Gauge Recomendations - JeepForum.com
 2Likes
post #1 of 17 Old 07-21-2021, 05:55 AM Thread Starter
Siva283
Siva283's Avatar
So at Great Lakes Jeep Jam I did some bartering and am scoring a custom dash extremely cheap. I need to decide what brand gauges I want and what gauges I want. Once I decide that it will be custom made and a direct bolt in with all the correct holes to mount everything up. Ill probably have a hook or two welded to the back for the wire harness. What has everyone been going with for gauges. I know there will be wiring involved so the simpler the better.
http://www.logansmetal4x4.com/ is who is doing it. She does amazing work.
Second question. How has everyone with Hydro assist routing the lines. I am having the worse trouble keeping them from rubbing the balancer.
Siva283 is offline
post #2 of 17 Old 07-21-2021, 06:28 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Gauges are a budget item, some people go cheap, others get high end. I went with Autometer, their Phantom line because to me it was easiest to read. For wiring, go to a junk yard and get a few nice male/female 8-12 pin connector combos from any vehicle. I use one plug for headlights and speakers, another for instrumentation, and a third for the off-road section (ARBs, winch, OBA).
Siva283 likes this.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #3 of 17 Old 07-21-2021, 08:10 AM
mark1305
mark1305's Avatar
I like Autometer and VDO stuff. Just throwing out a thought: Last "hot rod" build I did involved a Ford 460/C6 combo and I went old school with just three mechanical gauges. Oil pressure, mechanical temp which requires a sensor port somewhere in the water jacket, and ammeter. I considered those the important three in addition to the stock gas gauge in the dash. Those three fit perfectly in the big square space where the 8 track player used to be.
89 YJ Parts Bin Special titled as 84 CJ7; parts ranging from 1984 -2000; 4.2L with AX-15. Also a 2000 XJ Sport 2WD with a troublesome AW4.
mark1305 is offline
post #4 of 17 Old 07-21-2021, 08:26 AM
jbolty
Administrator
jbolty's Avatar
I pull my hoses out of the way of the pulley with a bungee and they can still move around with the axle.
autometer for me. so nice knowing the real temp and how much gas I have.
jbolty is offline
post #5 of 17 Old 07-21-2021, 09:29 AM
Waternut
Waternut's Avatar
Gauges are 100% style and budget. There isn't really a wrong choice but this is certainly your opportunity to be different/unique. Ignoring price for now... Most aftermarket gauges with the exception of the fuel gauge are pretty generic. Fuel gauges require a specific ohm rating and I think the stock YJ fuel tank sender is 0-90ohms. Beyond that, find some gauges you like that are in your price range. Then evaluate if they are something you can live with. For example, if the coolant temp gauge goes from 80 degrees to 260 degrees but only has a 45 degree sweep, you'll never be able to look at the gauge and tell that you're overheating because the gauge just isn't fine enough, especially if you have to look at an angle. Likewise, if you get a digital gauge, you may quit looking at it completely because it shoots up and down 30-40 degrees every time the thermostat opens/closes.
Waternut is offline
post #6 of 17 Old 07-21-2021, 09:06 PM
timatoe
timatoe's Avatar
I went with the Autometer Phantoms as well.
timatoe is offline
post #7 of 17 Old 07-23-2021, 05:19 AM Thread Starter
Siva283
Siva283's Avatar
I did not even think about things like the headlights and dimmer switch and idiot lights. Good points I am still a newbie to wiring so I better look up diagrams for all those
Siva283 is offline
post #8 of 17 Old 07-23-2021, 05:25 AM Thread Starter
Siva283
Siva283's Avatar
How long to the bungies last? I DD mine.
I have the box brace that goes to the passenger frame rail I was thinking about sheathing them putting that brace back on and some zip ties. That should allow it to move if I do it right. I was thinking about using thin ones that break easy just in case
Siva283 is offline
post #9 of 17 Old 07-23-2021, 05:27 AM Thread Starter
Siva283
Siva283's Avatar
Good stuff I didnt think about the ranges or the sweep. I am a complete newbie at gauges. Thanks for that tidbit. That definitely makes a bog difference and is good to know.
Siva283 is offline
post #10 of 17 Old 07-23-2021, 09:07 AM
timatoe
timatoe's Avatar
Totally missed the hydro assist question.... I just have them going from the box to the ram and put a zip tie to the two lines. They seem to stay in place all on their own. I use some generic springs to pull the long brake hoses out of the way, you could do something like that.
CJWoodman likes this.
timatoe is offline
post #11 of 17 Old 07-23-2021, 10:40 AM
downs
downs's Avatar
1995 XJ Cherokee
IMO the cheapest anyone should go on gauges is Auto Meter's "Autogauge" line. They're affordable.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #12 of 17 Old 07-24-2021, 02:41 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
Well, ill go ahead and give them a shout out here because they deserve it.
Speedhut.
I've had zero issues, it was the first set of aftermarket gauges i ever ordered. They're packaging is perfect, their interactive website is perfect, fully customizable if you;re into that sorta thing, great customer support and great wiring harnesses included. Keeps everything neat
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #13 of 17 Old 07-26-2021, 05:03 AM Thread Starter
Siva283
Siva283's Avatar
I like this simple idea for the Hydro Lines I am gonna give that a shot and see if it works on mine. Simple and cheap is the best
Siva283 is offline
post #14 of 17 Old 07-26-2021, 05:04 AM Thread Starter
Siva283
Siva283's Avatar
Speedhut.
Awesome to hear. I will have to take a peek and check them out.
Siva283 is offline
post #15 of 17 Old 07-26-2021, 02:51 PM
bruinjeeper
Speedhut.
Also includes sending units.
