Front Driveshaft slip - JeepForum.com
post #1 of 12 Old 07-11-2015, 09:32 PM Thread Starter
DesertLight
1987 XJ Cherokee
Alright guys put my new tcase in and rear pinion yoke. Almost done with my revival project. However the front drive shaft is bugging me. After screwing around for 20-25 minutes of trying to shove the driveline in, I've given in for a break. Im not sure the deal, tried rotating the shaft to align the spines but its not working.
TLDR; How do I get that in there? Pictures for reference.
DesertLight is offline
post #2 of 12 Old 07-11-2015, 11:46 PM
Drednot
Drednot's Avatar
take the front yoke out and reassemble on a bench. You need to loosen that collar and clean, relube, and check the seal.
Then reinstall. You can inspect the u-joint a little better, too.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/[email protected]
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/[email protected]
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #3 of 12 Old 07-12-2015, 12:35 AM Thread Starter
DesertLight
1987 XJ Cherokee
Alright. I wish I had a bench right about now lol. Ugh. Anyways how do I loosen ane adjust that collar?
post #4 of 12 Old 07-12-2015, 02:48 AM
Drednot
Drednot's Avatar
Channel locks as I recall. It doesn't need to be real tight, just snug to lightly seat the seal.
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #5 of 12 Old 07-12-2015, 02:55 AM Thread Starter
DesertLight
1987 XJ Cherokee
Sounds good. I'll get on it in the morning. I already cleaned it out with brake cleaner. So a lube and fitting should do it.
post #6 of 12 Old 07-12-2015, 08:55 PM
rustisexpected
Also make sure your U-joints are lined up. Phasing is important if you want the drive shaft to last.
rustisexpected is offline
post #7 of 12 Old 07-13-2015, 01:05 AM Thread Starter
DesertLight
1987 XJ Cherokee
That's good to know about phasing, thanks. However the collar just keeps on turning, not really sure how this sucker will work. If it'll just unscrew or pop off.
post #8 of 12 Old 07-13-2015, 02:09 AM Thread Starter
DesertLight
1987 XJ Cherokee
Alright 80 turns later. I think I'm giving up on this session for the night.
post #9 of 12 Old 07-13-2015, 11:35 PM Thread Starter
DesertLight
1987 XJ Cherokee
So what is the problem? Video is related.
Phone was leaning against the door.
https://youtu.be/Zb4-h6lTbNI
post #10 of 12 Old 07-14-2015, 07:04 PM
kloppk
kloppk's Avatar
That collar just pop's on and off. It takes some coaxing with a mallet to get it on and off. It's a snug fit.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #11 of 12 Old 07-18-2015, 04:33 PM Thread Starter
DesertLight
1987 XJ Cherokee
I finally got it the shaft in to the slip.
post #12 of 12 Old 07-19-2015, 01:14 PM
Mike Romain
Are the ears of the top and bottom U-joints lined up perfectly? So if you sat it on the floor, both ears would be flat on the floor idea.
Mike
Mike Romain is offline
