Engine temp 220 at idle - JeepForum.com
post #1 of 7 Old 08-19-2019, 11:27 AM Thread Starter
Jp241993
Hi, first time post here, so I have a 93 wrangler with a 4.0 automatic, the engine came out of a 95 Cherokee, has about 260,xxx miles, mostly everything was replaced, water pump, thermostat, thermostat housing, radiator, etc, I suspect this issue to be stemming from the fan clutch going bad? I have seen similar posts here on this forum and they say fan clutch, but I haven’t seen any post specific to mine since I swapped motors from an xj even tho it’s the same 4.0 engine. Any help would be much appreciated.
Jp241993 is offline
post #2 of 7 Old 08-22-2019, 03:52 PM
Louie4
Louie4's Avatar
1935 CJ2A
Does your fan spin more than a quarter turn after itís been running a while? By spin a quarter turn, thatís spinning by hand.
Sent from my iPhone using Tapatalk
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #3 of 7 Old 08-22-2019, 07:03 PM
Boojo35
1987 YJ Wrangler
Does it run cooler going down the road? I assume it does. If so that usually points to the fan or the shroud if it only happens at idle. So, belts in good condition and not slipping, fan clutch in good condition, etc.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #4 of 7 Old 08-22-2019, 07:32 PM
NHfireLJ
NHfireLJ's Avatar
The XJ fan is off set unless you relocated it... The XJ has an off set mechanic fan and then an electrical fan... Is your fan centered and with a shroud? Is this new since the eng swap? or was it previously running cool and now its a new problem?
I used an E fan in my XJ eng swap...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #5 of 7 Old 08-23-2019, 06:47 AM
Siva283
Siva283's Avatar
It is offset on some. I dont think it was on the 95 and I know its not on the 96 as I got my engine from one. If it is offset I believe the water pump is wehat offsets it so just get a YJ water pump and install it. If it was offset it shouldnt have fit in the shroud though. If you have no shroud that is definitly part of your problem. At speed the shroud doesnt matter at idle its the difference between running normal temps and overheating
Ask me how I know...
Siva283 is offline
post #6 of 7 Old 08-23-2019, 06:55 AM
NHfireLJ
NHfireLJ's Avatar
My 95 eng was offset... The fan mounts to another pulley... The water pumps mount the same but may have different rotation... If it is offset it can be mounted on the wp pulley.
SOLD
style intake
NHfireLJ is offline
post #7 of 7 Old 08-23-2019, 08:15 AM
Flyer58
Flyer58's Avatar
Has it ever run cool since the new pump or t-stat was installed? Are you sure you have all the air out of the system?
Just asking common questions for others who follow this.
Flyer58 is offline
