Fuel Pump - JeepForum.com
post #1 of 4 Old 07-02-2020, 05:54 AM Thread Starter
itred
Fuel Pump
Yj let me down, no fuel to injectors, no pump sound when turn key. checked connector at fuel pump, unplugged and plugged back in looked good. tried to start, cranks but wont fire. swapped horn and fuel pump relay and she fired right up. Horn also still works? could there have just been a loose connection at the relay? or can the fuel pumps be an intermittent problem. Anybody have any problems with the fuel pump relays and this issue? I'm a bit Leary to take her to far and having another fuel issue. Thanks
itred is offline
post #2 of 4 Old 07-02-2020, 06:44 AM
NHfireLJ
NHfireLJ's Avatar
Could be all of the above.... you need to just keep trouble shooting.... clean all contacts of connections, and relays. wiggle them and wiring while its running...
Any codes? when you have a cold start, and turn the key to run does the CEL illuminate right away or is there a 30 second lag, and hearing the fuel pump kick on right away or a lag? if so, it may be the capacitors in the ECU.
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #3 of 4 Old 07-02-2020, 07:31 AM
jtec
jtec's Avatar
2014 JK Wrangler
NOTE
The fuel pump will only have 12v for @3seconds if engine does not start! ! !
This makes testing voltage at fuel pump a little complicated; The fuel pressure is often checked first, then check and jump 12v at relay to energize fuel pump circuit,
jtec is offline
post #4 of 4 Old 07-02-2020, 08:20 AM Thread Starter
itred
Thanks for the input. She is up and running now that i switched the horn and fuel relays, but the horn still works which leads me to believe it wasnt the relay itself but possible a bad connection in the fuse/ relay box. , so i don't know what the initial reason for no fuel was. Has anyone had any intermittent fuel pumps?
itred is offline
