First post first Jeep - JeepForum.com
 8Likes
post #1 of 16 Old 05-23-2019, 05:52 PM Thread Starter
Beeaav
Beeaav's Avatar
Well I just got a pile of Jeep yj and will be doing everything to it to make it a reliable daily driver/ desert toy. I am trying to determine where to mount my Hi-Lift jack and noticed something peculiar on the back fender (see picture attached) any idea what this mount was used for? Either an antenna or a hi lift is my assumption but I’m not sure how one would mount to it. Thanks in advance everyone! Stoked to be reading the forums and picking everyone’s brain.
31112FD4-DCE4-4FCC-BF22-6FC03A436AA4_1558655516463.jpg   5FA34FB8-484B-469E-BB60-061B69B40B12_1558655530249.jpg
Beeaav is offline
post #2 of 16 Old 05-24-2019, 07:41 AM
flcracker
I believe that keeps your spare from destroying the tail-light
bharris68 and zrickety like this.
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #3 of 16 Old 05-24-2019, 08:02 AM
timatoe
timatoe's Avatar
That's the bump stop for the stock spare tire to keep it from smashing out the tail light.
On to your actual issue of mounting the hi-lift.... Where do you plan to lift the jeep from? That rear bumper is not suitable (it may work but, not ideal) and I see no points other than the body to lift from. I'd worry more about how and where to lift the jeep than where to mount it. I too went out and bought a hi-lift early on, it's been in the shed for pushing 9 years, I carry a small bottle jack instead. It's easier to stow and use.
Additionally please fill out your profile as it will help others help you as you move along with your build... https://www.jeepforum.com/forum/f12/...guide-4348507/
222Doc likes this.
timatoe is offline
post #4 of 16 Old 05-24-2019, 10:58 AM
jbolty
jbolty's Avatar
What he said. There seems to be some rule that when you get a jeep you need to get a hi lift and a winch before anything else. I have literally 5 hi lift jacks at my house people have given me over the years because they never use them and I hardly ever carry one in the jeep.
jbolty is offline
post #5 of 16 Old 05-24-2019, 11:26 AM
Chrisnvegas
Windows95
Chrisnvegas's Avatar
In the tens of thousands of miles of Jeeping in the desert, I have never needed a high lift jack. A winch in the desert is mostly extra weight. There is nothing solid enough to hook to.
My first accessories were a good tire inflator and tire repair kit. A decent shovel is helpful. Proper desert tires will keep you from getting stuck in the first place.
Tires should fit the wheels properly to keep vulnerable sidewalls from tears. Choose quality tires with stout sidewalls. If you have a 4.2, carry an extra fuel pump and tools to replace it. New fuel pumps are made in China and are not reliable enough to bet your life on.
Standard rules apply. Don't wheel alone. Bring water. Have a good tow strap. Tell family or friends were you are going and when you will be back. Be prepared for as much as you can. The desert favors the prepared and is unforgiving the unprepared.
Make sure the Jeep is in good condition before venturing out too far. Do a walk around before leaving. Check belts, hoses, look for leaks, lubricate things that need it. That kind of thing. Always leave with a full fuel tank.
GPS with "breadcrumbs" is really helpful. As is a HAM or CB radio.
What's your general location?
Fill out your profile so we know more about your Jeep.
Here's me violating most every Jeep safety rule.
I was alone
No cell service
Had been drinking (forgot to put Jeep into 4 wheel drive)
Did not air tires down
2:00 am
No water, only beer and pretzels
Fortunately I told my kid where I was going. He showed up with his K-5
Tophog1 and zrickety like this.
End the Ethanol Rip-Off
Chrisnvegas is offline
post #6 of 16 Old 05-24-2019, 03:13 PM
Awesome
Awesome's Avatar
Ignore what they are saying. That's the optional rear quarter panel high-power HAM antenna high-gain mount. It was only a Jeep dealer option for four months. I've never actually seen one before.
Okay, so I'm kidding.
