Fuel tank mishap - JeepForum.com
 11Likes
post #1 of 34 Old 07-24-2021, 11:54 AM Thread Starter
93YJ4FUN
So a couple months ago when dropping the tank, the very old filler and vent houses had to be cut off. I finally got back to the project today, took the hose ends off of the tank, and saw that the vent line connector had been damaged.
Let me know if I can still use this tank, or if I just forced myself to spend more money. Any advice is appreciated. I'd rather know now than just assume it'll be ok.
IMG_20210724_103927_7_1627149271331.jpg   IMG_20210724_104032_4_1627149364295.jpg
93YJ4FUN is online now
post #2 of 34 Old 07-24-2021, 01:36 PM
timatoe
timatoe's Avatar
I'd clean it up so no chunks fall into the tank and use it.
timatoe is offline
post #3 of 34 Old 07-24-2021, 02:11 PM Thread Starter
93YJ4FUN
Maybe double clamp it? Would that even matter?
post #4 of 34 Old 07-24-2021, 06:56 PM
timatoe
timatoe's Avatar
Wouldn't hurt it to double clamp, but there's not any strain on it and it just vents so not like it's going to "leak".
Awesome likes this.
timatoe is offline
post #5 of 34 Old 07-28-2021, 07:09 AM
fishadventure
fishadventure's Avatar
Yup. Run it.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 34 Old 07-29-2021, 05:45 AM
Siva283
Siva283's Avatar
Take that insert out of the vent tube too and enjoy your now 20 gallon tank
bruinjeeper and Wyo like this.
Siva283 is offline
post #7 of 34 Old 07-29-2021, 07:50 AM
Dake
Dake's Avatar
I’d just sand it smooth and use it. A new tank is vary expensive .
Waiting on my Rough Country lift to sag!
April 2020 pandemic YJOTM
Dake is offline
post #8 of 34 Old 07-29-2021, 08:50 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
In order to use that tank, you will need to clean up the cuts to the vent hose line, install a Poision Spyder hood vent on your hood, and perform an LS swap on your engine. I mean, really, if you are going through all the trouble to clean up that vent tube, might as well go ahead and do the V8 swap at the same time.
Boojo35, bruinjeeper and stalag17 like this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is online now
post #9 of 34 Old 07-29-2021, 06:40 PM
Boojo35
1987 YJ Wrangler
@Luuca is mostly correct but he forgot that double clamped or not you are at risk of a fuel leak. You really need to stretch your wheel base by 12 or more inches and probably go full width to lessen the angles of the tank.
JK. Smooth it off and run it.
Just curious but I think I know the answer. That was a sawzall job that caused that.... wasn't it?
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #10 of 34 Old 07-31-2021, 08:08 PM
YMFriday
YMFriday's Avatar
Yep, anyone who’s done the 20 gallon mod looks exactly like that, or they just scrapped the insert altogether. You’re good.
YMFriday is offline
post #11 of 34 Old 08-02-2021, 05:36 AM
fishadventure
Originally Posted by Boojo35 View Post
@Luuca is mostly correct but. Smooth it off and run it curious
You just have to soften up the plastic with a propane torch…
(that was a joke. don’t do that! you will die)
post #12 of 34 Old 08-02-2021, 07:18 AM
jbolty
Administrator
jbolty's Avatar
IF you do it anyway, take pictures....
timatoe likes this.
jbolty is offline
post #13 of 34 Old 08-02-2021, 08:00 AM
Rapidrob
Rapidrob's Avatar
JP Weld the cracked-off area. Will last forever.
Luuca likes this.
'Nam Vet
Tin Can Sailor
President
NM MILSURPS
Rapidrob is offline
post #14 of 34 Old 08-04-2021, 01:54 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
everyone hit it on the head.
I'd use the time and free space right now to cut a clean access hole for future maintenance service on tank internals.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #15 of 34 Old 08-04-2021, 02:19 PM Thread Starter
93YJ4FUN
Speaking as someone that has only taken the tank out and not yet or it back in, it doesn't seem like it's that crazy to reinstall.
The task itself isn't so daunting to me (probably naively so lol), it's the crazy heat that seems to be affecting me more this summer than it used to.
That being said, I do want to get it running at least before I submit for YJOTM. So it'll get done soon.
Luuca likes this.
