Flywheel grind on startup - JeepForum.com
 1Likes
  • 1 Post By bruinjeeper
post #1 of 4 Old 08-26-2016, 01:13 AM Thread Starter
andresatencio
Hey all,
Starting my jeep the last few days, every third start or so i get a horrible grind from the flywheel when I engage the starter, it seems the starter engages the flywheel, grinds and gets stuck all in the same key turn. I release the key and try again and it gets out of it and starts right up.
Do I have a chipped tooth (or teeth) in my flywheel?
I've gone through 3 starters this year, and replaced the flywheel 2 years ago when I replaced the engine.
I'm wondering if this engine really came out of a 93 yj, or maybe a 95, because at the parts store, the starters have different number of teeth.
andresatencio is offline
post #2 of 4 Old 08-26-2016, 05:45 AM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
I would get under the jeep and look at the starter maybe it came lose and is eating into the flywheel? After my starter fell out of my jeep on a drive I learned to use loctite on all the starter bolts. See if it's moving or angled.
Thomas
-1987 YJ
Tompatt is offline
post #3 of 4 Old 08-26-2016, 05:34 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
unsure and haven't done much research on the topic.... but it may have a shim and not require it.... or require a shim and not have it.
Think this is pertinent to certain years/models. SOmeone else will surely chime in on this
Chrisnvegas likes this.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #4 of 4 Old 08-28-2016, 02:13 PM
plym49
A very common problem. Some starter motors mount with metric bolts and some use SAE bolts. It often happens that somewhere along the line someone used an SAE bolt in a metric hole, or vice-versa. It seems that the bolts are tight but they cannot handle the torque of the starter motor and the starter wiggles enough to move the starter pinion too far from the ring gear on the flywheel or flexplate.
The teeth on your flywheel or flexplate are fine. Make sure that you have the right bolt in the right threaded hole and that the threads are not half eaten away.
The fix is simple: a helicoil. It takes five minutes and can be done under the vehicle with no disassembly save for removing the starter.
plym49 is offline
