. You'll probably be a minimum of $400 in parts to replace those gears and if you have a shop do the work, add another $500-$600 because it's a time consuming job. If you do it yourself, you'll probably be a couple hundred into special tools that you may or may not have and will have very limited use in other applications.
There are definitely smarter, easier, and cheaper ways to fix common gear ratio problems including a used axle. Sounds like more work but I promise you that swapping in a used axle and changing out any bad parts is WAY easier.
Waternut is offline
post #9 of 23 Old 11-13-2019, 09:38 AM
fishadventure
fishadventure's Avatar
He’s in Florida-
He could throw me a couple hundred and a spare bedroom for a week and I’ll drive down and do it for him... more than 50% serious here lol
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is online now
post #10 of 23 Old 11-13-2019, 10:30 AM
Siva283
Siva283's Avatar
Originally Posted by fishadventure View Post
He’s in Florida-
Well **** if we are going that route I would do it for the spare room and air fair
Siva283 is offline
post #11 of 23 Old 11-13-2019, 12:07 PM
1project2many
My first job as a mechanic was learning to overhaul gearboxes and axles way back in 1987. I still do it on the side. The tools I use for R&P replacements include:
Small hammer
Medium hammer
Selection of various diameter exhaust tubing
Cutoff wheel
Chisel
10" drift
Bronze Punch
Prick punch
Set of "setup" bearings w/ ID honed
Pile of shims collected over the years
Dial indicator
Ring gear marking compound / white grease
Combination wrenches
Pry bar
Torque Wrench
The absolutely most important part of R&P replacement is cleaning. If the R&P or bearings are bad expect to spend 2-3 hours cleaning. Not clean = parts failure.
Boojo35 likes this.
1project2many is offline
post #12 of 23 Old 11-14-2019, 05:23 PM Thread Starter
siilverback68
1987 YJ Wrangler
Which photos would you like? I have a friend who has an entire shop. The only hard part is its currently not even a rolling frame. Going to take front axle off to take to his shop. You are not kidding about the prices. SO far the least expensive gears that are same ratio are about $330 and the master rebuild kit about another $150. The 3.55 gears for the Dana 30 are expensive. It would almost be same cost to switch out both front and back to a higher gear ratio.
post #13 of 23 Old 11-14-2019, 08:33 PM
Waternut
Waternut's Avatar
I was looking for pictures of the pitting in the gears. The thought process was if it's not too bad, you just roll with the pitted gears until they fail because you aren't really going to tear much else up if you do. For $300, you should be able to just buy a whole new axle and bolt it in. This option is very viable especially if you're already talking about taking the axle to a shop.
The price and procedure is the same whether you swap in 3.55 gears or 4.88.
Waternut is offline
post #14 of 23 Old 11-15-2019, 05:43 PM Thread Starter
siilverback68
1987 YJ Wrangler
Here are the photos.
post #15 of 23 Old 11-15-2019, 05:45 PM Thread Starter
siilverback68
1987 YJ Wrangler
I did not think of a new axle. What would you suggest? I also appreciate the offers of room and board to switch it out for me. Unfortunately I am not sure any of my kids would give up their room.
gear change , pinion , ring and pinion
