First wheelin trip! - JeepForum.com
 10Likes
  • 2 Post By andresatencio
  • 2 Post By Luuca
  • 2 Post By bruinjeeper
  • 4 Post By TSEJEEPERS
post #1 of 10 Old 07-19-2016, 09:11 PM Thread Starter
andresatencio
First wheelin trip!
Goin on my first wheeling trip out of town. Approx 300 highway miles to destination to the High Sierras.
I have a couple of issues im afraid of. Mind you this trip will be on the eastern side of the Sierra Nevadas, where the towns are 50 miles apart and have a population of 1000 or less, besides Bishop, they have 3000.
I have some blowback, has spitted on my air filter pretty good. I have replaced the PCV T Valve but hasnt seemed to help. I am running stock axles and gears and no lift on 31" Toyo MT's. 2.5L engine.
Will the blowback be an issue?
Chances of snapping an axle? What do I do if that happens!?
Starter winds every once in a while and takes a try or two to get it started. Do i need to get a new starter before I go?
Jeep has about 175K, engine is somewhat rebuilt , has 89K. (Swapped in a used engine after waterlocking the original.)
Thanks for any advice. Dont have much money to work with, just looking to do some cheap fixes and fiddling before I venture out.
Luuca and Scarface6174 like this.
andresatencio is offline
post #2 of 10 Old 07-19-2016, 09:25 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
run what you brung. If it breaks, get help to get her off the mountain and get her home. Rinse and repeat. Welcome to the wonderful world of YJs (Jeeps really)
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #3 of 10 Old 07-19-2016, 10:05 PM
bruinjeeper
bruinjeeper's Avatar
pack plenty of PB and J and don't forget to have some fun.
shaggyjim and Scarface6174 like this.
bruinjeeper is offline
post #4 of 10 Old 07-19-2016, 10:40 PM
timatoe
timatoe's Avatar
Where are you going? I'm assuming stock axles on 31's you're not going too deep, so I wouldn't worry about it.
timatoe is offline
post #5 of 10 Old 07-20-2016, 12:17 AM
paulhead
if it works fix it
paulhead's Avatar
jumper cables, jack
Trying to weld has honed my grinding skills
paulhead is offline
post #6 of 10 Old 07-20-2016, 06:19 AM
TSEJEEPERS
TSEJEEPERS's Avatar
Do not go alone.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #7 of 10 Old 07-20-2016, 07:44 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I don't think you'll have a problem, if all you're doing is going on dirt roads. Just don't go crazy, especially if you're out there alone. If the starter goes out, you can always push start it.
If you get up near Mammoth, you should check out Wild Willy's Hot Springs. It's occasionally clothing optional.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #8 of 10 Old 07-20-2016, 10:52 AM Thread Starter
andresatencio
Goin with a buddy, takin me to a place called Green Creek, out towards Lee Vining and Bridgeport off the 395.
So yeah it's past mammoth, almost to NV. I'll definitely stop in Mammoth thanks haha.
Yes, stock everything. Lol.
Sent from my Verizon 4G LTE Droid using JeepForum
post #9 of 10 Old 07-20-2016, 11:55 AM
jbolty
jbolty's Avatar
Make sure stuff is fixed before you go. Anyone one can break an axle and should have a spare along but if I'm sitting on the trail for hours waiting on someone with a failing part and I find out it was known bad before the trip I might just leave them there.
jbolty is offline
post #10 of 10 Old 07-20-2016, 02:32 PM
89YJBuilder
Blow by issues are usually rings or valve guides. This sounds like over pressure in the crank case. Witch can be rings. So do what you will on that one. The starter is easy and not expensive to fix. Do it. As for spare parts carry what you can as well as with tools. Luck favors the prepared.
Oh and have fun!
Keep your boogger hook off the bang button!
When all else fails... ham radio is there!
KG6YSF
89YJBuilder is offline
d35 , dana , trip , wheeling , YJ
