Engine in my 90 YJ? - JeepForum.com
 5Likes
  • 1 Post By fishadventure
  • 1 Post By Chrisnvegas
  • 1 Post By timatoe
  • 1 Post By 90_soYJ_AC
post #1 of 12 Old 03-29-2020, 07:02 PM Thread Starter
90_soYJ_AC
90_soYJ_AC's Avatar
Engine in my 90 YJ?
Changing the plugs in my YJ today and also going to do the oil filter... that reminded me that when i look up the oil filter that is currently on my jeep it says it does not fit my 90, but in my case it sure does. I believe there were at least 5 owners before me so who knows what actually was done on mine but is there a way, by some serial number on the engine block, etc what engine i actually have in mine?
It is a in-line 6 cylinder and takes oil filer PF61E with spark plugs champion rc12pec5.
Thanks in advance. Aaron
90_soYJ_AC is offline
post #2 of 12 Old 03-29-2020, 09:25 PM
JohnW63
Well, Wiki says...
The YJ used a 2.5 L AMC 150 I4 or optional 4.2 L AMC 258 I6 until 1990. Starting in 1991, a fuel-injected 180 hp (134 kW) 4.0 L AMC 242 variant replaced the 112 hp (84 kW) 4.2 L 258 CID straight-6.
So, do you have fuel injection or a carburetor ?
JohnW63 is offline
post #3 of 12 Old 03-29-2020, 09:31 PM
kevrags
There is a date code stamped on the passenger side between plugs 2 and 3 that you can use to determine the date of manufacture. Also, if your middle exhaust ports are together that's a 4.2 head. Also, some people (like me on my '90) changed the oil filter connector to take the much more common 4.0 filters, so maybe the same was done for yours as well.
kevrags is offline
post #4 of 12 Old 03-30-2020, 06:36 AM Thread Starter
90_soYJ_AC
90_soYJ_AC's Avatar
Thanks for the info John - Im running a carb so i must have the 4.2 L AMC 258 I6 but i want to check the date code that is stamped on it, which i will do.
Kevrags == great info, im going to check this today. Very interesting if the oil filter connector was changed after the fact.
post #5 of 12 Old 03-31-2020, 08:51 AM Thread Starter
90_soYJ_AC
90_soYJ_AC's Avatar
I read the plate on my engine as 110C15.
post #6 of 12 Old 04-01-2020, 05:44 AM
fishadventure
fishadventure's Avatar
That doesn’t take a PH16 or 3985?!!
(Is the pf61 just a high-volume version of PH16?)
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #7 of 12 Old 04-01-2020, 10:02 AM
LJameson
LJameson's Avatar
Seeing the blue paint makes me think your motor came out of a CJ. According to the code, the engine was made in November of 1977
1976 CJ7 Restoration:
LJameson is offline
post #8 of 12 Old 04-01-2020, 11:44 AM
fishadventure
77 and 78 often had the 12-counterweight crankshaft 🙂 and that’s some CJ but mostly jeep truck motors is what I understand.
LOL my ‘89 has a 98XJ 4.0 and I painted it AMC blue when I put it in. If the ‘78 air cleaner would’ve fit under my 1960s hood I would have used it as well just to mess with anyone who would know and might see it 😄
90_soYJ_AC likes this.
post #9 of 12 Old 04-03-2020, 12:15 PM
Chrisnvegas
Chrisnvegas's Avatar
Some 4.2's came with a different filter that's not listed.
We have one!
I'll look at the number on it when it comes home later. It's out driving around.
Took a whole lot of trial and error to find the right filter.
"Alferd Packer: Stand up, you voracious, man-eating son of a *****, stand up! There was seven democrats in Hinsdale County and you up and ate five of them."
Chrisnvegas is online now
post #10 of 12 Old 04-03-2020, 06:21 PM
timatoe
timatoe's Avatar
I bought a reman 4.2 for mine and it absolutely does not take the filter called for for a '90. Appears the block is an older 4.2, I buy the filter an '85.
timatoe is offline
post #11 of 12 Old 04-03-2020, 06:27 PM
Chrisnvegas
AC Delco PF24
Wix 51049
Wix 51055
CARQUEST 85049
Purolator L20033
IHC-NAVISTAR 384843C1
IH? Yeah, the 258 was available in some International trucks.
post #12 of 12 Old 04-06-2020, 04:51 AM Thread Starter
90_soYJ_AC
90_soYJ_AC's Avatar
Thanks --- i was able to find a good match with a quick run to Napa -- also picked up a new steering pump belt b/c the old one was squeaaaaaling bad!
Chrisnvegas likes this.
