Engine died while driving and won't start back up. Pulling code 42. - Page 4 - JeepForum.com
post #46 of 57 Old 08-19-2015, 09:26 PM
Que89YJ
Really good point John. Look at the harness for each of the 3 things I listed looking for a short.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #47 of 57 Old 08-20-2015, 03:11 AM Thread Starter
rleff34
Originally Posted by jsawduste
There are more then four sensors the green/red go to. That circuit carries voltage. Somewhere you have short to ground that caused the wire to fail. Not confident you will have fixed the problem without finding the short.
I knew something had to be causing it. Thanks.
rleff34 is offline
post #48 of 57 Old 08-20-2015, 03:56 AM
Que89YJ
Where is the harness at that burned
? I can see the section but can't tell where it's at.
Fault codes:
No Start:
Que89YJ is offline
post #49 of 57 Old 08-20-2015, 07:14 AM
fearior
fearior's Avatar
Just food for thought but i had same symptoms in my cherokee 4.0. Starter turned over fine. Fuel pump cycled, but it wouldn't even try to fire when turning over. It was the oil pressure sensor. Located right on the housing the oil filter screws into. Changed it out and it fired up like there was never a problem. It was a few dollars just food for thought.
fearior is offline
post #50 of 57 Old 08-20-2015, 07:21 AM
jsawduste
2006 YJ Wrangler
The OBD1 on the YJ doesn't use an OP signal to the ECM to control the spark therefore fuel.
jsawduste is offline
post #51 of 57 Old 08-20-2015, 03:19 PM Thread Starter
rleff34
Originally Posted by Que89YJ
Where is the harness at that burned ? I can see the section but can't tell where it's at.
I havent found that yet. The wire coating is just coming off on nearly all of the wire.
rleff34 is offline
post #52 of 57 Old 08-20-2015, 03:33 PM
Que89YJ
You have a dead short. Probably the alternator.
Fault codes:
No Start:
Que89YJ is offline
post #53 of 57 Old 08-20-2015, 04:37 PM
jsawduste
2006 YJ Wrangler
x 2
post #54 of 57 Old 08-23-2015, 09:12 AM Thread Starter
rleff34
this is at the coil harness. This was covered up with electrical tape (probably previous owner.) hmm...
rleff34 is offline
post #55 of 57 Old 08-23-2015, 09:26 AM Thread Starter
rleff34
nothing looks wrong with ground at alternator...could it be the whole alternator itself? I don't want to take off the compressor and alternator if I don't have to. Following the green and orange wire ends up at the o2 sensor as in this picture. Note the bare copper!
rleff34 is offline
post #56 of 57 Old 08-23-2015, 09:39 AM
jsawduste
2006 YJ Wrangler
The 12v ASD sensor supply is part of the O2 circuit. Also the splice for the coil power can be a trouble spot.
Check and fix what you have found then use your meter to check for any additional groundings, if any
post #57 of 57 Old 08-23-2015, 01:04 PM Thread Starter
rleff34
I'm starting a new thread so it's all easier, go check it out. If there's anything that's made me feel stupid it's owning my first jeep that is usually broken. I was debating taking it to a mechanic but I'm the type who likes to fix stuff on my own and I have the time on this sunday to do it and my willingness with you and other's knowledge can get this done on my own easily. I'm about to go stick my head under there and keep tracing the wire. Thank you!
rleff34 is offline
asd , fuel pump , relay , start problems , start-up
