Gear Carriers for gear ratio swap - JeepForum.com
post #1 of 2 Old 05-04-2006, 10:37 AM Thread Starter
bwiencek
OK - I've got some conflicting information on this one... '88 YJ with I6 and 5-speed.
I believe that my jeep has the 3.54 axle ratio, and was looking to put 4.10's in it. My understanding is the carriers have to be swapped for anything lower, but then I was told ONLY the front carrier needs to be swapped and the rear is fine and doesn't need to be swapped. I've searched here but couldn't find any definate info - most just reference the carrier needs to be swapped.
bwiencek is offline
post #2 of 2 Old 05-04-2006, 10:52 AM
bretm
Guest
I have an 88 that used to have 3.55s that I swapped to 4.11s, but truetrac in the rear so not sure about it. The front definitely has to be swapped.
You could always ask whoever you are buying your gears/carriers from. I got em from Randy's R&P, the sales guy knew immediately, but I can't recall the cutoff for the D35. I think the D30 was 3.73s with the stock sized carrier.
bretm is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 07:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 08:30 PM
Gear Ratio Swap Question ebills4595 TJ Wrangler Technical Forum 4 10-13-2007 02:40 PM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 10:52 AM
