Fold and Tumble Bolt Size - JeepForum.com
post #1 of 14 Old 07-22-2021, 04:56 PM Thread Starter
burley
burley's Avatar
1976 CJ5
Anyone know what the bolt size is for the Fold and Tumble brackets that go into the floor? I just replaced a back seat and it didn't come with hardware. Do the bolts have nuts or screw into the floor/supports? I've found the bolts for sale online, but they dont list size. I'm just going to buy them locally at a hardware store, not paying $20+ for fancy Jeep bolts.
burley is offline
post #2 of 14 Old 07-22-2021, 07:52 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
If you are talking about the seat risers and the 2 each bolts that hold them to the tub, they screw into captured nuts on the body. Exact size, I do not know.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is online now
post #3 of 14 Old 07-23-2021, 07:33 AM Thread Starter
burley
burley's Avatar
1976 CJ5
I'm talking about the back seat, forward facing brackets that that allow the seat to flip forward on a hinge. See attached photo. It seems like there are nuts in the body, I just dont want to go back and forth 100 times at the hardware store or buy 30 different kinds to bring home.
I found a seller on ebay selling a set and he responded that his are " 3/8"-16 x 7/8" Hex Flange bolts Grade 8". I cant believe he told me the size, who would pay some guy on ebay $20 for something you could get locally, same day, for $5.
In any case, I'll pick these up to see if they fit, but if anyone else can confirm it would help.
burley is offline
post #4 of 14 Old 07-23-2021, 01:00 PM Thread Starter
burley
burley's Avatar
1976 CJ5
3/8"-16 x 7/8 worked perfectly, once I cleaned out the rusty holes. I used 1 1/4" long, but the 7/8" probably would have worked fine. The holes have threads, so no nut needed.
burley is offline
post #5 of 14 Old 07-29-2021, 06:22 AM
fishadventure
fishadventure's Avatar
If you area is in the rust belt, in your travels hit fastenal and buy black grade 8 flanged bolts. Were USA made and too much money. But… The metallurgy won’t rust as fast as the tractor supply and other chain crap hardware. Don’t ask how I know.
Anyways, that’s (I hope) why them there bolts on fleabay were $20. I would guess they contained molybdenum, nickel, chrome and USA steel.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 14 Old 07-29-2021, 07:00 AM
Delta0
If you are going off road, I suggest you get a higher grade.
Price difference is insignificant.
Delta0 is online now
post #7 of 14 Old 07-29-2021, 08:54 AM
Luuca
Luuca's Avatar
1986 MJ Comanche
Higher than Grade 8? Like a Grade 9? for a rear seat mounted to a pinch plate captured nut on sheet metal?
I don't follow.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is online now
post #8 of 14 Old 07-29-2021, 06:27 PM
Boojo35
1987 YJ Wrangler
I don't follow.
Me either. Grade 8 is the hardest...... or so I thought. Maybe we are about to learn something new.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #9 of 14 Old 08-02-2021, 05:44 AM
fishadventure
I don't follow.
It might have been sarcasm? ???
OEM were grade 5 weren’t they?
Either way, the tracterShuply bolts are adequate for grade 8- their alloys, however, suck compared to USA, Deutschland, or some Japanese and Taiwan bolts. On my 89 the oem bolts still come out but the tractor supply stuff went awful in under two years time.
post #10 of 14 Old 08-02-2021, 02:50 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
I doubt they were grade 5 for seatbelts or mounting. But cannot confirm.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is online now
post #11 of 14 Old 08-02-2021, 04:48 PM
Boojo35
1987 YJ Wrangler
I do not recall ever seeing a seatbelt bolt that is stamped properly (which our torx bolts are not) that was anything other than a grade 8 bolt.
And for what it is worth. Sarcasm from @Luuca ??? No way.. He is as straight and serious as they come.
Boojo35 is offline
post #12 of 14 Old 08-02-2021, 05:57 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Grade 9 structural bolts, also known as grade 9 hex cap screws, are one the strongest structural bolts that can be used today. While the typical grade 8 bolt has a tensile strength of 150,000 PSI, a grade 9 bolt has a tensile strength of 180,000PSI.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is online now
post #13 of 14 Old 08-02-2021, 06:20 PM
Boojo35
1987 YJ Wrangler
Oh... Those things. I never realized that they are grade 9....
You saved my day buddy. I try to learn at least one new thing every day. Today was coming up empty, man.
Boojo35 is offline
post #14 of 14 Old 08-03-2021, 07:49 AM
fishadventure
Ok. I do know mine are hex grade 8 /now/ lol
