Engine Temp Concerns - Page 3 - JeepForum.com
 4Likes
post #31 of 37 Old 07-16-2019, 05:59 PM
Boojo35
When you stop, coolant will want to possibly go to the overflow reservoir. Make sure that the reservoir hose is connected and not cracked. Maybe? Really look and see where the coolant is coming from after you stop.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #32 of 37 Old 07-16-2019, 06:28 PM
jay-h
Originally Posted by Z_MAN View Post
So, new discovery. I've been driving without the efan like recommended and it doesn't really get past 210.
But the two times I've come home, a few minutes after there's a pool of coolant under my jeep. Yesterday a lot and today a little. The then radiator had had green all over the fill area. I think it's the radiator cap. Mine currently says 1.1 on it. Should I get another 1.1 or get a 1.3?
That sounds like a bad cap. Even if you run hot enough to push coolant out of the cap it should all go into the bottle, never on the radiator.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #33 of 37 Old 07-16-2019, 07:20 PM Thread Starter
Z_MAN
I did look. I'm pretty sure it's coming out of the cap. The fluid is right under the radiator on the ground and dripping along the bottom. No cracks in the radiator, hoses are good, and wet green stains around the fill nozzle cap area.
Sent from my Mi MIX 2S using Tapatalk
Z_MAN is offline
post #34 of 37 Old 07-17-2019, 04:30 PM
Boojo35
Boojo35 is offline
post #35 of 37 Old 07-19-2019, 08:01 AM Thread Starter
Z_MAN
Took off of work to sort this **** out.... Turn in efan switch.. Fan not on.... Lightly tap the fan..... ON. that's a problem.
Looking at serpentine belt.... A little loose... I can spin a pulley by hand, problem 2.
Visually inspecting the engine with DAYLIGHT..... I see green under the thermostat housing.
Z_MAN is offline
post #36 of 37 Old 07-19-2019, 09:11 AM
Que89YJ
Is that coolant I see?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #37 of 37 Old 07-19-2019, 09:34 AM
Siva283
Siva283's Avatar
Check your waterpump weep hole. I thought my thermo housing was leaking but it was that weep hole on the pump. Coolant around your rad cap is an issue too as others said it should go into the over flow not leak through the cap. The 4.0 and 2.5 FI engines usually run at 210. The fuel system wont go into to closed loop under 180
Ask me how I know...
Siva283 is online now
