Engine died while driving and won't start back up. Pulling code 42. - JeepForum.com
post #1 of 57 Old 08-14-2015, 12:01 PM Thread Starter
rleff34
93 YJ Engine died and won't start. No Start and Code 42.
The jeep has been driving fine, last night I cranked it up to leave Sonic, got half way around the parking lot/drive thru in 2nd gear feathering the gas and the engine just died. The starter engages, but it doesn't start up. OBD pulling code 42 which means ASD relay or fuel pump relay, to my understanding. (fuel guage reads.) Turning the key on I can hear what I think is the fuel pump turning on, so that could eliminate the fuel pump relay from causing the issue, am I correct? I have tried swapping both the ASD and fuel pump relays with the horn relay with no luck. I'm not sure where to proceed from here. Any help is much appreciated!
rleff34 is offline
post #2 of 57 Old 08-14-2015, 01:08 PM
Que89YJ
You need a meter to read some voltages. Make sure you are hearing the fuel pump kick on. Do you get the check engine light? For giggles jumper across the asd relay from 30/87 in the relay socket(Side of the relay show the numbers) with a short piece of wire and see if it starts.
Que89YJ is offline
post #3 of 57 Old 08-14-2015, 02:52 PM Thread Starter
rleff34
Didn't get check engine light. I'll try to jump the relay... but I can hear the fuel pump turning on. And 12, 42, 55 only codes that pulled. What voltages do I need to read? I just don't know where to begin
rleff34 is offline
post #4 of 57 Old 08-14-2015, 04:15 PM
Que89YJ
Wait no cel. You need to check power on the ecu
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 57 Old 08-14-2015, 04:16 PM
Que89YJ
Pins 3 and 9 on the ecu. Do you have a meter.
Fault codes:
No Start:
Que89YJ is offline
post #6 of 57 Old 08-14-2015, 04:21 PM
jsawduste
2006 YJ Wrangler
There's your problem. Maybe it like Wendy`s better ?
Sorry no help from me but you got Que on it. Can`t do better then him.
jsawduste is offline
post #7 of 57 Old 08-14-2015, 07:19 PM Thread Starter
rleff34
Yes, I have a meter, but I'm a little new to most of this so how do you tell which pins are which? Do I test this with the key on, engine off or do I test it with someone attempting to crank it? I appreciate your help.
rleff34 is offline
post #8 of 57 Old 08-14-2015, 08:39 PM
Que89YJ
This thread is what to check.
https://www.jeepforum.com/forum/f12/9.../topics/490788
This explains how to use Google a special way to get pics and info from just this forum
https://www.jeepforum.com/forum/f12/f...oogle-1003734/
Fault codes:
No Start:
Que89YJ is offline
post #9 of 57 Old 08-16-2015, 11:37 AM Thread Starter
rleff34
http://www.google.com/url?sa=t&sourc...gMxU4MhuIeNi8g
I'm waiting on rain to pass so I can push my jeep off the street and into my driveway for further testing.. but I was doing some testing as well as reading another post that you replied, and I have 12v in both the fuel pump relay and asd relay on pin 30 and you mentioned something about backfeeding? I will report back after I'm able to finish testing the ecm wiring harness. Damn wiper fluid reservoir.
rleff34 is offline
post #10 of 57 Old 08-16-2015, 03:40 PM
Awesome
Awesome's Avatar
The jeep has been driving fine, last night I cranked it up to leave Sonic ...
Tails? Is it really you??
The 4th 5-seater YJ in the world.
Awesome is offline
post #11 of 57 Old 08-16-2015, 06:08 PM Thread Starter
rleff34
Ecu is getting power in pin 3 and 9 when key is on. Unless I've got a bad ground it's the ecu i think... I still don't understand how it would start like normal then die 20 seconds later and stop starting..
rleff34 is offline
post #12 of 57 Old 08-16-2015, 06:32 PM
Que89YJ
I don't think it's the ecu. Check it with your meter ground at pin 11.
Fault codes:
No Start:
Que89YJ is offline
post #13 of 57 Old 08-16-2015, 06:40 PM
jaycal3
jaycal3's Avatar
Que89YJ, does all this sound eerily familiar??? Que is the man, he'll get you going no doubt!
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #14 of 57 Old 08-16-2015, 07:31 PM Thread Starter
rleff34
Meter on ohms from pin 11 to battery ground terminal (disconnected) correct? I'm not very good at wiring.. but pin 11 and 12 read 0.0 when doing that but I'm not sure if I'm doing it right..
rleff34 is offline
post #15 of 57 Old 08-16-2015, 07:37 PM
jaycal3
jaycal3's Avatar
I believe you check pins 11 and 12 with pins 3 and 9...
KCCO
jaycal3 is offline
asd , fuel pump , relay , start problems , start-up
