Gear oils - JeepForum.com
 10Likes
post #1 of 28 Old 09-03-2019, 10:35 AM Thread Starter
V8orBUST
V8orBUST's Avatar
Gear oils
So I'm switching to synthetic gear oil now that my 4.11 gears are well broken in using super tech dino oil. I am going to do a 75w90 in the front and 75w140 in the 8.8. I have been considering valvoline syn tech, mobil 1 and royal purple. Since I get 20% off at autozone, I am sticking with those brands.
I can however get the royal purple for $15.99/qt at local parts house plus 10% off as apposed to AZ @ $21.99
Anyone have a preference or gripe between these?
Adopt-a-Trail Volunteer SBNF 3N17
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #2 of 28 Old 09-03-2019, 10:56 AM
Siva283
Siva283's Avatar
I use whatever is cheapest. We arent putting a thousand horsepower through our diffs and we usually change our diff oil alot more often than most because WATER. So pic your poison and toss it in. I have been using Lucas 80w140 in both mine. D30 lunchbox locker and 8.8 with AUburn Ected Locker. I do add limited slip additive to the 8.8
80cj and NHfireLJ like this.
Ask me how I know...
Siva283 is offline
post #3 of 28 Old 09-04-2019, 08:10 PM
zrickety
zrickety's Avatar
I use Mobil 1 gear oil...in all my vehicles. FWD, RWD, 4WD. I'm a Mobil 1 user for life, it saved my engine when I overheated a Trans Am. The gear oil is balanced and doesn't corrode yellow metals. And LSD safe.
1988 Jeep Wrangler Laredo
zrickety is offline
post #4 of 28 Old 09-05-2019, 02:47 AM
80cj
80cj's Avatar
1980 CJ5
I fully agree with Siva 283. I'll go further to say that any good quality GL-5 hypoid gear lube should suffice for our Jeeps. I've used Valvoline GL-5 80W90 High Performance gear lube in my CJ-5 for many years with no problems.
80cj is offline
post #5 of 28 Old 09-05-2019, 06:47 AM
vadslram
How many rivers do you plan on playing in?
If you are going to be axle deep a lot I would put the cheapest you can get because it is soo much cheaper to flush it regularly than deal with rusted gears and bearings.
I use Amsoil but that's because I have a dealership and it is cheaper wholesale than any other brand. Frankly I don't recommend it for people that play in the water a lot though because what it is too expensive to drain 4 or 5 times a year at retail cost.
That said I also have it in my truck and have had it for the last 75K miles (since I played tug boat in the streets during a hurricane.) and synth is the only way to go if you want to keep your stuff running and efficient. I'd say go with a good synth bearing grease too. They are much less likely to wash out or separate and leak out.
uptillnow likes this.
vadslram is offline
post #6 of 28 Old 09-05-2019, 06:52 AM
Siva283
Siva283's Avatar
I should add the only reason I use Lucas is because by the gallon its cheaper on Amazon. My front now has the walmart special in it because I developed a pinion seal leak and needed gear oil immediatly and couldnt wait for shipping. I have a gallon of it and I will use it until its gone. Any gear oil should be up to the task with todays standards. I also have mixed brands just to use up what I had around. I have never had any troubles with it. My lockers seem fine as well. I DD my jeep 60 miles each way to work plus other running. Just dont use GL-5 in your transmission that will eat the syncro's your diff has no yellow metals and diffs are pretty hearty things the bearings just want some kind of lube. I dont suggest it but I have seen people put 10w30 in thier diffs and they even seemed happy with that.
Siva283 is offline
post #7 of 28 Old 09-05-2019, 07:49 AM
downs
downs's Avatar
1995 XJ Cherokee
I just run Supertech 80-90. Haven't felt the need to get fancy. I keep a gallon jug on the shelf all the time. They make a synthetic 75w-90 and 75W-140 if you want synthetic in there. I dont think the make the syn stuff in gallon jugs though.
At this point the only thing that doesnt have supertech in it on my Jeep is the trans and tcase
Sent from my SM-G892A using Tapatalk
timatoe likes this.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #8 of 28 Old 09-05-2019, 09:02 AM
Siva283
Siva283's Avatar
Supertech does make Synthetics in the gallon jugs too. Some walmarts have it some dont. I got a gallon of 75w90 synth last night.
downs likes this.
Siva283 is offline
post #9 of 28 Old 09-05-2019, 09:04 AM
Siva283
Siva283's Avatar
Oh and that Supertech gear oil is $13.97 a gallon at Wally World
downs likes this.
Siva283 is offline
post #10 of 28 Old 09-05-2019, 06:49 PM
Chrisnvegas
Chrisnvegas's Avatar
Been using Royal Purple for years. Have never had a failure... ever.
Water is not an issue (I'll go around a 2" mud puddle) but heat sure is. I use my Jeep at the dunes and stuff gets hot.
A Law repugnant to the Constitution is void. Marbury vs. Madison 1803 I'm talking to you, Virginia...
Chrisnvegas is offline
post #11 of 28 Old 09-07-2019, 07:20 AM
mudbug85603
mudbug85603's Avatar
It has been proven time and time again by people a lot smarter than me, that synthetic gear oil in diffs is a bad idea. Synthetic gear oil does not transfer heat near as well as Dino oil so your gears and bearings will run hotter than they should. Yes, your diff cover will feel cooler with synthetic oil but the internals will be hotter. If you don't believe this, research it yourselves.
timatoe likes this.
'98 TJ 5sp Super 35 D30 w/Aussie 5.13 on 33's
'94 YJ 5sp 4.88 Super 35/HP30 w/Aussie on 33's
mudbug85603 is offline
post #12 of 28 Old 09-07-2019, 05:14 PM
Chrisnvegas
I have heard that before.
post #13 of 28 Old 09-08-2019, 11:11 AM
downs
downs's Avatar
1995 XJ Cherokee
Ive never heard that and cant find anything to back it up. My googlefu must be weak today.
downs is offline
post #14 of 28 Old 09-09-2019, 02:56 PM Thread Starter
V8orBUST
V8orBUST's Avatar
There is no published tests of any kind to back up this claim that I have seen. Synthetic oils have better heat transfer characteristics than conventional.
YJOTM November '18
IYAAYAS
V8orBUST is offline
post #15 of 28 Old 09-09-2019, 03:07 PM Thread Starter
V8orBUST
V8orBUST's Avatar
Thanks for all the feedback, I decided to use the valvoline synpower in my green jeep since it meets J2360 spec and it's easier to find. I avoid mud and water, so I do not plan to do a drain and fill very often and $10/qt it is not terribly pricey.
I also got some royal purple to put in my other 2 yjs that do not see anything crazy if at all. Figure the royal purple will be an 80K gear oil on those rigs.
I will be tracking mpg numbers as always so I'll post up results after a couple fillups.
Side note, I ordered 3 gallons of redline mt90 for all the transmissions. Cant wait to have a true GL4.
YJOTM November '18
IYAAYAS
V8orBUST is offline
