Game of “what’s this” - JeepForum.com
 2Likes
  • 1 Post By Luuca
  • 1 Post By Awesome
post #1 of 10 Old 09-03-2019, 01:25 PM Thread Starter
jhrebs
1987 YJ Wrangler
Open end of a metal tube in driver side engine compartment. Metal tube runs along frame near brake lines. Connects to rubber hose. Goes to passenger side of fuel tank. Goes up then back down and then into my tank. I don’t think it’s a breather because I have one of those on the other side of the rank with a check valve in it. Here are some pictures.
Sent from my iPhone using Tapatalk
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #2 of 10 Old 09-03-2019, 01:27 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Vacuum hose patched long ago terminating to thin air.
Best guess is someone took the Charcoal Canister off and never went back.
timatoe likes this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #3 of 10 Old 09-03-2019, 01:32 PM Thread Starter
jhrebs
1987 YJ Wrangler
I still have my charcoal canister intact. Passenger side under the battery. I’ve never noticed this before. I’m pretty observant of things in my engine. So I’m assuming I accidentally knocked something off?
jhrebs is offline
post #4 of 10 Old 09-03-2019, 03:50 PM
bruinjeeper
bruinjeeper's Avatar
Are all the hoses and lines plugged into your charcoal canister?
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is online now
post #5 of 10 Old 09-03-2019, 09:01 PM
Awesome
Awesome's Avatar
Fuel return line for anti-vapor-lock system that someone removed? Is your carb stock or have blocked-off ports?
uptillnow likes this.
The 4th 5-seater YJ in the world.
Awesome is online now
post #6 of 10 Old 09-04-2019, 03:08 PM Thread Starter
jhrebs
1987 YJ Wrangler
Throttle body injection.
jhrebs is offline
post #7 of 10 Old 09-04-2019, 05:05 PM
Awesome
Awesome's Avatar
Oh right, four cylinder. I thought you had the 4.2 for some reason. I still think it's a fuel return line.
post #8 of 10 Old 09-04-2019, 06:07 PM
Boojo35
1987 YJ Wrangler
The line that curves up at the front left frame rail should have a hose that goes to the charcoal canister. The other end of that line should terminate right next to where your steel fuel lines terminate. The line in question goes then to the vent or vacuum line that is teed into both valves on the top of the tank.
Here is a couple of pics at the rear. The line hanging down in front of the tank would hook to the only rusty steel line in the other pic. Hope this helps.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #9 of 10 Old 09-04-2019, 06:50 PM Thread Starter
jhrebs
1987 YJ Wrangler
Awesome. Thanks.
jhrebs is offline
post #10 of 10 Old 09-07-2019, 06:23 PM Thread Starter
jhrebs
1987 YJ Wrangler
I found a line coming off of the charcoal canister that lead to the “area” of the hard line not connected. However it didn’t reach. What a PITA to fix. The diameter of the hard line is smaller that the opening on the charcoal canister. AND there was a plastic fitting inside the hose at the canister end. I muscles the fitting into the new hose and with a little might and some lube was able to get the new hose back onto the canister.
Thanks for the help guys.
jhrebs is offline
