Fuse Block Fuse and Alt. Pwr. 2 Fuse in PDC Blows Immediately - JeepForum.com
post #1 of 5 Old 08-12-2020, 02:13 PM Thread Starter
_JeepZB
So I've been struggling this past week with getting my YJ to start. It's a 1994 4.0L with 5-speed manual. I tried to move it out of my garage so I could clean up a bit and it would not start, turns out the battery was dead so I got a new one, hooked it up then it turns out the starter was bad so I got a new one. Well once I hooked every thing back up, the bendix gear would spin in place but not shoot out, I had the starter tested and it works fine. I then start following the signal wire to see if something is wrong and I follow it all the way up to the PDC and its fine. I checked all of my grounds, cleaned them and the contact points so they're good. I check all of my fuses and the Alt. Pwr. 2 fuse was blown and the fuse block fuse. So I follow the wire going to the alternator to look for a short or something grounding itself out. My buddy used his voltmeter and found continuity where "Alt. Pwr. 2" fuse goes. All of the wires and connections are good so I took the alternator off and had it tested and thought maybe it was possible there was a short inside of it. Turns out the alternator was bad, so I then proceed to hook everything back up, get new fuses and relays and install them. As soon as I hook the battery up it immediately blows the Fuse Block fuse and Alt. Pwr. 2 fuse again. I'm at a stand still and close to burning the thing down.
_JeepZB is offline
post #2 of 5 Old 08-12-2020, 04:07 PM
jtec
jtec's Avatar
2014 JK Wrangler
I want to be sure we are looking at the same fuse (circuit) I attached a diagram of PDC is this the circuit/fuse?
I ahte going down the wrong rabbit hole.
jtec is offline
post #3 of 5 Old 08-12-2020, 04:10 PM
jtec
jtec's Avatar
2014 JK Wrangler
What happens if yu do NOT hook up that wire to back of Alt-
does it still blow ?
jtec is offline
post #4 of 5 Old 08-12-2020, 05:59 PM
Boojo35
1987 YJ Wrangler
I agree with Jtec. If you are identifying the correct fuse per the info he supplied and if it blows that fuse immediately, disconnect the alternator. It is the only thing on that circuit according the schematics I have. If we are on the same page, It should be the easiest short to ground you will ever trace. It is a larger wire and the only thing on the circuit.
If the fuse does not blow with the alternator disconnected. Your alternator is bad. If it still blows, trace the wiring for its path or short to ground.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #5 of 5 Old 08-13-2020, 12:43 PM
Louie4
Louie4's Avatar
1935 CJ2A
You could unhook the battery ground and power and check for continuity on the alternator wire to the battery and the battery ground. If you have continuity, you have a short. If you follow the above post you will probably find it quickly.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