I don't have pictures, but I have used my high-lift several times to get me out of bad spots. One time I slid into a mud hole that I was purposely trying to go around and got stuck. The only trees were behind me. I had to use the high-lift and winch myself backwards 1 inch at a time until I was perpendicular to a tree that was about 50 yards away. I then used the electric winch to pull myself out of the hole sideways. It bent my winch plate pretty good, but it pulled me out.
Another time, my front shackles inverted. A bottle jack would have been useless. I jacked up the front of the Jeep until it was off the ground, and the springs reset.
I've used it a few more times, too. I'll agree that its uses are limited, but when you do need it, it's good to have it around.
EDIT: Chris, as a desert wheeler, you should know how to use a winch in the desert. You have a spare tire and a shovel already; get a winch.
The 4th 5-seater YJ in the world.
Awesome is offline
post #7 of 16 Old 05-25-2019, 09:03 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
It's an antenna mount (once you have a tire carrier off the tailgate)
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #8 of 16 Old 05-26-2019, 12:09 AM
Awesome
Awesome's Avatar
Attachment 3830309
I had mine mounted there for a little bit, but it kept smacking the soft top when I was on the highway. I guess with the fastback top I could put it back there.
Awesome is offline
post #9 of 16 Old 05-26-2019, 09:09 PM
timatoe
timatoe's Avatar
Off Topic, but which top are you using?
timatoe is offline
post #10 of 16 Old 05-27-2019, 01:15 AM
Awesome
Awesome's Avatar
The Rampage fastback top.
There's another one made in the US, but it requires the use of full doors or modified TJ uppers. The Rampage top does not.
Awesome is offline
post #11 of 16 Old 05-27-2019, 09:33 AM
timatoe
timatoe's Avatar
Sending you a PM as to not muddy up the thread.
timatoe is offline
post #12 of 16 Old 05-27-2019, 10:35 AM
StrippedTorx
StrippedTorx's Avatar
I was alone
No cell service
2:00 am
Thank God for kids. You burried that thing
Awesome likes this.
StrippedTorx is offline
post #13 of 16 Old 05-27-2019, 10:38 AM
bruinjeeper
bruinjeeper's Avatar
Really have grown fond of my rampage top. It's taken 3 winters beatings too
timatoe and Awesome like this.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is online now
post #14 of 16 Old 05-27-2019, 06:44 PM
30yroldyj
30yroldyj's Avatar
First post Clutch/transmission issue
I have a 1988 YJ 4.2L M/T (BA-10)
Here is my problem when I first start driving the clutch and transmission work fine. Once it heats up I cannot get it into gear And it is hard to shift when I do I shut it off transmission goes into any gear no problem. Pedal feels good plenty of fluid no leaks That I can see
Any ideas?
30yroldyj is offline
post #15 of 16 Old 05-27-2019, 10:01 PM
timatoe
timatoe's Avatar
Any ideas?
You should start a whole new thread, you'll get better responses that way.
For your issue, I'd look at the rubber hose that runs between the clutch master and the bellhousing where it goes to the slave cylinder. It's likely the stock hose and 30 years old, they wear and begin to crack. Once that happens they expand when warm and you lose fluid/pressure to the slave because of hose expansion.
timatoe is offline
18 Grand Cherokee extreme amount of problems and concerns under 7300 miles professordenk WK2 Grand Cherokee Forum 22 02-17-2019 04:07 PM
Brand New 05-10 Jeep Grand Cherokee (WK) OR Commander (XK) 2.25in Lift kit superheady Suspension Parts 3 12-18-2018 10:40 PM
5 Jeep Wrangler JK Factory Wheels Like New: $500 kcall333 Tires & Wheels 0 08-23-2018 05:04 PM
Diode Dynamics Video: How to Install 2018 Jeep JL Wrangler Switchback Turn Signal LED Diode Dynamics Diode Dynamics 3 07-02-2018 09:26 AM
258 Jeep YJ Rough/Rich idle - Post nutter zgeorge YJ Wrangler Technical Forum 4 12-21-2017 05:47 PM
